[Swift-devel] Reducing swift log size
Yadu Nand Babuji yadunand at uchicago.edu
Thu Jun 12 16:50:51 CDT 2014
Just an update.
I ran the same configs as earlier, 6001 tasks, each taking 20s with
swift-0.95-RC6
and set just local pool to use ssh-cl:local and the logs are only 42Mb.
This is without
minimal or reduced logging set.
-Yadu
On 06/12/2014 01:36 PM, Mihael Hategan wrote:
> On Thu, 2014-06-12 at 13:02 -0500, Michael Wilde wrote:
>> In general we're moving to running coasters in all configurations (in
>> part to reduce the number of configurations to explain and test).
> Right. Although we could default to the local provider for local things.
>> Yadu's also looking at using provider staging shared-filesystem mode to
>> avoid un-necessary staging for local filesystems.
>> Can you explain the connection between this and the excessive logging?
>> Can that be fixed rather than resorting to an alternate provider?
> Local coaster services run in the same JVM. So static variables are the
> same in multiple instances of local coaster services. The code was
> written with the assumption that there would be one service per JVM, a
> scenario that we didn't think we would deviate from a few years ago.
> The job to worker node submission scheme is made up of a thread that
> looks at queued jobs and matches them with free workers. This runs in a
> loop that polls both the job queue and the worker queue. It is, however,
> possible for workers to be available that cannot fit any of the queued
> jobs due to walltime constraints. So you don't want to loop constantly
> in that case.
> The good news is that if a worker cannot run a queued job now due to
> time constraints, it will never be able to. So unless a new job with a
> smaller walltime comes in, you can safely assume that you don't need to
> bother waking up said worker.
> This is achieved using a sequence number. The job queue keeps one and
> changes it monotonically when new jobs come in. Sleeping workers take a
> snapshot of that and are only awaken if it differs from the one in the
> job queue (i.e. new jobs came in since we last figured that this worker
> cannot run any of the already queued jobs).
> The problem is that there are two job queues, one for each coaster
> service. But the code only looks at one static instance of them when
> checking whether a worker should be awaken. So the worker gets a low
> sequence number from the right job queue, but then it checks it against
> the other job queue, which has a higher sequence number. So it gets
> awaken. Then it gets put to sleep because it has nothing to run really.
> Anyway, there are two things that should be fixed there: the static
> variables and this should be made threadless.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
