[Swift-devel] trunk-cobalt block task ended prematurely
    Ketan Maheshwari
    ketan at mcs.anl.gov
    Wed Mar  4 15:43:38 CST 2015
Sorry, I realized your question now. I have copied the whole if ... fi
block (including genScripts) from _swiftwrap to _swiftwrap.staging to see
what happens. Will keep you posted. --Ketan
On Wed, Mar 4, 2015 at 3:37 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Right. However, you mentioned before that it works fine when you switch
> staging from "direct" to "swift". That causes swift to use the plain
> _swiftwrap, which pretty much has the same code:
> if [ "$STDIN" == "" ]; then
>         if [ "$SWIFT_GEN_SCRIPTS" != "" ]; then
>                 genScripts
>         fi
>             if [ -n "$TIMECMD" ] && [ -n "$TIMEARGS" ]; then
>                "$TIMECMD" "${TIMEARGS[@]}" "$EXEC" "${CMDARGS[@]}"
> 1>"$STDOUT" 2>"$STDERR"
>             else
>                "$EXEC" "${CMDARGS[@]}" 1>"$STDOUT" 2>"$STDERR"
>             fi
> else
> So that's what's puzzling to me.
> Can you try changing this line in _swiftwrap.staging:
> to
> "$EXEC" "${CMDARGS[@]}" 1>"$STDOUT" 2>"$STDERR" </dev/null
> and then remove stdin= from the app in the swift script and seeing if
> that works?
> While it seems like a wise choice to do this in general, I'm trying to
> see if this fixes this particular issue.
> Mihael
> On Wed, 2015-03-04 at 15:22 -0600, Ketan Maheshwari wrote:
> > Hi Mihael,
> > The code in _swiftwrap.staging branches based on if STDIN is present or
> > not. See the snippet below:
> >         echo "#!/bin/bash" > run.sh
> >         echo "\"$EXEC\" \"${CMDARGS[@]}\" 1>\"$STDOUT\" 2>\"$STDERR\"" >>
> > run.sh
> >         chmod +x run.sh
> >     fi
> > else
> > <\"$STDIN\"" >> run.sh
> >         chmod +x run.sh
> >     fi
> >     "$EXEC" "${CMDARGS[@]}" 1>"$STDOUT" 2>"$STDERR" <"$STDIN"
> > fi
> > When "stdin=" is not provided the code takes the first branch and hangs.
> It
> > works otherwise.
> > It is possible that it hangs because if mpich bug Mike mentioned.
> > I agree we should stick in a </dev/null in there.
> > --Ketan
> > On Wed, Mar 4, 2015 at 3:12 PM, Hategan-Marandiuc, Philip M. <
> > > I'm still confused. I don't see any difference in stdin handling
> between
> > > _swiftwrap and _swiftwrap.staging (which is used for direct staging).
> > > Maybe we should always feed the app a /dev/null if there is no stdin=
> > > specified.
> > > Mihael
> > > On Wed, 2015-03-04 at 08:50 -0600, Ketan Maheshwari wrote:
> > > > I added stdin="/dev/null" to app invocation line and it has worked
> now.
> > > > --Ketan
> > > > On Wed, Mar 4, 2015 at 8:44 AM, Ketan Maheshwari <ketan at mcs.anl.gov>
> > > wrote:
> > > > > Please find one with 59 minutes attached. --Ketan
> > > > > On Tue, Mar 3, 2015 at 11:17 PM, Mihael Hategan <
> > > > > wrote:
> > > > >> You are using coasters, so what gets queued is the block, not the
> job.
> > > > >> You should specify execution.options.maxJobTime = "00:59:00".
> > > > >> Then you can probably do a walltime of about "00:50:00". But 7
> minutes
> > > > >> vs. 5 minutes isn't much of a difference.
> > > > >> Mihael
> > > > >> On Tue, 2015-03-03 at 22:28 -0600, Ketan Maheshwari wrote:
> > > > >> > Attached is a log for maxWalltime set to 7 minutes beyond which
> the
> > > job
> > > > >> > does not get submitted because of the 1 hour walltime limit of
> > > Cetus.
> > > > >> > --Ketan
> > > > >> > On Tue, Mar 3, 2015 at 10:15 PM, Ketan Maheshwari <
> > > > >> wrote:
> > > > >> > > When I check queue with qstat, I see the job is submitted for
> 40
> > > > >> minutes.
> > > > >> > > When I try to increase maxWallTime the workflow does not get
> > > submitted
> > > > >> > > because on Cetus maximum allowed walltime is 60 minutes.
> --Ketan
> > > > >> > > On Tue, Mar 3, 2015 at 10:03 PM, Hategan-Marandiuc, Philip M.
> > > > >> > >> Hi,
> > > > >> > >> Looks like almost exactly 5 minutes to me:
> > > > >> > >> 2015-03-04 01:45:43,943+0000 INFO  Execute TASK_STATUS_CHANGE
> > > > >> > >> taskid=urn:R-3-0-2-1425432781969 status=2
> > > > >> > >> workerid=0304-3301040-000000:000000
> > > > >> > >> 2015-03-04 01:50:44,676+0000 INFO  Execute TASK_STATUS_CHANGE
> > > > >> > >> taskid=urn:R-3-0-2-1425432781969 status=5 Walltime exceeded
> > > > >> > >> Which is what the config file is asking for:
> > > > >> > >> app.bgsh {
> > > > >> > >>   env.SUBBLOCK_SIZE: "16"                                 #
> [R]
> > > line
> > > > >> 27
> > > > >> > >>   executable: "/home/ketan/SwiftApps/subjobs/bg.sh"       #
> [R]
> > > line
> > > > >> 25
> > > > >> > >>   maxWallTime: "00:05:00"                                 #
> [R]
> > > line
> > > > >> 26
> > > > >> > >> Again, the wrapper log shows the app as still running. Last
> line
> > > is:
> > > > >> > >> Progress  2015-03-04 01:45:43.971393118+0000  EXECUTE
> > > > >> > >> Please do me a favor and increase the walltime to one hour
> and
> > > let's
> > > > >> see
> > > > >> > >> what happens then.
> > > > >> > >> If it still doesn't finish after one hour, we could try to
> > > strace it
> > > > >> and
> > > > >> > >> see what is happening there.
> > > > >> > >> Mihael
> > > > >> > >> On Tue, 2015-03-03 at 19:53 -0600, Ketan Maheshwari wrote:
> > > > >> > >> > Please find the log attached. --Ketan
> > > > >> > >> > On Tue, Mar 3, 2015 at 7:03 PM, Hategan-Marandiuc, Philip
> M. <
> > > > >> > >> > > On Tue, 2015-03-03 at 15:42 -0600, Ketan Maheshwari
> wrote:
> > > > >> > >> > > > Slow network looks unlikely to be a cause:
> > > > >> > >> > > It's the only variable obvious, so I wouldn't say that.
> > > > >> > >> I meant "only obvious variable" there.
> > > > >> _______________________________________________
> > > > >> Swift-devel mailing list
> > > > >> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150304/8ab348e8/attachment.html>
