[Swift-devel] assertEqual
Tim Armstrong
tim.g.armstrong at gmail.com
Wed Apr 8 13:57:25 CDT 2015
So assertEqual(float, float, string, float tolerance=0.0) ?
On 8 April 2015 at 13:08, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> I went with an optional. It keeps backwards compatibility and makes it
> clear what that number is.
> Mihael
> On Wed, 2015-04-08 at 11:48 -0500, Tim Armstrong wrote:
> > Reviving this thread... Probably the options are to either add an
> overload:
> > assertEqual(float v1, float v2, float tolerance, string msg)
> > or something like
> > assertAlmostEqual(float v1, float v2, float tolerance, string msg)
> > assertApproxEqual(float v1, float v2, float tolerance, string msg)
> > assertApprox(float v1, float v2, float tolerance, string msg)
> > I don't think there's much of a reason to break compatibility in Swift/T
> > with the (float, float, string) form, so I think we should keep that in.
> > - Tim
> > On 6 April 2015 at 12:14, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > > On Mon, 2015-04-06 at 09:38 -0500, Tim Armstrong wrote:
> > > > Right, the tests for those things in the Swift test suite are like:
> > > > assert(abs(sin(PI/2) - 1.0) < 1e-15, "sin");
> > > > Which is a little less convenient.
> > > > I think if we want almost equal semantics we could have
> assertAlmostEqual
> > > > with a tolerance parameter
> > > That's a choice.
> > > I personally think that approximate equality in numerics is such a
> > > widespread issue, that there wouldn't be much confusion.
> > > Mihael
> > > > -Tim
> > > > On 5 April 2015 at 21:17, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> > > > > Hi,
> > > > > I found it useful to have a tolerance parameter for
> assertEqual(float,
> > > > > float).
> > > > > Checks like assertEqual(tan(x), sin(x) / cos(x)) are otherwise not
> > > going
> > > > > to work very well.
> > > > > Mihael
> > > > > _______________________________________________
> > > > > Swift-devel mailing list
> > > > > Swift-devel at ci.uchicago.edu
> > > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150408/7d4965c8/attachment.html>
