[Swift-devel] Localhost coasters not working on Beagle
Michael Wilde
wilde at anl.gov
Sun Jun 8 22:31:35 CDT 2014
I'll try the other addresses for that host.
Maybe something changed there in iptables or similar.
- MIke
On 6/8/14, 10:27 PM, Mihael Hategan wrote:
> Ok, so:
> shell1: hategan at login1:~> netcat -l -p 50003
> shell2: hategan at login1:~> netstat -lntp
> tcp 0 0 0.0.0.0:50003 0.0.0.0:*
> LISTEN 22806/netcat
> hategan at login1:~> telnet 127.0.0.1 50003
> Trying 127.0.0.1...
> telnet: connect to address 127.0.0.1: Connection timed out
> I don't think this has anything to do with swift or coasters.
> Mihael
> On Sun, 2014-06-08 at 20:22 -0700, Mihael Hategan wrote:
>> That's odd. Have you tried netstat -lntp? telnet?
>> I'll give it a shot, but this looks rather strange.
>> Mihael
>> On Sun, 2014-06-08 at 22:10 -0500, Michael Wilde wrote:
>>> login1$ more /home/wilde/.globus/coasters/worker-0608-0710120-000000.log
>>> 2014/06/08 22:07:12.296 INFO - 0608-0710120-000000 Logging started: Sun
>>> Jun 8 22:07:12 2014
>>> 2014/06/08 22:07:12.296 INFO - Running on node
>>> login1.beagle.ci.uchicago.edu
>>> 2014/06/08 22:07:12.296 DEBUG - uri=http://127.0.0.1:50003
>>> 2014/06/08 22:07:12.296 DEBUG - scheme=http
>>> 2014/06/08 22:07:12.297 DEBUG - host=127.0.0.1
>>> 2014/06/08 22:07:12.297 DEBUG - port=50003
>>> 2014/06/08 22:07:12.297 DEBUG - blockid=0608-0710120-000000
>>> 2014/06/08 22:07:12.297 INFO - Connect attempt: 0 ...
>>> 2014/06/08 22:07:12.297 INFO - Trying 127.0.0.1:50003 ...
>>> 2014/06/08 22:07:33.296 INFO - Connection failed: Connection timed out.
>>> Trying other addresses
>>> 2014/06/08 22:07:33.296 ERROR - Connection failed for all addresses.
>>> 2014/06/08 22:07:33.296 ERROR - Retrying in 1 seconds
>>> 2014/06/08 22:07:34.297 INFO - Connect attempt: 1 ...
>>> 2014/06/08 22:07:34.297 INFO - Trying 127.0.0.1:50003 ...
>>> 2014/06/08 22:07:55.295 INFO - Connection failed: Connection timed out.
>>> 2014/06/08 22:07:55.296 ERROR - Connection failed for all addresses.
>>> 2014/06/08 22:07:55.296 ERROR - Retrying in 2 seconds
>>> 2014/06/08 22:07:57.298 INFO - Connect attempt: 2 ...
>>> 2014/06/08 22:07:57.298 INFO - Trying 127.0.0.1:50003 ...
>>> 2014/06/08 22:08:18.295 INFO - Connection failed: Connection timed out.
>>> 2014/06/08 22:08:18.295 ERROR - Connection failed for all addresses.
>>> 2014/06/08 22:08:18.295 ERROR - Failed to connect: Connection timed out
>>> login1$
>>> On 6/8/14, 5:33 PM, Mihael Hategan wrote:
>>>> Can you enable worker logging and post the worker log?
>>>> Mihael
>>>> On Sun, 2014-06-08 at 16:48 -0500, Michael Wilde wrote:
>>>>> Mihael - Im not able to get a simple localhost coasters run working on
>>>>> Beagle login1.
>>>>> All: Is anyone seeing something similar? It looks to me like my coaster
>>>>> worker is not able to connect to the Swift coaster service (using
>>>>> standard automatic coasters).
>>>>> Im working in /lustre/beagle/wilde/swift/lab/fastio (where you can find
>>>>> logs and configs). Running 0.95RC6.
>>>>> Im setting GLOBUS_HOSTNAME (to 127.0.0.1) and have tried internalHost as
>>>>> well:
>>>>> login1$ swift -config cf -tc.file apps -sites.file localcoast.xml
>>>>> catsn.swift
>>>>> login1$ cat localcoast.xml
>>>>> <?xml version="1.0" encoding="UTF-8"?>
>>>>> <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
>>>>> <pool handle="localhost">
>>>>> <execution provider="coaster" jobmanager="local:local"/>
>>>>> <profile namespace="globus" key="internalHostname">127.0.0.1</profile>
>>>>> <profile namespace="globus" key="maxwalltime">00:01:00</profile>
>>>>> <profile namespace="globus" key="maxtime">3600</profile>
>>>>> <profile namespace="globus" key="jobsPerNode">1</profile>
>>>>> <profile namespace="globus" key="slots">1</profile>
>>>>> <profile namespace="globus" key="nodeGranularity">1</profile>
>>>>> <profile namespace="globus" key="maxNodes">1</profile>
>>>>> <profile namespace="karajan" key="jobThrottle">12</profile>
>>>>> <profile namespace="karajan" key="initialScore">10000</profile>
>>>>> <profile namespace="karajan" key="lowOverAllocation">100</profile>
>>>>> <profile namespace="karajan" key="highOverAllocation">100</profile>
>>>>> <filesystem provider="local"/>
>>>>> <workdirectory>/tmp/swiftwork</workdirectory>
>>>>> </pool>
>>>>> I get error 110 connection timeouts:
>>>>> 2014-06-08 16:37:50,762-0500 DEBUG swift JOB_START jobid=cat-7jiymsrl
>>>>> tr=cat arguments=[data.txt] tmpdir=catsn-run013/jobs/7/cat-7jiymsrl
>>>>> host=localhost
>>>>> 2014-06-08 16:37:50,829-0500 INFO LocalService Started local service:
>>>>> 127.0.0.1:50000
>>>>> 2014-06-08 16:37:50,837-0500 INFO BootstrapService Socket bound. URL is
>>>>> http://127.0.0.1:50001
>>>>> 2014-06-08 16:37:50,914-0500 INFO Settings Local contacts:
>>>>> [http://127.0.0.2:50003, http://192.5.86.104:50003,
>>>>> http://10.128.2.244:50003]
>>>>> 2014-06-08 16:37:50,917-0500 INFO CoasterService Started local service:
>>>>> 2014-06-08 16:37:50,917-0500 INFO CoasterService Reserving channel for
>>>>> registration
>>>>> 2014-06-08 16:37:50,942-0500 INFO MetaChannel MetaChannel [context:
>>>>> cpipe, boundTo: null] binding to cpipe://1
>>>>> spipe, boundTo: null] binding to spipe://1
>>>>> 2014-06-08 16:37:50,942-0500 INFO CoasterService Sending registration
>>>>> 2014-06-08 16:37:50,948-0500 INFO MetaChannel Trying to re-bind current
>>>>> channel
>>>>> 2014-06-08 16:37:50,949-0500 INFO RequestHandler Handler(tag: 1,
>>>>> REGISTER) unregistering (send)
>>>>> 2014-06-08 16:37:50,949-0500 INFO CoasterService Registration complete
>>>>> 2014-06-08 16:37:50,949-0500 INFO CoasterService Started coaster
>>>>> service: http://127.0.0.1:50002
>>>>> 2014-06-08 16:37:50,952-0500 WARN Settings original callback URI is
>>>>> 2014-06-08 16:37:50,952-0500 WARN Settings callback URI has been
>>>>> overridden to http://127.0.0.1:50003
>>>>> 2014-06-08 16:37:50,953-0500 INFO RequestHandler Handler(tag: 1,
>>>>> CONFIGSERVICE) unregistering (send)
>>>>> 2014-06-08 16:37:50,969-0500 INFO BlockQueueProcessor Starting...
>>>>> id=0608-3704500
>>>>> 2014-06-08 16:37:50,969-0500 INFO RequestHandler Handler(tag: 2,
>>>>> SUBMITJOB) unregistering (send)
>>>>> 2014-06-08 16:37:51,009-0500 INFO BlockQueueProcessor
>>>>> Settings {
>>>>> slots = 1
>>>>> jobsPerNode = 1
>>>>> workersPerNode = 1
>>>>> nodeGranularity = 1
>>>>> allocationStepSize = 0.1
>>>>> maxNodes = 1
>>>>> lowOverallocation = 10.0
>>>>> highOverallocation = 1.0
>>>>> overallocationDecayFactor = 0.001
>>>>> spread = 0.9
>>>>> reserve = 60.000s
>>>>> maxtime = 3600
>>>>> remoteMonitorEnabled = false
>>>>> internalHostname = 127.0.0.1
>>>>> hookClass = null
>>>>> workerManager = block
>>>>> workerLoggingLevel = NONE
>>>>> workerLoggingDirectory = DEFAULT
>>>>> ldLibraryPath = null
>>>>> workerCopies = null
>>>>> directory = null
>>>>> useHashBang = null
>>>>> parallelism = 0.01
>>>>> coresPerNode = 1
>>>>> perfTraceWorker = false
>>>>> perfTraceInterval = -1
>>>>> attributes = {}
>>>>> callbackURIs = [http://127.0.0.1:50003]
>>>>> 2014-06-08 16:37:51,009-0500 INFO BlockQueueProcessor Jobs in holding
>>>>> queue: 1
>>>>> 2014-06-08 16:37:51,009-0500 INFO BlockQueueProcessor Time estimate for
>>>>> holding queue (seconds): 1
>>>>> 2014-06-08 16:37:51,009-0500 INFO BlockQueueProcessor Allocating blocks
>>>>> for a total walltime of: 1s
>>>>> 2014-06-08 16:37:51,009-0500 INFO BlockQueueProcessor Considering:
>>>>> Job(id:0 60.000s)
>>>>> 2014-06-08 16:37:51,009-0500 INFO BlockQueueProcessor Max
>>>>> Walltime (seconds): 60
>>>>> estimate (seconds): 600
>>>>> 2014-06-08 16:37:51,010-0500 INFO BlockQueueProcessor Total for
>>>>> this new Block (est. seconds): 0
>>>>> 2014-06-08 16:37:51,013-0500 INFO BlockQueueProcessor index: 0, last:
>>>>> 0, holding.size(): 1
>>>>> 2014-06-08 16:37:51,014-0500 INFO BlockQueueProcessor Queued: 1 jobs to
>>>>> new Block
>>>>> 2014-06-08 16:37:51,014-0500 INFO BlockQueueProcessor index: 0, last:
>>>>> 0, ii: 1, holding.size(): 1
>>>>> 2014-06-08 16:37:51,014-0500 INFO Block Starting block: workers=1,
>>>>> walltime=600.000s
>>>>> 2014-06-08 16:37:51,016-0500 INFO RemoteLogHandler BLOCK_REQUESTED
>>>>> id=0608-3704500-000000, cores=1, coresPerWorker=1, walltime=600
>>>>> 2014-06-08 16:37:51,016-0500 INFO RequestHandler Handler(tag: 2, RLOG)
>>>>> 2014-06-08 16:37:51,018-0500 INFO BlockTaskSubmitter Queuing block
>>>>> Block 0608-3704500-000000 (1x600.000s) for submission
>>>>> 2014-06-08 16:37:51,018-0500 INFO BlockQueueProcessor Added 1 jobs to
>>>>> new blocks
>>>>> 2014-06-08 16:37:51,018-0500 INFO BlockTaskSubmitter Submitting block
>>>>> 2014-06-08 16:37:51,018-0500 INFO ExecutionTaskHandler provider=local
>>>>> 2014-06-08 16:37:51,023-0500 INFO Block Block task status changed:
>>>>> Submitting
>>>>> 2014-06-08 16:37:51,023-0500 INFO JobSubmissionTaskHandler Submit: in:
>>>>> / command: /usr/bin/perl
>>>>> /home/wilde/.globus/coasters/cscript2445623341660096310.pl
>>>>> http://127.0.0.1:50003 0608-3704500-000000 NOLOGGING
>>>>> 2014-06-08 16:37:51,024-0500 INFO Block Block task status changed:
>>>>> Submitted
>>>>> 2014-06-08 16:37:51,027-0500 INFO Block Block task status changed: Active
>>>>> 2014-06-08 16:37:51,027-0500 INFO RemoteLogHandler BLOCK_ACTIVE
>>>>> 2014-06-08 16:37:51,027-0500 INFO RequestHandler Handler(tag: 3, RLOG)
>>>>> 2014-06-08 16:37:51,681-0500 INFO RuntimeStats$ProgressTicker Submitted:1
>>>>> 2014-06-08 16:37:51,681-0500 INFO RuntimeStats$ProgressTicker HeapMax:
>>>>> 954466304, CrtHeap: 253624320, UsedHeap: 28583112
>>>>> 2014-06-08 16:38:21,683-0500 INFO RuntimeStats$ProgressTicker Submitted:1
>>>>> 2014-06-08 16:38:21,683-0500 INFO RuntimeStats$ProgressTicker HeapMax:
>>>>> 954466304, CrtHeap: 253624320, UsedHeap: 29067208
>>>>> 2014-06-08 16:38:51,686-0500 INFO RuntimeStats$ProgressTicker Submitted:1
>>>>> 2014-06-08 16:38:51,686-0500 INFO RuntimeStats$ProgressTicker HeapMax:
>>>>> 954466304, CrtHeap: 253624320, UsedHeap: 29551304
>>>>> 2014-06-08 16:38:57,113-0500 INFO Block Block task status changed:
>>>>> Failed Job failed with an exit code of 110
>>>>> 2014-06-08 16:38:57,115-0500 INFO Block Failed task spec: Job:
>>>>> executable: /usr/bin/perl
>>>>> arguments:
>>>>> stdout: null
>>>>> stderr: null
>>>>> directory: /
>>>>> batch: false
>>>>> redirected: false
>>>>> attributes:
>>>>> hostcount=1,count=1,jobspernode=1,corespernode=1,maxwalltime=10
>>>>> env: WORKER_LOGGING_LEVEL=NONE
>>>>> 2014-06-08 16:38:57,115-0500 INFO Block Worker task failed:
>>>>> Failed to connect: Connection timed out at
>>>>> /home/wilde/.globus/coasters/cscript2445623341660096310.pl line 1101.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Mathematics and Computer Science Computation Institute
Argonne National Laboratory The University of Chicago
