[Swift-devel] staging time to sites from log
    Ketan Maheshwari
    ketan at mcs.anl.gov
    Wed Jan 22 15:39:36 CST 2014
In the log I have from Swift trunk swift-r7228 cog-r3817, I do not see
'sending data' messages.
On Wed, Jan 22, 2014 at 3:09 PM, David Kelly <davidkelly at uchicago.edu>wrote:
> I was just looking more closely through a log I just created that used
> provider staging. I think there is some info about timings there that look
> like this:
> 2014-01-22 14:11:50,249-0600 INFO  PutFileHandler Handler(tag: 7644, PUT)
> source: ./hostname-run000/jobs/a/hostname-azak6dll/hostfile.out
> destination:
> proxy://u2086f356-143bb93f2a2--7fff-u2086f356-143bb93f2a2--8000S//home/davidk/test/./hostfile.out
> 2014-01-22 14:11:50,251-0600 INFO  PutFileCommand Sending Command(tag: 10,
> PUT) (t) on cpipe://1
> 2014-01-22 14:11:50,251-0600 INFO  PutFileCommand Command(tag: 10, PUT)
> (t) sending data
> 2014-01-22 14:11:50,251-0600 INFO  PutFileHandler Handler(tag: 7644, PUT)
> -> 10
> 2014-01-22 14:11:50,251-0600 INFO  PutFileHandler Handler(tag: 10, PUT)
> destination: file://localhost//home/davidk/test/hostfile.out
> 2014-01-22 14:11:50,252-0600 INFO  PutFileHandler Handler(tag: 10, PUT)
> Transfer done
> 2014-01-22 14:11:50,252-0600 INFO  RequestHandler Handler(tag: 10, PUT)
> unregistering (send)
> 2014-01-22 14:11:50,252-0600 INFO  PutFileHandler Handler(tag: 7644, PUT)
> Transfer done
> 2014-01-22 14:11:50,253-0600 INFO  RequestHandler Handler(tag: 7644, PUT)
> Maybe you could keep track of the tag number and record the difference
> from "sending data" to "Transfer done" to get an estimate. I'm not sure how
> to correlate the file transfers to a jobid though.
> On Wed, Jan 22, 2014 at 2:54 PM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>> Hi,
>> Is it possible to find staging in and out times per job with Swift logs
>> with provider staging?
>> Speaking with David about this, he mentioned it is not currently possible
>> with provider staging but there may be some options in log4j that could
>> achieve it.
>> Does anyone know about any such options or any indirect methods?
>> Thanks,
>> Ketan
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140122/3defc335/attachment.html>
