[Swift-devel] Strange errors while staging in data
David Kelly davidkelly at uchicago.edu
Sat Mar 1 13:35:46 CST 2014
Hello,
At the beginning of my run (apparently before any jobs actually start on
the scheduler) I am running into this error:
Swift 0.95 RC5 swift-r7605 cog-r3874
RunID: 20140301-1911-fe86tqf8
Progress: Sat, 01 Mar 2014 19:11:49+0000
Progress: Sat, 01 Mar 2014 19:11:50+0000  Selecting site:193  Stage in:307
Execution failed:
Exception in RunpSIMS:
    Arguments: [047, 438, params.psims, output/047/438output.tar.gz]
    Host: midway
    Directory: RunpSIMS-20140301-1911-fe86tqf8/jobs/g/RunpSIMS-g4b3m5nl
exception @ swift-int.k, line: 530
Caused by: java.lang.NullPointerException
cache @ swift-int.k, line: 134
at
org.globus.cog.karajan.compiled.nodes.CacheNode.setValue(CacheNode.java:131)
at
org.globus.cog.karajan.compiled.nodes.CacheNode.runBody(CacheNode.java:77)
at
org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:153)
This only seems to happen when I have 500 or more tasks. If I set
foreach.max.threads to a low number like 50, it seems to work fine.
The log is at
http://web.ci.uchicago.edu/~davidk/logs/RunpSIMS-20140301-1921-r4dps0i4.log.
Any ideas?
David
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140301/ffa475b9/attachment.html>
