[Swift-devel] trying v2 stdlib
Ketan Maheshwari
ketan at mcs.anl.gov
Mon Jun 8 13:34:52 CDT 2015
Trying this. Could it be the case that importing the stdlib.v2
suppresses the other functions:
$ swift const.swift
Swift trunk git-rev: f1abaa217c4e7c4b18b39e2323c572d9e0abc6d8 heads/master 6370
RunID: run007
Could not start execution:
Compile error in procedure invocation at 6:
No function or procedure 'tracef' found
tracef() works when I remove the import line.
Here is my test script:
import "stdlib.v2";
//float PI=3.14159;
//float E=2.71828;
tracef("%f, %f\n" , PI,E);
Ketan
On Fri, Jun 5, 2015 at 2:29 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Hi,
> Mike asked about how one can try the v2 library, so here it is:
> 1. use trunk
> 2. see https://github.com/swift-lang/swift-k/wiki/StandardLibrary for
> some documentation. The koala is the sign that a function is implemented
> in /K.
> 3. use
> import "stdlib.v2";
> in the beginning of your script.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
