[Swift-devel] changes
Tim Armstrong
tim.g.armstrong at gmail.com
Fri Jul 4 11:49:11 CDT 2014
I had a semi-related question: is there any documentation aside from the
user guide about sites, providers, and job managers in Swift/Coasters?
- Tim
On Fri, Jul 4, 2014 at 11:02 AM, Michael Wilde <wilde at anl.gov> wrote:
> A lot of great work, here, Mihael - very nice!
> We'll need to re-adjust the new config mechanism to match this, unless
> you've already done that.
> This means that we'll need to get all users converted to the new config
> before this gets released - else they will have no backwards compatibility
> for their current configurations (sites and tc files).
> Nonetheless, as we discussed in a prior meeting, I think we agreed that
> this was a necessary step and the right way to go.
> - Mike
> On 7/4/14, 3:07 AM, Mihael Hategan wrote:
> Hi,
> I committed a fairly large number of changes. Some things got limited
> testing, and some are work in progress. For example, I need to update
> sites files used in tests, but it's getting late here.
> Anyway, here's a summary:
> 1. New sites.xml format and removal of tc.data. I expect a bunch of
> things to break, but we discussed cleaning both sites.xml and tc.data
> many times and I guess I never got the courage to do it until now. This
> format is not backwards compatible (intentionally). It goes like this:
> <sites>
> <apps>? <!-- global apps -->
> <property name="...">...</property>* <!-- global app properties -->
> <env name="...">...</env>* <!-- global app envs -->
> <app name="..." executable="...">*
> <property/>*
> <env/>*
> </app>
> </apps>
> <site name="...">
> <execution provider="..."...>
> <property/>*
> </execution>
> <filesystem>?
> <property/>*
> </filesystem>
> <wokdirectory/>
> <scratch/>?
> <apps/>?
> <site>
> </sites>
> There are no more namespaces since they were mostly used to figure out
> whether a property was going to the task or the site. I also changed
> "profile" to "property", since "profile" seemed a bit arcane.
> You should also now be able to use maxParallelTasks and
> initialParallelTasks instead of jobThrottle and initialScore. It
> computes the latter automatically.
> 2. Coasters now support multiple configurations. So you can have two
> local:local coaster sites with different settings and it should work.
> The way this works is that every configuration (and every different run)
> gets its own job queue, settings, and block allocator, and they don't
> interact with each other. This might be problematic with things like
> slots which is meant to limit the number of jobs globally, but that's a
> minor annoyance.
> 3. Passive workers can be launched with a -c(oncurrency) argument (1 by
> default). This will be the jobs per node setting. Each worker can have a
> different number, and that should work as expected. For passive workers,
> the client side jobsPerNode setting will be ignored.
> 4. There is a tool to analyze logs now (swift-log-info). This is simply
> an offline version of the http monitor. It can parse logs and feed the
> information to a web browser. It should also be able to follow logs as
> they are produced and feed live information to a browser. It can also
> fake a live log by parsing it slowly instead of all-at-once.
> 5. The http monitor got a bit of an update. You can look at all kinds of
> statistics, browse through apps, look at pretty plots of how apps
> behaved, etc. all in a nice dynamically updated ajaxy and hyperlinked
> fashion. It should be cute and useful in one. Won't work with older
> logs. Some pics attached.
> 6. There are now worker.pl "probes" for CPU usage, disk usage, and some
> I/O stats. If you click on a link to a worker in the http monitor,
> you'll get nice graphs of these things. The probes are currently
> hardcoded to run every 60 seconds (although in the pictures below they
> ran at 1/s).
> Mihael
> Swift-devel mailing listSwift-devel at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
> Mathematics and Computer Science Computation Institute
> Argonne National Laboratory The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140704/e0e144f9/attachment.html>
