[Swift-user] Re: Swift script throws exception in mapping
Michael Wilde
wilde at mcs.anl.gov
Wed Aug 29 14:58:49 CDT 2007
Also: this was run on tg-viz-login1 from the directory ~wilde/angle/data
using awf1.swift and the swift dist in ~wilde/swift1730/vdsk-0.2-dev
- Mike
Michael Wilde wrote:
> The swift script:
> type pcapfile;
> type angleout;
> type anglecenter;
> (angleout ofile, anglecenter cfile) angle4 (pcapfile ifile)
> app { angle4 @ifile @ofile @cfile; }
> pcapfile pcapfiles[]<filesys_mapper; prefix="pc", suffix=".pcap">;
> foreach pf in pcapfiles {
> angleout of;
> anglecenter cf;
> (of,cf) = angle4(pf);
> throws the error below using trunk, 1730, updated around noon today:
> awf2.swift: source file is new. Recompiling.
> Using sites file: /home/wilde/swift1730/vdsk-0.2-dev/bin/../etc/sites.xml
> Using tc.data: /home/wilde/swift1730/vdsk-0.2-dev/bin/../etc/tc.data
> Swift v0.2-dev
> RunID: amf8l37tq0rh1
> java.lang.ClassCastException: org.griphyn.vdl.mapping.RootDataNode
> vdl:new @ awf2.kml, line: 47
> Caused by: java.lang.ClassCastException:
> at
> org.griphyn.vdl.mapping.RootArrayDataNode.init(RootArrayDataNode.java:22)
> at org.griphyn.vdl.karajan.lib.New.function(New.java:88)
> The source, data and out/log files are attached.
> This code seemed to work circa 8/1 with 0.2 (or with a patch that Ben
> made to 0.2 around that date).
> I will continue to fiddle with it and try simpler code using 1730 but
> I'd appreciate it Ben and/or Mihael if you could investigate.
> Thanks,
> - Mike
More information about the Swift-user
