[Swift-devel] Issues to resolve for the 0.96 config mechanism
    Michael Wilde
    wilde at anl.gov
    Sun Jul 13 20:17:53 CDT 2014
I agree about the logical nature of the search path.  But it was
designed so that most users would see a very simple view of
configuration. Its not really like a deep inheritance tree.
The concept was this:
 > 1. The etc/swift.properties file included with the Swift distribution.
These would be basic things like localhost, and maybe a few simple sites
for generic cloud pools and sets of ad-hoc nodes.
Things that should enable you to just download Swift and try a few
things without thinking (or even knowing) about sites.
 > 2. $SWIFT_SITE_CONF/swift.properties - used for defining site templates.
This was for site admins to make, e.g., Swift modules, so that when you
say "module load swift" you get a set of reasonable site definitions for
local clusters and queues.
 > 3. $HOME/.swift/swift.properties
This would allow the user to set some preferences, like whether they
wanted Swift retry to be on or off by default.
 > 4. swift.properties in your current directory.
This was seen as the *main* property file that a user would create,
alongside their .swift file, for a given scripting application.  Its
where anything specific to running a given script would be set.
 > 5. Any property file you point to with the command line argument
This was seen as a way to specify a remote configuration file, and was
expected to be seldom used by most users.
Regarding the tool, I agree totally, and there was indeed such a thing
provided in 0.95:
To verify what files are being read, and what values will be set, run:
$ swift -listconfig
Ive not checked its output, but both it, and the swift log, should list:
a)  a set of all the properties files that were read in the run (or in
the current environment)
b) a hierarchical listing of all properties (including site attributes),
listed one attribute per line.
For each attribute, the output can append a simple [n] notation after
each attribute stating which of the N property files that attribute was
set from.
- Mike
On 7/13/14, 8:04 PM, Tim Armstrong wrote:
> My two cents: the five step search path seems logical and I can come
> up with scenarios where someone would want to have a particular
> setting at a particular level in the hierarchy.
> It reminds me though of some of the OOP debates about inheritance,
> where you have carefully thought out, deep, inheritance hierarchies,
> carefully engineered to reuse code wherever possible.  The problem
> tends to be that as a developer reading a bit of code, you've got no
> idea which overridden method is being called, except maybe with the
> help of an IDE.  There's not really a right answer, just that
> sometimes the smart complicated way is the best, and sometimes the
> dumb but simple way is the best.
> Maybe if having 4/5 levels of configuration is "the right thing" that
> users should do, all of the sample and tutorial properties files that
> users will copy could just explicitly include their predecessor?  I.e.
> use the explicit mechanism but encourage the desired approach by
> convention.
> With the more complex inheritance mechanism, it seems like it is
> almost necessary to have a tool that shows all of the currently
> applied settings and where they come from.
> - Tim
> On Sun, Jul 13, 2014 at 6:37 PM, Mihael Hategan <hategan at mcs.anl.gov
> <mailto:hategan at mcs.anl.gov>> wrote:
>     I know the feeling. I get it too. I see some new stuff and I was
>     getting
>     used to the old stuff, and I get this immediate anger about the new
>     stuff and the feeling that it's stupid and I want the old stuff back.
>     All I'm saying is give it some time. Try it out a bit, see how you
>     would
>     do something with it, etc. It's not set in stone. We have SVN and
>     we can
>     always go back.
>     Ultimately the questions are: can I do what I was doing before,
>     and how
>     much effort does that require. Also what are the new things that I can
>     do and could not do before, and how much better/worse is the overall
>     process. I know what the previous thing could do, and you can still do
>     that, just not in the exact same way.
>     Some more inline...
>     On Sun, 2014-07-13 at 17:03 -0500, Michael Wilde wrote:
>     > On 7/13/14, 1:01 PM, Mihael Hategan wrote:
>     > >> - the include mechanism is new.   I think its nice and likely
>     is very
>     > >> >useful, but I wonder how it will interact with or supplement the
>     > >> >property search path.
>     > > We discussed this a few days ago. We had repeated issues with
>     magically
>     > > loaded files from strange locations that the users took a long
>     time to
>     > > find and fix. The solution that I saw in 0.95 was even more search
>     > > locations, which I think was not right.
>     > > So the philosophy in trunk is "either it stares at you or it isn't
>     > > there". And includes do this in a way that doesn't sacrifice
>     > > convenience.
>     > I disagree with this. The properties search path in 0.95 was
>     carefully
>     > thought out, and based on a lot of experience with users, even
>     it that
>     > discussion did not take place on the list.
>     You can write a config file that includes all the different config
>     files
>     and put it in swift/etc, if, as a user, that is what you think is
>     best.
>     > Unfortunately the trunk commits over-wrote the 0.95
>     documentation in the
>     > trunk userguide, but the search path was like this:
>     > Location of swift.properties
>     > Swift searches for swift.properties files in multiple locations:
>     distribution.
>     templates.
>     > "-properties
>     > <file>"
>     > Settings get read in this order. Definitions in the later files will
>     > override
>     > any previous definitions. For example, if you have
>     execution.retries=10 in
>     > $HOME/.swift/swift.properties, and execution.retries=0 in the
>     > swift.properties
>     > in your current directory, execution.retries will be set to 0.
>     Yes. Well, I think this is bad. Imagine a user having to mentally go
>     through this sequence in order to figure out what's being set and
>     where.
>     It's actually nearly impossible mentally. You have to go through the
>     files and remember the order.
>     The biggest problems we've had so far in terms of the configuration we
>     had were with this. A file in the search path magically loaded without
>     the user's knowledge. Even recently you and Yadu have experienced
>     this,
>     and were wondering where some configuration value comes from that was
>     causing a run to break. And it took you a few hours and I had to get
>     involved to sort it out. And It was all documented. See
>     https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=1281
>     So no, I do not think that this is a good idea.
>     > I thought this search path notion was logical, useful, and
>     reflected the
>     > needs of users and site admins. It was a refinement of what
>     existed in
>     > Swift going back many releases.
>     It added extra steps to something that already had too many steps.
>     That said, the new stuff doesn't say you can't do that. Just that you
>     have to actually say it yourself that you want to do that. The
>     reason we
>     had multiple search paths is because we did not support includes,
>     so we
>     needed a mechanism to override only a few things. But you can simulate
>     it with includes and customize it in whatever way you want and it
>     would
>     be obvious what's coming from where.
>     The point is to give the user a simple and powerful tool to do
>     what they
>     need.
>     > In 0.95 it was tied to the use of run directories (which I hope
>     has not
>     > been removed from trunk!).
>     No. It's still there. I like it. I only renamed runxxx.log to
>     swift.log,
>     since I did not se why everything had a name that did not include the
>     run id except for the log. We can change this back if there is a
>     reason.
>     We do probably need to fix a few issues with it. It will break with
>     concurrent starts of swift, and it will break on filesystems that
>     don't
>     list directories in some particular order.
>     _______________________________________________
>     Swift-devel mailing list
>     Swift-devel at ci.uchicago.edu <mailto:Swift-devel at ci.uchicago.edu>
>     https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140713/b5f4767e/attachment.html>
