[Swift-devel] Coaster Task Submission Stalling
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Sep 16 15:09:49 CDT 2014
Ok, I see this in coaster-start-service.log:
Running /home/tim/ExM/swift-k.git/dist/swift-svn/bin/worker.pl
http://127.0.0.1:60566 LOCAL
Not given: LOGDIR
Looks like that script hasn't been updated in a while. Things probably
worked for you before because it wasn't running jobs through workers.
I'll try to see what's happening with that.
However, and correct me if I'm wrong, I don't see much benefit in this
particular case for managing workers through a shell script rather than
letting the service do the work. So as far as C client testing goes you
could just use -shared.
You can, of course, start worker.pl manually until this gets sorted out.
Mihael
On Tue, 2014-09-16 at 13:02 -0700, Mihael Hategan wrote:
> I take it all back.
> It looks like submitting jobs to a passive service with empty settings
> should work.
> What I do not see in your log is any workers being actually started. How
> are you starting the workers?
> Mihael
> On Tue, 2014-09-16 at 11:32 -0700, Mihael Hategan wrote:
> > On Tue, 2014-09-16 at 09:52 -0500, Tim Armstrong wrote:
> > > Would the "local" setting be in the -shared config file?
> > Shared and passive should be mutually exclusive, although I don't think
> > the code enforces that. I'll make sure it would.
> > But hang on. The whole thing makes no sense. So let me get back to you
> > on it.
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
