[Swift-devel] Lammps on BGQ: task completes but status shows active
Mihael Hategan hategan at mcs.anl.gov
Mon Dec 8 17:31:21 CST 2014
On Mon, 2014-12-08 at 17:08 -0600, Ketan Maheshwari wrote:
> On Mon, Dec 8, 2014 at 4:30 PM, Hategan-Marandiuc, Philip M. <
> hategan at mcs.anl.gov> wrote:
> > This looks like the strace you initially sent, the one that was stracing
> > bg.sh, so I suspect that you didn't remove the failing strace from
> > wherever it was, unless I'm misunderstanding what gets called from
> > where.
> This is the new strace output obtained by putting "strace -o" in front of
> $EXEC call in _swiftwrap.staging. This strace output is distinct from the
> previous one which was obtained by putting "strace -o" in front of bgsh in
> app call. They are similar because they invoke the same executable with
> same arguments.
So what you are saying is that _swiftwrap does not invoke your app
directly, but it invokes bg.sh instead?
Mihael
