[Swift-user] Could not convert value to number: true
Ben Clifford
benc at hawaga.org.uk
Mon Jun 25 22:11:45 CDT 2007
Hi.
The csv_mapper only maps the filename of datafiles into an array. It
doesn't map actual data itself.
So this:
> type student { string name; int age; float GPA;
> student p[]<csv_mapper;file="student.txt">;
says to make an array called p[], and the filename that indicates where
data is stored for each field in student comes from each field in
student.txt.
Also, when you say this:
> int age = p[0].age * 4;
swift thinks that the data in p[0].age is stored in a disk file (because
it is mapped) and in that case, can't multiple the contents of a file by a
number.
More information about the Swift-user
