[Swift-devel] Coaster Task Submission Stalling
Tim Armstrong
tim.g.armstrong at gmail.com
Thu Sep 11 12:16:30 CDT 2014
I'm seeing failures when running Swift/T tests with
start-coaster-service.sh.
E.g. the turbine test coaster-exec-1. I can provide instructions for
running the test if needed (roughly, you need to build Swift/T with coaster
support enabled, then make tests/coaster-exec-1.result in the turbine
directory). The github swift-t release is up to date if you want to use
that.
Full log is attached, stack trace excerpt is below.
- Tim
2014-09-11 12:11:13,708-0500 INFO BlockQueueProcessor Starting...
id=0911-1112130
Using threaded sender for TCPChannel [type: server, contact: 127.0.0.1:48242
2014-09-11 12:11:13,708-0500 INFO AbstractStreamCoasterChannel Using
threaded sender for TCPChannel [type: server, contact: 127.0.0.1:48242]
org.globus.cog.coaster.channels.ChannelException: Invalid channel: null
@id://null-nullS
at
org.globus.cog.coaster.channels.ChannelManager.getMetaChannel(ChannelManager.java:452)
at
org.globus.cog.coaster.channels.ChannelManager.reserveChannel(ChannelManager.java:226)
at
org.globus.cog.abstraction.coaster.service.job.manager.PassiveQueueProcessor.setClientChannelContext(PassiveQueueProcessor.java:41)
at
org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.setClientChannelContext(JobQueue.java:135)
at
org.globus.cog.abstraction.coaster.service.SubmitJobHandler.requestComplete(SubmitJobHandler.java:77)
at
org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
at
org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
at
org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:173)
at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
provider=local
2014-09-11 12:11:13,930-0500 INFO ExecutionTaskHandler provider=local
@id://null-nullS
at
at
org.globus.cog.coaster.channels.ChannelManager.getMetaChannel(ChannelManager.java:432)
at
org.globus.cog.coaster.channels.ChannelManager.reserveLongTerm(ChannelManager.java:472)
at
org.globus.cog.abstraction.coaster.service.SubmitJobHandler.requestComplete(SubmitJobHandler.java:80)
at
at
at
Handler(tag: 38907, SUBMITJOB) sending error: Could not deserialize job
description
org.globus.cog.coaster.ProtocolException: Could not deserialize job
description
at
org.globus.cog.abstraction.coaster.service.SubmitJobHandler.requestComplete(SubmitJobHandler.java:84)
at
at
at
Caused by: org.globus.cog.coaster.channels.ChannelException: Invalid
channel: null at id://null-nullS
at
at
at
at
... 4 more
2014-09-11 12:11:13,937-0500 INFO RequestReply Handler(tag: 38907,
SUBMITJOB) sending error: Could not deserialize job description
description
at
at
at
at
at
at
at
at
... 4 more
On Thu, Sep 11, 2014 at 10:30 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
wrote:
> This all sounds great.
> Just to check that I've understood correctly, from the client's point of
> view:
> * The per-client settings behave the same if -shared is not provided.
> * Per-client settings are ignored if -shared is provided
> I had one question:
> * Do automatically allocated workers work with per-client settings? I
> understand there were some issues related to sharing workers between
> clients. Was the solution to have separate worker pools, or is this just
> not supported?
> - Tim
> On Mon, Sep 8, 2014 at 2:38 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>> So...
>> There were bugs. Lots of bugs.
>> I did some work over the weekend to fix some of these and clean up the
>> coaster code. Here's a summary:
>> - there was some stuff in the low level coaster code to deal with
>> persisting coaster channels over multiple connections with various
>> options, like periodic connections, client or server initiated
>> connections, buffering of commands, etc. None of this was used by Swift,
>> and the code was pretty messy. I removed that.
>> - there were some issues with multiple clients:
>> * improper shutdown of relevant workers when a client disconnected
>> * the worker task dispatcher was a singleton and had a reference to
>> one block allocator, whereas multiple clients involved multiple
>> allocators.
>> - there were a bunch of locking issues in the C client that valgrind
>> caught
>> - the idea of remote job ids was a bit hard to work with. This remote id
>> was the job id that the service assigned to a job. This is necessary
>> because two different clients can submit jobs with the same id. The
>> remote id would be communicated to the client as the reply to the submit
>> request. However, it was entirely possible for a notification about job
>> status to be sent to the client before the submit reply was. Since
>> notifications were sent using the remote-id, the client would have no
>> idea what job the notifications belonged to. Now, the server might need
>> a unique job id, but there is no reason why it cannot use the client id
>> when communicating the status to a client. So that's there now.
>> - the way the C client was working, its jobs ended up not going to the
>> workers, but the local queue. The service settings now allow specifying
>> the provider/jobManager/url to be used to start blocks, and jobs are
>> routed appropriately if they do not have the batch job flag set.
>> I also added a shared service mode. We discussed this before. Basically
>> you start the coaster service with "-shared <service.properties>" and
>> all the settings are read from that file. In this case, all clients
>> share the same worker pool, and client settings are ignored.
>> The C client now has a multi-job testing tool which can submit many jobs
>> with the desired level of concurrency.
>> I have tested the C client with both shared and non-shared mode, with
>> various levels of jobs being sent, with either one or two concurrent
>> clients.
>> I haven't tested manual workers.
>> I've also decided that during normal operation (i.e. client connects,
>> submits jobs, shuts down gracefully), there should be no exceptions in
>> the coaster log. I think we should stick to that principle. This was the
>> case last I tested, and we should consider any deviation from that to be
>> a problem. Of course, there are some things for which there is no
>> graceful shut down, such as ctrl+C-ing a manual worker. Exceptions are
>> fine in that case.
>> So anyway, let's start from here.
>> Mihael
>> On Fri, 2014-09-05 at 13:09 -0500, Tim Armstrong wrote:
>> > Thanks, let me know if there's anything I can help do.
>> > - Tim
>> > On Fri, Sep 5, 2014 at 12:57 PM, Mihael Hategan <hategan at mcs.anl.gov>
>> wrote:
>> > > Thanks. It also seems that there is an older bug in there in which the
>> > > client connection is not properly accounted for and things start
>> failing
>> > > two minutes after the client connects (which is also probably why you
>> > > didn't see this in runs with many short client connections). I'm not
>> > > sure why the fix for that bug isn't in the trunk code.
>> > > In any event, I'll set up a client submission loop and fix all these
>> > > things.
>> > > Mihael
>> > > On Fri, 2014-09-05 at 12:13 -0500, Tim Armstrong wrote:
>> > > > Ok, here it is with the additional debug messages. Source code
>> change is
>> > > > in commit 890c41f2ba701b10264553471590096d6f94c278.
>> > > > Warning: the tarball will expand to several gigabytes of logs.
>> > > > I had to do multiple client runs to trigger it. It seems like the
>> > > problem
>> > > > might be triggered by abnormal termination of the client. First 18
>> runs
>> > > > went fine, problem only started when I ctrl-c-ed the swift/t run #19
>> > > before
>> > > > the run #20 that exhibited delays.
>> > > > http://people.cs.uchicago.edu/~tga/files/worker-logs3.tar.gz
>> > > > - Tim
>> > > > On Fri, Sep 5, 2014 at 8:55 AM, Tim Armstrong <
>> > > > wrote:
>> > > > > It's here:
>> http://people.cs.uchicago.edu/~tga/files/coaster-service.out.full.gz .
>> > > > > I'll add some extra debug messages in the coaster C++ client and
>> see
>> > > if I
>> > > > > can recreate the scenario.
>> > > > > - Tim
>> > > > > On Thu, Sep 4, 2014 at 7:27 PM, Mihael Hategan <
>> > > > > wrote:
>> > > > >> Ok, so that's legit.
>> > > > >> It does look like shut down workers are not properly accounted
>> for in
>> > > > >> some places (and I believe Yadu submitted a bug for this).
>> However, I
>> > > do
>> > > > >> not see the dead time you mention in either of the last two sets
>> of
>> > > > >> logs. It looks like each client instance submits a continous
>> stream of
>> > > > >> jobs.
>> > > > >> So let's get back to the initial log. Can I have the full
>> service log?
>> > > > >> I'm trying to track what happened with the jobs submitted before
>> the
>> > > > >> first big pause.
>> > > > >> Also, a log message in CoasterClient::updateJobStatus() (or
>> friends)
>> > > > >> would probably help a lot here.
>> > > > >> Mihael
>> > > > >> On Thu, 2014-09-04 at 15:34 -0500, Tim Armstrong wrote:
>> > > > >> > Should be here:
>> > > > >> > http://people.cs.uchicago.edu/~tga/worker-logs2.tar.gz
>> > > > >> > On Thu, Sep 4, 2014 at 3:03 PM, Mihael Hategan <
>> > > > >> wrote:
>> > > > >> > > The first worker "failing" is 0904-20022331. The log looks
>> funny
>> > > at
>> > > > >> the
>> > > > >> > > end.
>> > > > >> > > Can you git pull and re-run? The worker is getting some
>> command
>> > > at the
>> > > > >> > > end there and doing nothing about it and I wonder why.
>> > > > >> > > Mihael
>> > > > >> > > On Thu, 2014-09-04 at 14:35 -0500, Tim Armstrong wrote:
>> > > > >> > > > Ok, now I have some worker logs:
>> http://people.cs.uchicago.edu/~tga/2014-9-4-worker-logs.tar.gz
>> > > > >> > > > There's nothing obvious I see in the worker logs that would
>> > > > >> indicate why
>> > > > >> > > > the connection was broken.
>> > > > >> > > > - Tim
>> > > > >> > > > On Thu, Sep 4, 2014 at 1:11 PM, Tim Armstrong <
>> > > > >> > > > wrote:
>> > > > >> > > > > This is all running locally on my laptop, so I think we
>> can
>> > > rule
>> > > > >> out
>> > > > >> > > 1).
>> > > > >> > > > > It also seems like it's a state the coaster service gets
>> into
>> > > > >> after a
>> > > > >> > > few
>> > > > >> > > > > client sessions: generally the first coaster run works
>> fine,
>> > > then
>> > > > >> > > after a
>> > > > >> > > > > few runs the problem occurs more frequently.
>> > > > >> > > > > I'm going to try and get worker logs, in the meantime
>> i've got
>> > > > >> some
>> > > > >> > > > > jstacks (attached).
>> > > > >> > > > > Matching service logs (largish) are here if needed:
>> > > > >> > > > > http://people.cs.uchicago.edu/~tga/service.out.gz
>> > > > >> > > > > On Wed, Sep 3, 2014 at 10:35 PM, Mihael Hategan <
>> > > > >> > > > > wrote:
>> > > > >> > > > >> Ah, makes sense.
>> > > > >> > > > >> 2 minutes is the channel timeout. Each live connection
>> is
>> > > > >> guaranteed
>> > > > >> > > to
>> > > > >> > > > >> have some communication for any 2 minute time window,
>> > > partially
>> > > > >> due to
>> > > > >> > > > >> periodic heartbeats (sent every 1 minute). If no
>> packets flow
>> > > > >> for the
>> > > > >> > > > >> duration of 2 minutes, the connection is assumed broken
>> and
>> > > all
>> > > > >> jobs
>> > > > >> > > > >> that were submitted to the respective workers are
>> considered
>> > > > >> failed.
>> > > > >> > > So
>> > > > >> > > > >> there seems to be an issue with the connections to some
>> of
>> > > the
>> > > > >> > > workers,
>> > > > >> > > > >> and it takes 2 minutes to detect them.
>> > > > >> > > > >> Since the service seems to be alive (although a jstack
>> on the
>> > > > >> service
>> > > > >> > > > >> when thing seem to hang might help), this leaves two
>> > > > >> possibilities:
>> > > > >> > > > >> 1 - some genuine network problem
>> > > > >> > > > >> 2 - the worker died without properly closing TCP
>> connections
>> > > > >> > > > >> If (2), you could enable worker logging
>> > > > >> > > > >> (Settings::Key::WORKER_LOGGING_LEVEL = "DEBUG") to see
>> if
>> > > > >> anything
>> > > > >> > > shows
>> > > > >> > > > >> up.
>> > > > >> > > > >> Mihael
>> > > > >> > > > >> On Wed, 2014-09-03 at 20:26 -0500, Tim Armstrong wrote:
>> > > > >> > > > >> > Here are client and service logs, with part of
>> service log
>> > > > >> edited
>> > > > >> > > down
>> > > > >> > > > >> to
>> > > > >> > > > >> > be a reasonable size (I have the full thing if
>> needed, but
>> > > it
>> > > > >> was
>> > > > >> > > over a
>> > > > >> > > > >> > gigabyte).
>> > > > >> > > > >> > One relevant section is from 19:49:35 onwards. The
>> client
>> > > > >> submits 4
>> > > > >> > > > >> jobs
>> > > > >> > > > >> > (its limit), but they don't complete until 19:51:32
>> or so
>> > > (I
>> > > > >> can see
>> > > > >> > > > >> that
>> > > > >> > > > >> > one task completed based on ncompleted=1 in the
>> > > check_tasks log
>> > > > >> > > > >> message).
>> > > > >> > > > >> > It looks like something has happened with broken
>> pipes and
>> > > > >> workers
>> > > > >> > > being
>> > > > >> > > > >> > lost, but I'm not sure what the ultimate cause of
>> that is
>> > > > >> likely to
>> > > > >> > > be.
>> > > > >> > > > >> > - Tim
>> > > > >> > > > >> > On Wed, Sep 3, 2014 at 6:20 PM, Mihael Hategan <
>> > > > >> > > > >> wrote:
>> > > > >> > > > >> > > Hi Tim,
>> > > > >> > > > >> > > I've never seen this before with pure Java.
>> > > > >> > > > >> > > Do you have logs from these runs?
>> > > > >> > > > >> > > Mihael
>> > > > >> > > > >> > > On Wed, 2014-09-03 at 16:49 -0500, Tim Armstrong
>> wrote:
>> > > > >> > > > >> > > > I'm running a test Swift/T script that submit
>> tasks to
>> > > > >> Coasters
>> > > > >> > > > >> through
>> > > > >> > > > >> > > the
>> > > > >> > > > >> > > > C++ client and I'm seeing some odd behaviour
>> where task
>> > > > >> > > > >> > > > submission/execution is stalling for ~2 minute
>> periods.
>> > > > >> For
>> > > > >> > > > >> example, I'm
>> > > > >> > > > >> > > > seeing submit log messages like "submitting
>> > > > >> > > > >> > > > urn:133-1409778135377-1409778135378:
>> /bin/hostname" in
>> > > > >> bursts of
>> > > > >> > > > >> several
>> > > > >> > > > >> > > > seconds with a gap of roughly 2 minutes in
>> between,
>> > > e.g.
>> > > > >> I'm
>> > > > >> > > seeing
>> > > > >> > > > >> > > bursts
>> > > > >> > > > >> > > > with the following intervals in my logs.
>> > > > >> > > > >> > > > 16:07:04,603 to 16:07:10,391
>> > > > >> > > > >> > > > 16:09:07,377 to 16:09:13,076
>> > > > >> > > > >> > > > 16:11:10,005 to 16:11:16,770
>> > > > >> > > > >> > > > 16:13:13,291 to 16:13:19,296
>> > > > >> > > > >> > > > 16:15:16,000 to 16:15:21,602
>> > > > >> > > > >> > > > From what I can tell, the delay is on the coaster
>> > > service
>> > > > >> side:
>> > > > >> > > the
>> > > > >> > > > >> C
>> > > > >> > > > >> > > > client is just waiting for a response.
>> > > > >> > > > >> > > > The jobs are just being submitted through the
>> local job
>> > > > >> > > manager, so
>> > > > >> > > > >> I
>> > > > >> > > > >> > > > wouldn't expect any delays there. The tasks are
>> also
>> > > just
>> > > > >> > > > >> > > "/bin/hostname",
>> > > > >> > > > >> > > > so should return immediately.
>> > > > >> > > > >> > > > I'm going to continue digging into this on my
>> own, but
>> > > the
>> > > > >> 2
>> > > > >> > > minute
>> > > > >> > > > >> delay
>> > > > >> > > > >> > > > seems like a big clue: does anyone have an idea
>> what
>> > > could
>> > > > >> cause
>> > > > >> > > > >> stalls
>> > > > >> > > > >> > > in
>> > > > >> > > > >> > > > task submission of 2 minute duration?
>> > > > >> > > > >> > > > Cheers,
>> > > > >> > > > >> > > > Tim
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140911/7f9c01f8/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140911/7f9c01f8/attachment.bin>
