[Swift-user] New Java exception when moving from rc3
Chad Glendenin
chad at uchicago.edu
Fri Mar 2 18:39:16 CST 2007
$ cat swift.log
2007-03-02 14:25:07,474 DEBUG Loader Loader started
$ cat minmax-flkjse5yhp1c0.log
2007-03-02 14:25:09,645 INFO unknown Using sites file: /scratch20/
chad/src/vdsk-070301/bin/../etc/sites.xml
2007-03-02 14:25:09,646 INFO unknown Using tc.data: /scratch20/chad/
src/vdsk-070301/bin/../etc/tc.data
ccg
On Mar 2, 2007, at 6:31 PM, Mihael Hategan wrote:
> Chad,
> Can you post the log file?
> Mihael
> On Fri, 2007-03-02 at 15:26 -0600, Chad Glendenin wrote:
>> I'm still trying to run a workflow that worked with VDL rc3. With
>> Swift snapshot 070301, the command-line argument works again, but now
>> I get a Java exception:
>> $ swift minmax.kml -list=filelist.txt
>> Swift V 0.0405
>> RunID: flkjse5yhp1c0
>> Execution failed:
>> java.lang.NumberFormatException: null
>> Here's the code I'm trying to run.
>> type file_t {};
>> type filelist_t {
>> file_t file;
>> (file_t output, file_t error) minmax (file_t input) {
>> app {
>> wrapper @input stdout=@output stderr=@error;
>> //filelist_t dataset[] <csv_mapper; file="filelist.txt">;
>> filelist_t dataset[] <csv_mapper; file=@arg("list")>;
>> foreach f in dataset {
>> file_t out <regexp_mapper; source=@f.file, match="([^/]+).tar",
>> transform="\1.out">;
>> file_t err <regexp_mapper; source=@f.file, match="([^/]+).tar",
>> transform="\1.err">;
>> (out, err) = minmax(f.file);
>> Here's my input file, 'filelist.txt':
>> file
>> /scratch20/chad/src/workflow/driventurb_3d_direct_plt_cnt_000340.tar
>> /scratch20/chad/src/workflow/driventurb_3d_direct_plt_cnt_000341.tar
>> Any idea what's causing the exception?
>> By the way, the only reason I'm trying to upgrade is so that I can
>> get disk-space management to work ("<profile namespace="SWIFT"
>> key="storagesize">40000000000</profile>" in sites.xml). My
>> understanding is that if I use VDL rc3, it could overrun the
>> available scratch space and crash: I have 13.3 TB of data to process,
>> but the UC/ANL TG site only has 1.1 TB of scratch space available. So
>> if there's a way to enable scratch-space management in rc3, that
>> should be good enough for now. (I'm a Swift user, not a developer, so
>> I'd rather not be on the bleeding edge if I don't have to.)
>> Thanks,
>> ccg
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
