[Swift-devel] assertEqual
Tim Armstrong tim.g.armstrong at gmail.com
Wed Apr 8 11:48:25 CDT 2015
Reviving this thread...  Probably the options are to either add an overload:
assertEqual(float v1, float v2, float tolerance, string msg)
or something like
assertAlmostEqual(float v1, float v2, float tolerance, string msg)
assertApproxEqual(float v1, float v2, float tolerance, string msg)
assertApprox(float v1, float v2, float tolerance, string msg)
I don't think there's much of a reason to break compatibility in Swift/T
with the (float, float, string) form, so I think we should keep that in.
- Tim
On 6 April 2015 at 12:14, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Mon, 2015-04-06 at 09:38 -0500, Tim Armstrong wrote:
> > Right, the tests for those things in the Swift test suite are like:
> > assert(abs(sin(PI/2) - 1.0) < 1e-15, "sin");
> > Which is a little less convenient.
> > I think if we want almost equal semantics we could have assertAlmostEqual
> > with a tolerance parameter
> That's a choice.
> I personally think that approximate equality in numerics is such a
> widespread issue, that there wouldn't be much confusion.
> Mihael
> > -Tim
> > On 5 April 2015 at 21:17, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > > Hi,
> > > I found it useful to have a tolerance parameter for assertEqual(float,
> > > float).
> > > Checks like assertEqual(tan(x), sin(x) / cos(x)) are otherwise not
> going
> > > to work very well.
> > > Mihael
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150408/d797b22c/attachment.html>
