[Swift-devel] Multiple output files
Michael Wilde
wilde at anl.gov
Wed Mar 19 19:03:39 CDT 2014
Hi Jonathan,
You are thinking about this exactly right, and have (quickly) hit one of
our programmability weaknesses.
At the moment, there is no good way to do this. We have had much
discussion on it, though, and plan to create such "collect files of this
pattern into an array" semantics.
What we do for now is one of these two work-arounds:
- write a single tarfile as output (in a wrapper script for the app,
which tars files of the appropriate pattern, like "*.simout"
- write the files directly to a specific (shared) directory instead of
the Swift "app task directory" (called "job directory" in the current
User Guide. Then return a single file with a list of these file names,
and map that using an array_mapper if the results need to be passed to a
next stage
We should see if we can get a prototype of such a feature to you in
short order. But hopefully just to get things working, one of the above
methods will suffice for you, for now.
Im cc'ing swift-devel to see what we can do.
Thanks for reminding us of this fairly common need!
- Mike
On 3/19/14, 5:57 PM, Jonathan Ozik wrote:
> Mike,
> Perhaps I'm not thinking about this correctly, but I'm trying to figure out how to collect output files that are generated by a simulation run. The scenario is that the Repast executable is run and, after it is run, there are files that are output into some location. There can be an arbitrary number of such output files per simulation run but, if necessary, it would be possible to pre-specify which files to look for. Is there a simple way to indicate to swift that it should collect all the files matching a particular pattern within a directory? It looks like the mappers might work here but as far as I understand the mappers are defined prior to calls to executables. Again, I might just not be thinking about this in a "swift" enough way.
> Jonathan
Michael Wilde
Mathematics and Computer Science Computation Institute
Argonne National Laboratory The University of Chicago
