[Swift-devel] Issues to resolve for the 0.96 config mechanism
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Jul 14 15:06:38 CDT 2014
If there are no comments or suggestions besides what has already been
said, I'll keep the 5 step search path exactly as it is in 0.95. Please
do comment if you have something to say. We're less likely to re-visit
the issue in the future.
Anyway, the second issue is whether we want automatic or explicit
inheritance. In other words, do we want all of the 5 steps to be loaded
in order, non-existing files being silently skipped, or do we want the
first file in the search path to have to explicitly include others. Or
do we want a mixed behavior (such as SWIFT_SITE_CONF and ./swift.conf
both loaded automaticaly but not others)?
Mihael
On Mon, 2014-07-14 at 11:00 -0700, Mihael Hategan wrote:
> Hi,
> So, first, when I say "gone" that means "it's not there right now in
> trunk". This is work in progress, and I was hoping to get feedback from
> everybody, hopefully based on use cases and experiences. This change
> brings an opportunity to re-visit some of the things we have and see if
> they make sense in the new context and make the right long-term
> decisions.
> The first question is whether ~/.swift/swift.conf and ./swift.conf
> should be explicitly in the search path, since SWIFT_SITE_CONF can do
> both:
> export SWIFT_SITE_CONF=~/.swift/swift.conf
> export SWIFT_SITE_CONF=./swift.conf
> Mihael
> On Sun, 2014-07-13 at 20:02 -0700, Mihael Hategan wrote:
> > Sorry. This discussion went a bit off. I apologize.
> > Search path. There are some changes. Here are the details:
> > 1. swift/etc/swift.conf is still there
> > 2. SWIFT_SITE_CONF is still there. It makes good sense.
> > 3. ~/.swift/swift.conf is gone. SWIFT_SITE_CONF does the same and is
> > explicit. Can be added back.
> > 4. ./swift.conf is gone for reasons of magicality. Can also be added
> > back.
> > 5. -config on the command line is still there.
> > The fundamental difference is that there is no "if it's not there,
> > ignore silently and continue" behavior and there is no automated
> > chaining. The user has to say what they want. It's a one-time operation
> > per file. Very likely less work than the actual contents of the file,
> > but less error-prone. It's a choice. That of safety vs. convenience. We
> > can bias either way and supplement with tools.
> > We could and should discuss the merits of what has changed. It might
> > help if we do it one issue at a time.
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
