[Swift-devel] swift write once array/struct
Ketan Maheshwari
ketan at mcs.anl.gov
Sat Mar 21 14:16:16 CDT 2015
Thanks Mihael, that clarifies it.
Tim, I was thinking from the point of view of avoiding deadlocks. I
understand the semantics would remain same. I was thinking a self contained
array/struct in terms of state management (may be it is called actor based
impl, not sure) would be more robust in terms of avoiding deadlocks.
Ketan
On Sat, Mar 21, 2015 at 12:28 PM, Hategan-Marandiuc, Philip M. <
hategan at mcs.anl.gov> wrote:
> On Sat, 2015-03-21 at 10:38 -0500, Ketan Maheshwari wrote:
> > Hi Tim,
> > Thanks for the clarification and code snippet. To clarify, in my
> > understanding, the implementation is 'extrinsic'.
> > To be intrinsic, I imagined the array is implemented as an object which
> has
> > a function that monitors and controls its write-once property and gets
> > invoked every time anything is written to any element of the array.
> The array is implemented as you describe above. I'm not really sure what
> extrinsic would be.
> Calls to an object's methods aren't automatically synchronized or
> atomic, so I don't think that assumption in your earlier email is
> correct.
> Even if they were, having this particular method atomic does not
> guarantee that there would be no deadlocks. A user can write a[0] =
> f(a[1]); a[1] = f(a[0]);
> Mihael
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150321/4ead74ae/attachment.html>
