[Swift-devel] exec not in path despite providing absolute path
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat May 16 16:11:34 CDT 2015
The magic of hidden includes.
You are not actually using the site you defined. You probably want to
say
sites: [localhost]
at some point in that config file.
What's happening is that "site: [local]" from etc/swift.conf is used,
and that does not contain your app.
Mihael
On Fri, 2015-05-15 at 11:56 -0500, Ketan Maheshwari wrote:
> Hi,
> I am providing absolute path to an executable but Swift is complaining
> that it is not in path. Here is the error message:
> $ swift -config local.conf nek.swift
> Swift trunk git-rev: 86de22e2841518dbf337a0e0da56ad1dd9dd70f8 heads/master 6343
> RunID: run004
> Progress: Fri, 15 May 2015 11:51:55-0500
> Execution failed:
> Exception in genrun:
>     Arguments: [-d, LST.json, -u, LST_f90.tusr, --makenek,
> ~/maxhutch/nek/makenek, RTI_LST]
>     Host: local
>     Directory: nek-run004/jobs/g/genrun-aj3y9t8m
> exception @ swift-int.k, line: 467
> swiftStaging:execute2 @ swift.k, line: 139
> executeSelect @ swift.k, line: 207
> Caused by: Cannot find executable genrun on site system path
> throw @ swift-int.k, line: 78
> checkJobStatus @ swift-int.k, line: 406
> k:assign @ swift.k, line: 174
> swift:execute @ nek, line: 46
> app_genrun @ nek, line: 46
> Here is the config:
> $ cat local.conf
> site.localhost {
>     execution {
>         type: "local"
>         URL: "localhost"
>     filesystem {
>         type: "local"
>         URL: "localhost"
>     workDirectory: "/tmp/swift.workdir"
>     app.cat {
>         executable: "/bin/cat"
>     app.genrun {
>         executable: "/home/ketan/maxhutch/nek-tools/genrun/genrun.py"
> lazyErrors: false
> executionRetries: 0
> keepSiteDir: true
> providerStagingPinSwiftFiles: false
> alwaysTransferWrapperLog: true
> The log dir is attached.
> Any suggestions?
> Thanks,
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
