[Swift-devel] forcing service and local ports in automatic coasters
Mihael Hategan hategan at mcs.anl.gov
Tue Apr 28 14:48:27 CDT 2015
On Tue, 2015-04-28 at 12:56 -0500, Ketan Maheshwari wrote:
> On Tue, Apr 28, 2015 at 12:45 PM, Yadu Nand Babuji <yadunand at uchicago.edu>
> wrote:
> > Hi Mihael,
> > Ketan and I discussed the setup over voice, and here's what he ended up
> > using:
> > Swift client runs on  Cetus, while there is an persistent
> > coaster-service in active mode
> > on Tukey. A tunnel from Tukey connects the serviceports. Ssh from Cetus
> > to Tukey is
> > limited by a cryptocard, so ssh-cl:cobalt with coasters wasn't working
> > cleanly.
> Earlier, I tried setting up ssh multiplexed master channel to circumvent
> the cryptocard (verified this with ssh and scp). ssh-cl:cobalt still did
> not work. The error message was:
> java.io.IOException: Failed to run ssh: zsh:1: no matches found:
> /home/ketan/.globus/ssh*-*-*.
I would worry about some script in your environment or ssh
configuration. I can see no good reason why zsh should come into the
picture.
Mihael
