[Swift-user] Could not convert value to number: true
Luciano Piccoli piccoli at fnal.gov
Tue Jun 26 20:25:27 CDT 2007
Thank you for the clarification.
My goal in using the csv_mapper was to extract out the from the swift
script all hardcoded physics parameters, so that the same swift file
could be reused on different configurations without changes.
A second option is to pass all the parameters via the command line,
which I wanted to avoid. Well, the actual swift command line can be
wrapped in a shell script so the end user does not have to deal with all
the parameters.
Are there - or will there be - other ways to pass parameters to a swift
script? For example, if these parameters are kept in a database, could
they be accessed via a database mapper? Yong mentioned plans about a
database mapper last time he came to FNAL.
Luciano
Ben Clifford wrote:
> On Mon, 25 Jun 2007, Luciano Piccoli wrote:
>> Does the variable age gets read from the file at the first line? Is it an
>> integer at that point or is it still a reference to the file?
> The content of the file is never read into Swift itself. Swift will track
> files so that when you run an app block, you can refer to files there
> using the @filename construct (or equivalently, @ shorthand).
> So in:
>> (messagefile t) sayAge(int age) {
>>   app {
>>       echo "Age: " @age stdout=@filename(t);
> @age and @filename(t) will evaluate to the filename of the 'age' or 't'
> datafiles.
> If swift decides to run 'echo' on a different machine it will move those
> files to/from that remote machine and ensure that @age and @filename(t)
> evaluate to the appropriate remote filenames.
> But it won't read the contents of those files into a variable for
> evaluation.
More information about the Swift-user mailing list
