[Swift-devel] Lammps on BGQ: task completes but status shows active
Ketan Maheshwari ketan at mcs.anl.gov
Mon Dec 8 14:07:18 CST 2014
I tried to get strace output with two methods:
stderr.txt: This was obtained by attaching the "--strace 0" switch to the
runjob command. It seems to be exiting normally after writing a bunch of
stuff.
strace.out: This one was obtained by wrapping the app exe with strace -o
$HOME/strace.out  ...
This one shows a stuck output with the last line as:
waitpid(-1, %
Please find both attached.
I am trying to figure why this one stuck but any insights will help.
Ketan
On Mon, Dec 8, 2014 at 12:48 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> I would put an strace in _swiftwrap around the executable to see what
> keeps it from completing.
> Mihael
> On Mon, 2014-12-08 at 10:29 -0600, Ketan Maheshwari wrote:
> > Hi Mihael, All,
> > Can you help debugging this issue.
> > On BG/Q (cetus), running lammps with provider coaster.
> > The symptom is that the lammps task completes but Swift still thinks it
> is
> > running and continues to show "Active" status. Worker logs also show that
> > the task is running. The _wrapperlog is stalled in EXECUTE stage.
> > The script (bg.sh) running in the qsub "script" mode invokes runjob and
> it
> > seems that the line after runjob is not reached, meaning runjob does not
> > return.
> > The same configuration (qsub in script mode and runjob with same
> > parameters) , when run outside of Swift seems to be working (ie. script
> > exits on completion).
> > Attaching the bg.sh, and a tarball with Swift run dir and worker log in
> > DEBUG mode.
> > Thanks for any help further debugging this.
> > Best,
> > Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20141208/310f9e29/attachment.html>
2014-12-08 19:00:12.251 (INFO ) [0xfffaa45bde0] ibm.runjob.AbstractOptions: using properties file /bgsys/local/etc/bg.properties
2014-12-08 19:00:12.253 (INFO ) [0xfffaa45bde0] ibm.runjob.AbstractOptions: max open file descriptors: 65536
2014-12-08 19:00:12.253 (INFO ) [0xfffaa45bde0] ibm.runjob.AbstractOptions: core file limit: 18446744073709551615
2014-12-08 19:00:12.254 (INFO ) [0xfffaa45bde0] 12249:tatu.runjob.client: scheduler job id is 377820
2014-12-08 19:00:12.262 (INFO ) [0xfffac5634e0] 12249:tatu.runjob.monitor: monitor started
2014-12-08 19:00:15.924 (INFO ) [0xfffac5634e0] 12249:tatu.runjob.monitor: task record 830601 created
2014-12-08 19:00:15.925 (INFO ) [0xfffaa45bde0] CET-40000-51331-128:12249:ibm.runjob.client.options.Parser: set local socket to runjob_mux from properties file
2014-12-08 19:00:18.952 (INFO ) [0xfffaa45bde0] CET-40000-51331-128:900136:ibm.runjob.client.Job: job 900136 started
(I) sc_uname[0.0:1]: name=0x1fbfffb8d0
(I) sc_brk[0]: brk_val=r3=0x00000000
(I) sc_brk[0]: brk_val=0x00000000, returning 0x1f87000000.
(I) sc_brk[0]: brk_val=r3=0x1f870013c8
(I) sc_brk[0]: brk_val=0x1f870013c8, returning 0x1f870013c8.
(I) sc_set_tid_address[ 0]: Entry: tid_addr=0x1f870000d0. Returning PID=1.
(I) sc_futex[0]: op(129)=WAKE, uaddr=1fbfffb9b0, val=1 timeout=0 *uaddr=0 uaddr2=0x00000000 val3=0x00000000.
(I) sc_futex[0]: op(393)=Other, uaddr=1fbfffb9b0, val=1 timeout=0 *uaddr=0 uaddr2=0x00000000 val3=0x00000000.
(I) sc_rt_sigaction[0]: sig=32, act=0x1fbfffb7b0, oldact=0x00000000, sigsetsize=8.
(I) sc_rt_sigaction[0]: act{ sa_handler:216d040, flags=4 }
(I) sc_rt_sigaction[0]: sig=33, act=0x1fbfffb7b0, oldact=0x00000000, sigsetsize=8.
(I) sc_rt_sigaction[0]: act{ sa_handler:216d010, flags=10000004 }
(I) sc_rt_sigprocmask[0]: how=1 set=1fbfffb9d8 oldset=0
(I) sc_ugetrlimit[0]: resource=3, rlp=0x0000001fbfffb9c0
(I) sc_brk[0]: brk_val=r3=0x1f870223c8
(I) sc_brk[0]: brk_val=0x1f870223c8, returning 0x1f870223c8.
(I) sc_brk[0]: brk_val=r3=0x1f87023000
(I) sc_brk[0]: brk_val=0x1f87023000, returning 0x1f87023000.
(I) sc_futex[0]: op(129)=WAKE, uaddr=22904a4, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x01dc8980 val3=0x01dc8970.
(I) sc_GET_PERSONALITY[0]: dst=0x0000000002257b48, size=176.
(I) sc_statfs[0.0:1]: pathname="/dev/shm/", buf=0x1fbfffabd8
(I) sc_futex[0]: op(129)=WAKE, uaddr=228c418, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x00000000 val3=0x00000000.
(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-global-shmem", flags=0x000880c2 mode=(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-global-shmem", flags=0x00088002 mode=(I) sc_fcntl[0.0:1]: fd=3, cmd=1, parm3=0x0
(I) sc_ftruncate[0.0:1]: fd=3, len=389256
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x0005f088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
(I) sc_mmap[0]: Returning 0x31c3000000 for len=0x0005f088 fd=0x3.
(I) sc_close[0.0:1]: fd=3
(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-global-shmem-a", flags=0x000880c2 mode=(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-global-shmem-a", flags=0x00088002 mode=(I) sc_ftruncate[0.0:1]: fd=3, len=217984
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00035380, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
(I) sc_mmap[0]: Returning 0x31c3060000 for len=0x00035380 fd=0x3.
(I) sc_open[0.0:1]: pathname="/dev/shm/unique-comm-agent-shmem-file", flags=0x00088042 mode=(I) sc_ioctl[0.0:1]: fd=3, cmd=3221529856
(I) sc_ftruncate[0.0:1]: fd=3, len=65536
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00010000, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
(I) sc_mmap[0]: Returning 0x31c5000000 for len=0x00010000 fd=0x3.
(I) sc_open[0.0:1]: pathname="/dev/shm/job0-L2AtomicFactory-shared", flags=0x000880c2 mode=(I) sc_open[0.0:1]: pathname="/dev/shm/job0-L2AtomicFactory-shared", flags=0x00088002 mode=(I) sc_ioctl[0.0:1]: fd=4, cmd=3221529856
(I) sc_ftruncate[0.0:1]: fd=4, len=1081480
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00108088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
(I) sc_mmap[0]: Returning 0x31c5010000 for len=0x00108088 fd=0x4.
(I) sc_close[0.0:1]: fd=4
(I) sc_open[0.0:1]: pathname="/dev/shm/job0-unique-pami-globalRM-shmem-file", flags=0x000880c2 mode=(I) sc_open[0.0:1]: pathname="/dev/shm/job0-unique-pami-globalRM-shmem-file", flags=0x00088002 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=657988
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x000a0a44, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
(I) sc_mmap[0]: Returning 0x31c3096000 for len=0x000a0a44 fd=0x4.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=64, nfifos=1fbfffb210, fifoids=1fbfffb238.
(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=64, sg_ptr=1f8700b040, nfifos=1, fifoids=1fbfffb238, fifoAttrs=1f8700abc0.
(I) sc_brk[0]: brk_val=r3=0x1f8705c000
(I) sc_brk[0]: brk_val=0x1f8705c000, returning 0x1f8705c000.
(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=64, sg_ptr=31c3096080, nfifos=6, fifoids=1fbfffb238, fifoAttrs=1f8703f740.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=65, nfifos=1fbfffb210, fifoids=1fbfffb238.
(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=65, sg_ptr=31c3096350, nfifos=4, fifoids=1fbfffb238, fifoAttrs=1f8703f740.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=64, nbatids=1fbfffb390, batids=1fbfffb3b8.
(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=64, sg_ptr=31c3136680, nbatids=7, batids=1fbfffb3b8, system=0.
(I) sc_CFG_REC_FIFO_THRESH[0]: threshold=21845.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=0, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=0, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=0, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=1, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=1, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=1, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=2, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=2, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=2, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=3, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=3, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=3, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=4, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=4, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=4, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=5, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=5, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=5, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=6, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=6, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=6, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=7, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=7, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=7, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=8, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=8, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=8, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=9, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=9, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=9, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=10, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=10, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=10, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=11, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=11, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=11, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=12, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=12, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=12, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=13, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=13, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=13, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=14, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=14, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=14, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=15, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=15, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=15, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=16, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=16, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=16, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=17, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=17, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=17, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=18, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=18, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=18, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=19, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=19, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=19, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=20, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=20, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=20, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=21, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=21, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=21, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=22, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=22, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=22, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=23, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=23, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=23, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=24, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=24, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=24, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=25, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=25, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=25, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=26, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=26, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=26, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=27, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=27, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=27, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=28, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=28, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=28, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=29, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=29, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=29, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=30, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=30, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=30, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=31, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=31, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=31, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=32, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=32, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=32, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=33, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=33, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=33, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=34, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=34, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=34, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=35, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=35, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=35, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=36, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=36, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=36, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=37, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=37, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=37, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=38, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=38, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=38, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=39, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=39, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=39, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=40, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=40, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=40, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=41, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=41, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=41, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=42, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=42, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=42, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=43, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=43, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=43, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=44, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=44, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=44, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=45, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=45, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=45, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=46, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=46, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=46, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=47, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=47, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=47, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=48, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=48, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=48, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=49, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=49, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=49, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=50, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=50, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=50, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=51, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=51, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=51, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=52, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=52, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=52, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=53, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=53, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=53, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=54, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=54, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=54, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=55, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=55, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=55, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=56, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=56, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=56, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=57, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=57, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=57, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=58, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=58, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=58, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=59, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=59, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=59, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=60, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=60, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=60, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=61, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=61, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=61, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=62, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=62, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=62, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=63, nfifos=1fbfffb508, fifoids=1fbfffb520.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=63, nfifos=1fbfffb508, fifoids=1fbfffb510.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=63, nbatids=1fbfffb508, batids=1fbfffb540.
(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-client-MPI", flags=0x000880c2 mode=(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-client-MPI", flags=0x00088002 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=4194440
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00400088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
(I) sc_mmap[0]: Returning 0x31c5119000 for len=0x00400088 fd=0x4.
(I) sc_brk[0]: brk_val=r3=0x1f8708b000
(I) sc_brk[0]: brk_val=0x1f8708b000, returning 0x1f8708b000.
(I) sc_brk[0]: brk_val=r3=0x1f870ad000
(I) sc_brk[0]: brk_val=0x1f870ad000, returning 0x1f870ad000.
(I) sc_brk[0]: brk_val=r3=0x1f870ce000
(I) sc_brk[0]: brk_val=0x1f870ce000, returning 0x1f870ce000.
(I) sc_brk[0]: brk_val=r3=0x1f870fe000
(I) sc_brk[0]: brk_val=0x1f870fe000, returning 0x1f870fe000.
(I) sc_brk[0]: brk_val=r3=0x1f8712e000
(I) sc_brk[0]: brk_val=0x1f8712e000, returning 0x1f8712e000.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=0, nfifos=1fbfffaa68, fifoids=1fbfffaa90.
(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=0, sg_ptr=1f8706c2e0, nfifos=8, fifoids=1fbfffaa90, fifoAttrs=1f8710d1c0.
(I) sc_CFG_INJ_FIFO_INTS[0]: sg_ptr=1f8706c2e0, nfifos=8, fifoids=1fbfffaa90, fifoInterrupts=1f8710d1c0.
(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=1, nfifos=1fbfffaa68, fifoids=1fbfffaa90.
(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=1, sg_ptr=1f8706c5b0, nfifos=2, fifoids=1fbfffaa90, fifoAttrs=1f870fd0e0.
(I) sc_CFG_INJ_FIFO_INTS[0]: sg_ptr=1f8706c5b0, nfifos=2, fifoids=1fbfffaa90, fifoInterrupts=1f870fd0e0.
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00101000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
(I) sc_mmap[0]: Brk: 0x1f87000000 - 0x1f871fffff. MMap: 0x1f87200000 - 0x1fbfb00000.
(I) sc_mmap[0]: Returning 0x1f87200000 for len=0x00101000.
(I) sc_QUERY_REC_FIFOS[0]: subgrpid=0, nfifos=1fbfffaa68, fifoids=1fbfffaa90.
(I) sc_ALLOCATE_REC_FIFOS[0]: subgrpid=0, sg_ptr=1f8710d1c0, nfifos=1, fifoids=1fbfffaa90, fifoAttrs=1f8709cf60.
(I) sc_CFG_REC_FIFO_INTS[0]: sg_ptr=1f8710d1c0, nfifos=1, fifoids=1fbfffaa90, fifoInterrupts=1f8709cf60.
(I) sc_REC_FIFO_ENABLE[0]: groupid=0, enableBitsr=0000000000008000.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=0, nbatids=1fbfffaa68, batids=1fbfffaa90.
(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=0, sg_ptr=1f8710f860, nbatids=8, batids=1fbfffaa90, system=0.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=1, nbatids=1fbfffaa68, batids=1fbfffaa90.
(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=1, sg_ptr=1f8710f8b0, nbatids=8, batids=1fbfffaa90, system=0.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=2, nbatids=1fbfffaa68, batids=1fbfffaa90.
(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=2, sg_ptr=1f8710f900, nbatids=8, batids=1fbfffaa90, system=0.
(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=3, nbatids=1fbfffaa68, batids=1fbfffaa90.
(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=3, sg_ptr=1f8710f950, nbatids=8, batids=1fbfffaa90, system=0.
(I) sc_brk[0]: brk_val=r3=0x1f87150000
(I) sc_brk[0]: brk_val=0x1f87150000, returning 0x1f87150000.
(I) sc_brk[0]: brk_val=r3=0x1f87190000
(I) sc_brk[0]: brk_val=0x1f87190000, returning 0x1f87190000.
(I) sc_brk[0]: brk_val=r3=0x1f871d0000
(I) sc_brk[0]: brk_val=0x1f871d0000, returning 0x1f871d0000.
(I) sc_brk[0]: brk_val=r3=0x1f87210000
(I) sc_brk[0]: brk_val=0x1f87210000, returning 0x1f871d0000.
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00800000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f87200000, MMap_End=0x0000001fbfb00000.
(I) sc_mmap[0]: Returning 0x1f87301000 for len=0x00800000.
(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-clt0-ctx-mm", flags=0x000880c2 mode=(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-clt0-ctx-mm", flags=0x00088002 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=138376
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00021c88, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000001f87200000, MMap_End=0x0000001fbfb00000.
(I) sc_mmap[0]: Returning 0x31c3137000 for len=0x00021c88 fd=0x4.
(I) sc_open[0.0:1]: pathname="log.lammps", flags=0x00000241 mode=(I) sc_open[0.0:1]: pathname="input.lammps", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=1, buf=0x1fbfffaab0
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00010000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f87200000, MMap_End=0x0000001fbfb00000.
(I) sc_mmap[0]: Returning 0x1f87b01000 for len=0x00010000.
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=21
(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffaab0
(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00040000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f87200000, MMap_End=0x0000001fbfb00000.
(I) sc_mmap[0]: Returning 0x1f87b11000 for len=0x00040000.
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=67
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=40
(I) sc_fstat[0.0:1]: fd=5, buf=0x1fbfffb490
(I) sc_mmap[0]: Returning 0x1f87b51000 for len=0x00040000.
(I) sc_read[0.0:1]: fd=5, buf=0x1f87b51000, cnt=262144
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=22
(I) sc_open[0.0:1]: pathname="AuTiO.geo", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=6, buf=0x1fbfff9e10
(I) sc_mmap[0]: Returning 0x1f87b91000 for len=0x00040000.
(I) sc_read[0.0:1]: fd=6, buf=0x1f87b91000, cnt=262144
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=51
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=34
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=11
(I) sc_close[0.0:1]: fd=6
(I) sc_munmap[0]: start=0x1f87b91000, len=0x00040000.
(I) sc_open[0.0:1]: pathname="Au_u3.eam", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=6, buf=0x1fbfff9ad0
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=23
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=26
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=25
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=79
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=28
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=44
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=37
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=105
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=84
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=20
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=41
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=61
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=52
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=57
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=63
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=36
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=35
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=33
(I) sc_write[0.0:1]: fd=4, buf=0x1f87b11000, cnt=4840
(I) sc_open[0.0:1]: pathname="lammps.dump", flags=0x00000241 mode=(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=19
(I) sc_fstat[0.0:1]: fd=6, buf=0x1fbfff9650
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1576
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1587
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1592
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1601
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1593
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1591
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1590
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1588
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1600
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1595
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1584
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1585
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1580
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1582
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1581
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1586
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1583
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1578
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1579
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1589
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1594
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=86
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=38
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=27
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=29
(I) sc_write[0.0:1]: fd=4, buf=0x1f87b11000, cnt=211494
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=43
(I) sc_write[0.0:1]: fd=4, buf=0x1f87b11000, cnt=210896
(I) sc_write[0.0:1]: fd=6, buf=0x1f87b91000, cnt=1577
(I) sc_write[0.0:1]: fd=4, buf=0x1f87b11000, cnt=262144
(I) sc_open[0.0:1]: pathname="res.1000000", flags=0x00000241 mode=(I) sc_fstat[0.0:1]: fd=7, buf=0x1fbfff9bd0
(I) sc_mmap[0]: Returning 0x1f87bd1000 for len=0x00040000.
(I) sc_write[0.0:1]: fd=7, buf=0x1f87bd1000, cnt=3446
(I) sc_close[0.0:1]: fd=7
(I) sc_munmap[0]: start=0x1f87bd1000, len=0x00040000.
(I) sc_open[0.0:1]: pathname="res.2000000", flags=0x00000241 mode=(I) sc_fstat[0.0:1]: fd=7, buf=0x1fbfff9bd0
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=87
(I) sc_write[0.0:1]: fd=1, buf=0x1f87b01000, cnt=30
(I) sc_write[0.0:1]: fd=4, buf=0x1f87b11000, cnt=3739
(I) sc_close[0.0:1]: fd=5
(I) sc_munmap[0]: start=0x1f87b51000, len=0x00040000.
(I) sc_munmap[0]: start=0x1f87b11000, len=0x00040000.
(I) sc_exit_group[ 0:0]: status = 0.
2014-12-08 19:22:26.741 (INFO ) [0xfffaa45bde0] CET-40000-51331-128:900136:ibm.runjob.client.Job: exited with status 0
2014-12-08 19:22:26.741 (INFO ) [0xfffaa45bde0] tatu.runjob.client: task exited with status 0
2014-12-08 19:22:26.741 (INFO ) [0xfffac5634e0] 12249:tatu.runjob.monitor: monitor terminating
2014-12-08 19:22:26.746 (INFO ) [0xfffaa45bde0] tatu.runjob.client: monitor completed
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20141208/310f9e29/attachment.obj>
