[Swift-devel] Example of wrapper staging?
Michael Wilde
wilde at anl.gov
Sat Nov 8 17:32:37 CST 2014
Ok, that works great now, both with the conf you posted and with this one:
wrapperStagingLocalServer: "file://"
site.local {
staging: "wrapper"
scratch: "/tmp/wilde/swiftest"
- Mike
On 11/8/14 4:41 PM, Mihael Hategan wrote:
> (solved on IM but replying here for reference).
> I made a mistake in the swift.conf I sent. wrapperStagingLocalServer is
> a global option not a site option. However, it should work with the
> vanilla swift.conf posted, which had the wrong option commented out.
> Mihael
> On Sat, 2014-11-08 at 16:37 -0600, Michael Wilde wrote:
>> I get this error:
>> org.griphyn.vdl.util.SwiftConfigException: swift.conf:4 unexpected
>> property 'site.local.wrapperStagingLocalServer'
>> at
>> org.griphyn.vdl.util.SwiftConfigSchema.validate(SwiftConfigSchema.java:214)
>> Ive tried spelling this property both as in your sample .conf and as in
>> your text:
>> wrapperStagingLocalServer and wrapperStageingLocalServer
>> Neither is accepted. Did a schema change not get committed?
>> For general info: where is the json schema file that a user can check to
>> find all valid conf parameters?
>> Thanks,
>> - Mike
>> On 11/8/14 4:13 PM, Mihael Hategan wrote:
>>> type file;
>>> app (file c) cat(file a, file b) {
>>> cat filename(a) filename(b) stdout=filename(c);
>>> file c <"c.txt">;
>>> file a <"a.txt">;
>>> file b <"http://mirror.internode.on.net/pub/test/1meg.test">;
>>> c = cat(a, b);
>>> You would need a proper swift.conf. Here's an example of that:
>>> site.local {
>>> staging: "wrapper"
>>> scratch: "/some/scratch/dir"
>>> # *see email comments for details on the following option
>>> # wrapperStagingLocalServer:"file://"
>>> With a proper scratch dir there, this*should* work for you without any
>>> additional tweaking.
>>> Check _swiftwrap.wrapperstaging's stagein() and stageout() functions.
>>> That's where you would add additional protocols.
>>> The wrapperStagingLocalServer sets the default staging location for
>>> things that do not have an explicit scheme. In the case above, "c.txt"
>>> and "a.txt" are staged in and out using"file://". If you wanted the
>>> default to be some gridftp server, you would say something like
>>> 'wrapperStageingLocalServer: "gsiftp://gridftp.server.org/"'. Of course,
>>> _swiftwrap.wrapperstaging would need to know how to handle gsiftp URLs,
>>> which it doesn't at the moment.
>>> Mihael
Michael Wilde
Mathematics and Computer Science Computation Institute
Argonne National Laboratory The University of Chicago
