[Swift-devel] Reconsidering function overloading
    Michael Wilde
    wilde at anl.gov
    Wed Jan 28 09:14:59 CST 2015
Based on your point here and earlier, Tim, I agree with going with
option #1. So count this as a +1 for that.
Function references give us something we can not otherwise do, while
overloaded functions is just a convenience (which not everyone will like).
How does this apply to intrinsic functions in the library, though, eg,
strcat( ) which you could view as an overloaded function?
Can we address this more cleanly by introducing a type "var"? (I can't
recall where we left prior discussion on that issue).  Also, are we
dipping into the tangentially related issue of var-args (varying number
of args) here?
- Mike
ps. I prefer the approach of "simple and consistent but powerful set of
core rules that are orthogonal and compose well together" in the C,
Haskell, Python vein.
On 1/28/15 9:01 AM, Tim Armstrong wrote:
> Mike - that's technically possible to implement but I don't see the
> cost/benefit stacking up that well - I think any new syntactic
> constructs come with a non-neglible implementation/documentation/user
> attention cost that can quickly accumulate if we're not selective
> about what we put into the language (see C++).  Tangentially, that
> particular syntax is difficult to parse unambiguously - you could be
> trying to index a variable called int and pass it into max.
> The problem I see with #3 is that we're allowing overloaded functions
> so that the standard library seems slightly neater/more friendly.  If
> that results in a bunch of exceptions where users can't do something
> that "ought to" work - composing two standard library functions
> reduce/max, I just don't see enough of a net benefit (if any) to the
> programmer experience to justify the implementation burden.
> This of course is somewhat subjective - I tend to like languages where
> there is a simple and consistent but powerful set of core rules that
> are orthogonal and compose well together - you can learn the basic
> rules and don't have to worry about many exceptions.  Other language
> designs will special-case common constructs so that use-cases that the
> language designer expects to be common will be shorter or "cuter", or
> add features that don't compose well with other features and come with
> caveats/exceptions.  I think C, Haskell and Python are examples of the
> former, and Perl, R and C++ are examples of the latter.  I'm not sure
> which camp we see ourselves in.
> I haven't found complete documentation on Apple Swift's type
> inference, but it doesn't seem like it does anything very
> sophisticated - Swift/T already does similar local type inference.
> - Tim
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150128/650362ed/attachment.html>
