[Swift-devel] new config
    Michael Wilde
    wilde at anl.gov
    Wed Jul  9 15:18:55 CDT 2014
Nice step forward!
Do property values need to be quoted? If so, can that be made optional?
- Mike
On 7/9/14, 3:16 PM, Mihael Hategan wrote:
> Hi,
> I committed the new config code. Since it's a pretty big change, it
> might take some testing to get it ironed out and some time to get used
> to. Particularly, the tests have not been updated. Yadu, when you have
> some time, let's work on updating our testing tools.
> A bit of an overview:
> - it's a JSON-like format, with optional key quoting, optional comma
> between object keys (if there is a new line), optional "=" before a "{"
> and ":" and "=" mean the same thing. So this is valid:
>    site.local {
>      execution {
>        type: "ssh"
>        URL: "localhost"
> as is
>    site.local.execution.type = "ssh"
>    site.local.execution.URL = "localhost"
> However, in order to reduce confusion, we should encourage only the
> former choice.
> - Most properties that were in swift.properties had their names changed
> from a dot separator to camelCase. It was distasteful to see a file
> where site options were camelCase and other options
> used.dots.as.separators.
> - Some options have changed a bit more than that. For example,
> sitedir.keep is now keepSiteDir.
> - I removed clustering (it wasn't used and is superseded by coasters)
> - I also removed the graph generation option. It wasn't being used much
> (outside of I2U2) and I would prefer that such tools be outside of the
> run-time code and in the log analysis tools.
> - Everything is validated. Unrecognized options, or invalid values will
> produce an error. The "schema" used for validation is in
> resources/swift.conf.schema.
> - The preferred way of mixing configurations is through includes.
> - There is a conversion tool, swift-convert-config. You can give it a
> sites.xml, tc.data, and swift.properties, and it will print out a new
> config from there.
> - Somewhat unrelated, but wrapper/provider staging are now selectable
> per site. You would say something like site.local { staging:
> "provider" }
> - There is also a swift-config-info tool. This is similar to David's
> -listconfig option. It can list all available configuration properties
> and also print documentation on selected options. For somebody who is
> working on the command line doing stuff, it may be more convenient than
> switching to a web browser to look up the configuration documentation.
> - I still need to finish all property descriptions and update the
> documentation.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
