[Swift-devel] trunk-cobalt block task ended prematurely
Ketan Maheshwari
ketan at mcs.anl.gov
Tue Mar 3 22:28:53 CST 2015
Attached is a log for maxWalltime set to 7 minutes beyond which the job
does not get submitted because of the 1 hour walltime limit of Cetus.
--Ketan
On Tue, Mar 3, 2015 at 10:15 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> When I check queue with qstat, I see the job is submitted for 40 minutes.
> When I try to increase maxWallTime the workflow does not get submitted
> because on Cetus maximum allowed walltime is 60 minutes. --Ketan
> On Tue, Mar 3, 2015 at 10:03 PM, Hategan-Marandiuc, Philip M. <
> hategan at mcs.anl.gov> wrote:
>> Hi,
>> Looks like almost exactly 5 minutes to me:
>> 2015-03-04 01:45:43,943+0000 INFO Execute TASK_STATUS_CHANGE
>> taskid=urn:R-3-0-2-1425432781969 status=2
>> workerid=0304-3301040-000000:000000
>> 2015-03-04 01:50:44,676+0000 INFO Execute TASK_STATUS_CHANGE
>> taskid=urn:R-3-0-2-1425432781969 status=5 Walltime exceeded
>> Which is what the config file is asking for:
>> app.bgsh {
>> env.SUBBLOCK_SIZE: "16" # [R] line 27
>> executable: "/home/ketan/SwiftApps/subjobs/bg.sh" # [R] line 25
>> maxWallTime: "00:05:00" # [R] line 26
>> Again, the wrapper log shows the app as still running. Last line is:
>> Progress 2015-03-04 01:45:43.971393118+0000 EXECUTE
>> Please do me a favor and increase the walltime to one hour and let's see
>> what happens then.
>> If it still doesn't finish after one hour, we could try to strace it and
>> see what is happening there.
>> Mihael
>> On Tue, 2015-03-03 at 19:53 -0600, Ketan Maheshwari wrote:
>> > Please find the log attached. --Ketan
>> > On Tue, Mar 3, 2015 at 7:03 PM, Hategan-Marandiuc, Philip M. <
>> > > On Tue, 2015-03-03 at 15:42 -0600, Ketan Maheshwari wrote:
>> > > > Slow network looks unlikely to be a cause:
>> > > It's the only variable obvious, so I wouldn't say that.
>> I meant "only obvious variable" there.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150303/f1de07f0/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150303/f1de07f0/attachment.bin>
