[Swift-devel] trunk-cobalt block task ended prematurely
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Mar  3 14:51:39 CST 2015
With direct "staging" and a slow network FS, the application run time
will go up. This is why in many cases "avoid NFS/gpfs" is a good
strategy.
What happens if you increase the walltime for your jobs?
Mihael
On Tue, 2015-03-03 at 14:01 -0600, Ketan Maheshwari wrote:
> Hi,
> Continuing the discussion on devel. It seems that the run worked after I
> changed the staging method from "direct" to "swift".
> I am trying to narrow down the cause why "direct" staging does not work.
> Any pointers to possible causes will help.
> Thanks,
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
