[Swift-devel] Coaster Task Submission Stalling
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Fri Sep  5 13:09:00 CDT 2014
Thanks, let me know if there's anything I can help do.
- Tim
On Fri, Sep 5, 2014 at 12:57 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Thanks. It also seems that there is an older bug in there in which the
> client connection is not properly accounted for and things start failing
> two minutes after the client connects (which is also probably why you
> didn't see this in runs with many short client connections). I'm not
> sure why the fix for that bug isn't in the trunk code.
> In any event, I'll set up a client submission loop and fix all these
> things.
> Mihael
> On Fri, 2014-09-05 at 12:13 -0500, Tim Armstrong wrote:
> > Ok, here it is with the additional debug messages.  Source code change is
> > in commit 890c41f2ba701b10264553471590096d6f94c278.
> > Warning: the tarball will expand to several gigabytes of logs.
> > I had to do multiple client runs to trigger it.  It seems like the
> problem
> > might be triggered by abnormal termination of the client.  First 18 runs
> > went fine, problem only started when I ctrl-c-ed the swift/t run #19
> before
> > the run #20 that exhibited delays.
> > http://people.cs.uchicago.edu/~tga/files/worker-logs3.tar.gz
> > - Tim
> > On Fri, Sep 5, 2014 at 8:55 AM, Tim Armstrong <tim.g.armstrong at gmail.com
> > wrote:
> > > It's here:
> > > http://people.cs.uchicago.edu/~tga/files/coaster-service.out.full.gz .
> > > I'll add some extra debug messages in the coaster C++ client and see
> if I
> > > can recreate the scenario.
> > > - Tim
> > > On Thu, Sep 4, 2014 at 7:27 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > > wrote:
> > >> Ok, so that's legit.
> > >> It does look like shut down workers are not properly accounted for in
> > >> some places (and I believe Yadu submitted a bug for this). However, I
> do
> > >> not see the dead time you mention in either of the last two sets of
> > >> logs. It looks like each client instance submits a continous stream of
> > >> jobs.
> > >> So let's get back to the initial log. Can I have the full service log?
> > >> I'm trying to track what happened with the jobs submitted before the
> > >> first big pause.
> > >> Also, a log message in CoasterClient::updateJobStatus() (or friends)
> > >> would probably help a lot here.
> > >> Mihael
> > >> On Thu, 2014-09-04 at 15:34 -0500, Tim Armstrong wrote:
> > >> > Should be here:
> > >> > http://people.cs.uchicago.edu/~tga/worker-logs2.tar.gz
> > >> > On Thu, Sep 4, 2014 at 3:03 PM, Mihael Hategan <hategan at mcs.anl.gov
> > >> wrote:
> > >> > > The first worker "failing" is 0904-20022331. The log looks funny
> at
> > >> the
> > >> > > end.
> > >> > > Can you git pull and re-run? The worker is getting some command
> at the
> > >> > > end there and doing nothing about it and I wonder why.
> > >> > > Mihael
> > >> > > On Thu, 2014-09-04 at 14:35 -0500, Tim Armstrong wrote:
> > >> > > > Ok, now I have some worker logs:
> > >> > > > http://people.cs.uchicago.edu/~tga/2014-9-4-worker-logs.tar.gz
> > >> > > > There's nothing obvious I see in the worker logs that would
> > >> indicate why
> > >> > > > the connection was broken.
> > >> > > > - Tim
> > >> > > > On Thu, Sep 4, 2014 at 1:11 PM, Tim Armstrong <
> > >> > > > wrote:
> > >> > > > > This is all running locally on my laptop, so I think we can
> rule
> > >> out
> > >> > > 1).
> > >> > > > > It also seems like it's a state the coaster service gets into
> > >> after a
> > >> > > few
> > >> > > > > client sessions: generally the first coaster run works fine,
> then
> > >> > > after a
> > >> > > > > few runs the problem occurs more frequently.
> > >> > > > > I'm going to try and get worker logs, in the meantime i've got
> > >> some
> > >> > > > > jstacks (attached).
> > >> > > > > Matching service logs (largish) are here if needed:
> > >> > > > > http://people.cs.uchicago.edu/~tga/service.out.gz
> > >> > > > > On Wed, Sep 3, 2014 at 10:35 PM, Mihael Hategan <
> > >> > > > > wrote:
> > >> > > > >> Ah, makes sense.
> > >> > > > >> 2 minutes is the channel timeout. Each live connection is
> > >> guaranteed
> > >> > > to
> > >> > > > >> have some communication for any 2 minute time window,
> partially
> > >> due to
> > >> > > > >> periodic heartbeats (sent every 1 minute). If no packets flow
> > >> for the
> > >> > > > >> duration of 2 minutes, the connection is assumed broken and
> all
> > >> jobs
> > >> > > > >> that were submitted to the respective workers are considered
> > >> failed.
> > >> > > So
> > >> > > > >> there seems to be an issue with the connections to some of
> the
> > >> > > workers,
> > >> > > > >> and it takes 2 minutes to detect them.
> > >> > > > >> Since the service seems to be alive (although a jstack on the
> > >> service
> > >> > > > >> when thing seem to hang might help), this leaves two
> > >> possibilities:
> > >> > > > >> 1 - some genuine network problem
> > >> > > > >> 2 - the worker died without properly closing TCP connections
> > >> > > > >> If (2), you could enable worker logging
> > >> > > > >> (Settings::Key::WORKER_LOGGING_LEVEL = "DEBUG") to see if
> > >> anything
> > >> > > shows
> > >> > > > >> up.
> > >> > > > >> Mihael
> > >> > > > >> On Wed, 2014-09-03 at 20:26 -0500, Tim Armstrong wrote:
> > >> > > > >> > Here are client and service logs, with part of service log
> > >> edited
> > >> > > down
> > >> > > > >> to
> > >> > > > >> > be a reasonable size (I have the full thing if needed, but
> it
> > >> was
> > >> > > over a
> > >> > > > >> > gigabyte).
> > >> > > > >> > One relevant section is from 19:49:35 onwards.  The client
> > >> submits 4
> > >> > > > >> jobs
> > >> > > > >> > (its limit), but they don't complete until 19:51:32 or so
> (I
> > >> can see
> > >> > > > >> that
> > >> > > > >> > one task completed based on ncompleted=1 in the
> check_tasks log
> > >> > > > >> message).
> > >> > > > >> > It looks like something has happened with broken pipes and
> > >> workers
> > >> > > being
> > >> > > > >> > lost, but I'm not sure what the ultimate cause of that is
> > >> likely to
> > >> > > be.
> > >> > > > >> > - Tim
> > >> > > > >> > On Wed, Sep 3, 2014 at 6:20 PM, Mihael Hategan <
> > >> > > > >> wrote:
> > >> > > > >> > > Hi Tim,
> > >> > > > >> > > I've never seen this before with pure Java.
> > >> > > > >> > > Do you have logs from these runs?
> > >> > > > >> > > Mihael
> > >> > > > >> > > On Wed, 2014-09-03 at 16:49 -0500, Tim Armstrong wrote:
> > >> > > > >> > > > I'm running a test Swift/T script that submit tasks to
> > >> Coasters
> > >> > > > >> through
> > >> > > > >> > > the
> > >> > > > >> > > > C++ client and I'm seeing some odd behaviour where task
> > >> > > > >> > > > submission/execution is stalling for ~2 minute periods.
> > >> For
> > >> > > > >> example, I'm
> > >> > > > >> > > > seeing submit log messages like "submitting
> > >> > > > >> > > > urn:133-1409778135377-1409778135378: /bin/hostname" in
> > >> bursts of
> > >> > > > >> several
> > >> > > > >> > > > seconds with a gap of roughly 2 minutes in between,
> e.g.
> > >> I'm
> > >> > > seeing
> > >> > > > >> > > bursts
> > >> > > > >> > > > with the following intervals in my logs.
> > >> > > > >> > > > 16:07:04,603 to 16:07:10,391
> > >> > > > >> > > > 16:09:07,377 to 16:09:13,076
> > >> > > > >> > > > 16:11:10,005 to 16:11:16,770
> > >> > > > >> > > > 16:13:13,291 to 16:13:19,296
> > >> > > > >> > > > 16:15:16,000 to 16:15:21,602
> > >> > > > >> > > > From what I can tell, the delay is on the coaster
> service
> > >> side:
> > >> > > the
> > >> > > > >> C
> > >> > > > >> > > > client is just waiting for a response.
> > >> > > > >> > > > The jobs are just being submitted through the local job
> > >> > > manager, so
> > >> > > > >> I
> > >> > > > >> > > > wouldn't expect any delays there.  The tasks are also
> just
> > >> > > > >> > > "/bin/hostname",
> > >> > > > >> > > > so should return immediately.
> > >> > > > >> > > > I'm going to continue digging into this on my own, but
> the
> > >> 2
> > >> > > minute
> > >> > > > >> delay
> > >> > > > >> > > > seems like a big clue: does anyone have an idea what
> could
> > >> cause
> > >> > > > >> stalls
> > >> > > > >> > > in
> > >> > > > >> > > > task submission of 2 minute duration?
> > >> > > > >> > > > Cheers,
> > >> > > > >> > > > Tim
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140905/a70f8834/attachment.html>
