[Swift-devel] Sporadic connection handler messages in 0.95RC7
    Michael Wilde
    wilde at anl.gov
    Tue Jan 20 09:00:54 CST 2015
Mihael, All,
Im getting a sporadic "Could not start connection handler" message
followed by a tracback starting at gssap code (see below) at the start
of some test runs from bridled to beagle using 0.95RC7, coasters, ssh-cl
and provider staging.  The message seems to occur on less than half of
my tests and whatever is causing them doesnt seem to be impacting the run.
I intend to upgrade this script to trunk/0.96 as soon as time permits,
but in the meantime, if you know the cause of this, it would great of I
could fix it.  If not, its very low priority and not at the moment worth
much of your time (unless it recurs on 0.96 and/or causes failures).
The runs are on bridled at /scratch/local/wilde/epsweep.
- Mike
Swift 0.95 RC7
RunID: run011
Warning: The @ syntax for function invocation is deprecated
Progress: Tue, 20 Jan 2015 00:11:30-0600
5 Runs in Simulation
ep+12+31+90+72+72+3.85+113+70
ep+12+31+180+72+72+3.85+113+70
ep+12+31+135+72+72+3.85+113+70
ep+12+31+45+72+72+3.85+113+70
ep+12+31+0+72+72+3.85+113+70
Progress: Tue, 20 Jan 2015 00:11:31-0600  Submitting:5
java.io.EOFException
     at
org.globus.gsi.gssapi.net.impl.GSIGssInputStream.readHandshakeToken(GSIGssInputStream.java:61)
     at
org.globus.gsi.gssapi.net.impl.GSIGssSocket.readToken(GSIGssSocket.java:65)
     at
org.globus.gsi.gssapi.net.GssSocket.authenticateServer(GssSocket.java:127)
     at
org.globus.gsi.gssapi.net.GssSocket.startHandshake(GssSocket.java:147)
     at
org.globus.gsi.gssapi.net.GssSocket.getInputStream(GssSocket.java:177)
     at
org.globus.cog.coaster.channels.AbstractTCPChannel.setSocket(AbstractTCPChannel.java:47)
     at
org.globus.cog.coaster.channels.GSSChannel.<init>(GSSChannel.java:46)
     at
org.globus.cog.coaster.ConnectionHandler.<init>(ConnectionHandler.java:42)
     at
org.globus.cog.abstraction.coaster.service.local.LocalService.handleConnection(LocalService.java:71)
     at org.globus.net.BaseServer.run(BaseServer.java:247)
     at java.lang.Thread.run(Thread.java:722)
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
