[Swift-devel] user guide work
Lorenzo Pesce lpesce at uchicago.edu
Tue May 19 09:25:44 CDT 2015
I will throw in my useless 2 cents. I have been part of five or six swift based projects
all involving what I would call large computations (at least a million core hours, usually tens of terabytes of data).
In my experience:
1) The basic variables are all we ever needed.
2) The basic control loops is all we ever needed even if some more complex ones could have been handy (they just weren’t there when I started).
3) All the file system trickeries known to the devil and his friends are absolutely necessary. I never found a project that didn’t end up chocking on its data.
4) All the tricks for dealing intelligently with staging of data and code and “offloading” control are essential to avoid the hatred of the system administrators and other users.
5) A very clear understanding of where Swift is robust and where it isn’t are very important because nobody likes to have a 300 node run come crashing down on you creating an infestation of zombies that eventually might have forced Beagle’s admin to reboot. This is not criticism, I participated heavily in writing that script, so I am on the accused team.
I can try to be more helpful, if you want me to.
I have worked on a number of parallel projects, where essentially the same workflow was implemented with and without swift and both teams played to win. That is one paper I plan to write some day…
> On May 18, 2015, at 3:27 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> I think a little bit of both.  A brief overview of important things
> with examples in chapter 1. Then, topics like "Task Parallel
> Computing" or "Many Task Computing" may cover foreach, futures and
> task parallelism as implemented in Swift. Then, a chapter like "File
> I/O" may cover the mappers, etc. Then a topic like operators and
> variables may bring in more of the language reference in that
> describing types, structs, etc. Next may be builtin functions.
> Followed by a chapter on Compute sites which covers Resource and data
> managers, remote access and providers and such.
> So, to elaborate here is a rough outline I have in mind:
> Chap 1. Swift Overview
> -- Importance of Swift
> -- Swift example 1
>   -- hello world, description, concept show in this example
> -- Swift example 2
>   -- Run an app functions, describe importance of app functions
> -- Swift example 3
>   -- Do file mappings, describe mappers
> -- Swift example 4
>  -- Do foreach loop, describe foreach
> -- Swift example 5 (if needed)
> Chap 2. Many Task Computing in Swift
> -- Parallelism in DAGs
> -- Futures
> -- foreach loop and variants
> -- iterate
> Chap 3. File I/O
> -- File types
> -- Simple file def
> -- Complex Mappers
> -- Read and Write to Files
> Chap 4. Variables and Operators
> -- types
> -- structs
> -- import
> Chap 5. User defined and Builtin functions
> -- string
> -- numerical
> -- stat
> -- math
> Chap 6. Swift providers
> -- Coasters
> -- Data providers
> -- Compute Providers
> Chap 6. Remote compute sites
> -- Modes of running
> Appendix A. Swift Grammar in BNF
> Appendix B. A table of Swift conf options
> Appendix C. Swift cheatsheet
> On Mon, May 18, 2015 at 2:20 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> On Mon, 2015-05-18 at 13:27 -0500, Ketan Maheshwari wrote:
>>> I think Swift is a special purpose language where ~20% of features are
>>> used for ~80% of cases. Consequently, providing a K&R style language
>>> manual might not be the most valuable thing for a user to read. It
>>> also runs a risk of coming across as a general purpose language which
>>> may mislead readers.
>>> I think, a document structure where the important features (app and
>>> builtin functions, variables and mappers (with examples)) are
>>> highlighted in the early parts and details such as variable scope,
>>> expressions, operators etc. are described in the middle and concluded
>>> with sites specific details might serve well.
>> You mean like a brief overview of important things / tutorial in the
>> beginning?
>> Or do you mean that the language reference should not have a bottom-up
>> structure, starting with the simple/primary concepts and building up
>> from that?
>> Mihael
>>> Ketan
>>> On Sat, May 16, 2015 at 4:04 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>>> Hi,
>>>> Mike pointed out that I should probably post a link to what I'm trying
>>>> to do with the user guide just in case things are going awfully wrong.
>>>> So here it is:
>>>> http://www.mcs.anl.gov/~hategan/ug/ug/ug.html
>>>> Mike mention K&R a number of times and I think I like that general idea.
>>>> The above, so far, is a mix between K&R Chapter 2 and Appendix A.
>>>> The main idea is to keep things concise by separating parallelism
>>>> behaviour from what a program actually does. In that sense, one would
>>>> first describe the language, and then go into the details of how a
>>>> particular implementation goes about running programs.
>>>> I'm not particularly opposed to starting with a brief tutorial in the
>>>> spirit of K&R Chapter 1.
>>>> Mihael
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
