[Swift-devel] Swift on AWS-EC2 [Request for comments]
    Yadu Nand Babuji
    yadunand at uchicago.edu
    Mon Jul 14 14:36:51 CDT 2014
Hi Everyone,
I've added support for Amazon's-EC2 to the swift-on-cloud repository and
tutorial. Please try the setup and documentation.
If you are on the swift allocation on AWS, you'd only need to get the
IAM credentials file from the swift aws console:
https://swift.signin.aws.amazon.com/console
<https://www.google.com/url?q=https%3A%2F%2Fswift.signin.aws.amazon.com%2Fconsole&sa=D&sntz=1&usg=AFQjCNGCcWeMITvu7cmbPZWMClr-pk96VA>
Otherwise, you'd have to setup billing, and with micro instances prices
are now the same as Google's Compute Engine (around $0.013/Hr/micro
instance)
Cloud setup online doc:
https://github.com/yadudoc/swift-on-cloud/tree/master/aws
Git repo to clone:
https://github.com/yadudoc/swift-on-cloud.git
Once setup is done, do "connect headnode" and you can run the
swift-cloud-tutorial
under your $HOME/swift-on-cloud/swift-cloud-tutorial folder on the
headnode instance.
Feedback would be much appreciated.
PS: Remember to shut-down instances using the "dissolve" command.
Thanks!
Yadu
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140714/ca033ecf/attachment.html>
