[Swift-devel] Reducing swift log size
Mihael Hategan
hategan at mcs.anl.gov
Thu Jun 12 01:45:39 CDT 2014
Ok, the worker CPU stuff is indeed generating a lot of messages. But
that isn't supposed to happen. It's supposed to do nothing if nothing
happens. So I need to check what's going on.
Mihael
On Wed, 2014-06-11 at 19:45 -0500, Yadu Nand Babuji wrote:
> Okay, here you go:
> http://users.rcc.uchicago.edu/~yadunand/run010_swift_normal.tar.gz
> http://users.rcc.uchicago.edu/~yadunand/run011_minimal_logging.tar.gz
> http://users.rcc.uchicago.edu/~yadunand/run012_minimal_plus_log4j.tar.gz
> -Yadu
> On 06/11/2014 07:03 PM, Mihael Hategan wrote:
> > Sorry, I should have mentioned this, but can you please gzip them? It's
> > a bit much otherwise.
> > Mihael
> > On Wed, 2014-06-11 at 17:57 -0500, Yadu Nand Babuji wrote:
> >> Hi Mihael,
> >> I've got the logs for you.
> >> This time, i've run the 6001 tasks with 20s delay added, and was all run
> >> with swift-0.95-RC6 (from our website) :
> >> Normal run ->
> >> http://users.rcc.uchicago.edu/~yadunand/run010_swift_normal/run010.log (
> >> 6.1gb )
> >> With minimal logging ->
> >> http://users.rcc.uchicago.edu/~yadunand/run011_minimal_logging/run011.log (
> >> 7.5 gb )
> >> http://users.rcc.uchicago.edu/~yadunand/run012_minimal_plus_log4j/run012.log
> >> ( 845.4 kb )
> >> & log4j properties modified
> >> The run with minimal logging ran for ~15mins while the first run took
> >> ~12mins. That *might* explain why the one
> >> with minimal logging is larger.
> >> Thanks,
> >> Yadu
> >> On 06/11/2014 02:54 PM, Mihael Hategan wrote:
> >>> On Wed, 2014-06-11 at 14:46 -0500, Yadu Nand Babuji wrote:
> >>>> Hi,
> >>>> I'm running a proxy app for a user with 6000 tasks each taking a few
> >>>> milliseconds, and the log sizes are unusually large. When the tasks are
> >>>> set to take 20s, the total log size reaches ~7Gb.
> >>> 7GB? Wow. I'd like to see that. Can you upload and post link?
> >>>> I tried setting -minimal.logging and -reduced.logging but still see
> >>>> debug lines in the log like:
> >>>> 2014-06-11 19:15:06,961+0000 DEBUG Cpu worker started:
> >>>> block=0611-1507050-000000 host=midway461 id=10
> >>>> 2014-06-11 19:15:06,961+0000 DEBUG Cpu ready for work:
> >>>> block=0611-1507050-000000 id=10
> >>>> Do we need DEBUG lines such as the ones listed above ? Is it reasonable
> >>>> to have these set by default to WARN ?
> >>> It is until there's a problem and then people ask for the opposite. We
> >>> should evaluate whether this belongs in reduced logging or not. But does
> >>> that really account for most of the 7G?
> >>>> Secondly, setting -minimal.logging did not turn off these DEBUG lines
> >>>> and I had to set the following log4j.properties from DEBUG to WARN to
> >>>> remove most of the offending lines:
> >>> That sounds like a bug.
> >>>> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Cpu=WARN
> >>>> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Block=WARN
> >>>> With 6001 tasks, each taking 2 ms or so:
> >>>> Swift without any changes to logging -> 440879 lines and 51Mb
> >>>> Swift with -minimal.logging -> 83350 lines and 9.5Mb
> >>>> Swift with -minimal.logging and -> 7625 lines and 791Kb
> >>>> Cpu, Block log4j properties set
> >>>> Thanks,
> >>>> Yadu
> >>>> _______________________________________________
> >>>> Swift-devel mailing list
> >>>> Swift-devel at ci.uchicago.edu
> >>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
