[Swift-devel] Mailing lists, documentation update, etc.
Michael Wilde wilde at anl.gov
Mon Jun 29 23:16:59 CDT 2015
This may be a good time to make the lists appear to be hosted at
swift-lang.org.
It would also be good to move the list archives to that domain. We
should see if that is possible, an dhow forwarding would work.
- Mike
On 6/29/15 8:57 PM, Mihael Hategan wrote:
> Right. I missed it at first. I'm guessing that means that we can keep
> the @ci, so the only question is where it's hosted.
> Mihael
> On Mon, 2015-06-29 at 20:42 -0500, Foster, Ian T. wrote:
>> The original email said this about options:
>> If you want to retain and move the list, your best option is to create
>> a new
>> list on the service of your choice (for example, ITS provides mailing
>> lists at
>> https://itservices.uchicago.edu/services/mailing-lists).
>> Once you've got your new list configured and ready, if you'd like we
>> can point
>> the existing listname to that new address.  Or you can
>> simply switch to using the new address, whatever that may be.
>>> On Jun 29, 2015, at 7:17 PM, Mihael Hategan <hategan at mcs.anl.gov>
>>> wrote:
>>> Looks pretty good to me. Just two questions: is that OK with MCS
>>> folk,
>>> and is that OK with the CI (Ian?)?
>>> Mihael
>>> On Mon, 2015-06-29 at 18:28 -0500, Ketan Maheshwari wrote:
>>>> About mailing lists: can we move them to MCS mailing list?
>>>> Ketan
>>>> On Mon, Jun 29, 2015 at 3:57 PM, Mihael Hategan
>>>> <hategan at mcs.anl.gov> wrote:
>>>>> Hi,
>>>>> I believe that there are a few issues that need some attention.
>>>>> The first one is the email from systems that our mailing lists
>>>>> are going
>>>>> to be retired. While I don't think that is a good idea, since
>>>>> those
>>>>> lists provide both branding for the CI as well as a
>>>>> convenient/painless
>>>>> setup for CI projects, it is probably happening for a good
>>>>> reason.
>>>>> So, we need to find a new place to host our mailing lists and
>>>>> then save
>>>>> our archives and transition to the new lists. Ideas welcome.
>>>>> Second is documentation. I'm still writing, but it is now more
>>>>> than just
>>>>> the skeleton that it was. You can see a snapshot here:
>>>>> http://www.mcs.anl.gov/~hategan/docs/trunk/ug/ug.html
>>>>> I welcome feedback on the overall structure and organization at
>>>>> this
>>>>> point. Also, if you want to contribute a section that is
>>>>> missing, or
>>>>> find certain sections to be unpalatable, let's discuss. Please
>>>>> don't
>>>>> bother noticing small things, such as broken links. Almost all
>>>>> links are
>>>>> broken because I just put placeholders there. They will be fixed
>>>>> systematically once the text is written.
>>>>> Finally, while writing docs I had the chance (or the mental
>>>>> discomfort)
>>>>> of trying to explain why certain things just don't make much
>>>>> sense. For
>>>>> example, we say that variables are single assignment, but
>>>>> defining what
>>>>> exactly an assignment is can be messy. If you have some file
>>>>> input, you
>>>>> don't really assign to the corresponding variable. In fact, the
>>>>> fact
>>>>> that you don't make any explicit assignments is what makes the
>>>>> variable
>>>>> an input variable which in turns makes it assigned though the
>>>>> mapping
>>>>> declaration. This kind of Catch-22 design bothers me.
>>>>> Swift/T deals with the issue in a nice way (as far as I
>>>>> understand).
>>>>> Inputs are always assigned through a file() constructor. This is
>>>>> more
>>>>> elegant, at least for inputs. We should probably do the same:
>>>>> provide
>>>>> file(), <T> T glob(), etc, and restrict the traditional mappers
>>>>> to
>>>>> outputs. Mike will probably like the unifying idea. Anyway, I'll
>>>>> try to
>>>>> write these things down once I'm done with #2 and we can discuss
>>>>> them.
>>>>> Mihael
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
