[Swift-devel] Swift on Google compute engine [Request for	comments]
    Yadu Nand Babuji
    yadunand at uchicago.edu
    Fri Jun 27 12:00:52 CDT 2014
Thanks!
Google beats AWS in both Pricing and performance. Once you are past the
initial run of setup.sh from
the compute-engine setup, starting a 20 node cluster takes on less than
a 1min. The initial run copies
over images which takes time.
AWS                                    GCE
Micro instance                 $0.020/Hr
$0.013/Hr                  [1][2]
Networking perf               135mbits/s 692mbits/s                [3]
Boot speed 1min+                                 < 30s [4]
[1] https://developers.google.com/compute/pricing
[2] http://aws.amazon.com/ec2/pricing/
[3]
https://blog.serverdensity.com/network-performance-aws-google-rackspace-softlayer/
[4]
http://gigaom.com/2013/03/15/by-the-numbers-how-google-compute-engine-stacks-up-to-amazon-ec2/
Thanks
-Yadu
On 06/27/2014 11:11 AM, Foster, Ian T. wrote:
> Very nice.
> I am curious as to the reason for running on google. No objection to it, I just don't have experience with it -- only google
>> On Jun 27, 2014, at 10:47 AM, "Yadu Nand Babuji" <yadunand at uchicago.edu> wrote:
>> Hi Everyone,
>> Please try the Google Compute Engine setup and tutorial, I've linked below.
>> This will require credit card information and will bill you
>> approximately $0.065/Hr
>> with the default config of 5 micro instances.
>> Cloud setup online doc:
>> https://github.com/yadudoc/swift-on-cloud/tree/master/compute-engine
>> Git repo to clone:
>> https://github.com/yadudoc/swift-on-cloud.git
>> Once setup is done, do "connect headnode" and you can run the
>> swift-cloud-tutorial
>> under your $HOME/swift-on-cloud/swift-cloud-tutorial folder on the
>> headnode instance.
>> Feedback would be much appreciated.
>> PS: Remember to shut-down instances using the "dissolve" command.
>> Thanks!
>> Yadu
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
