[Swift-devel] error building swift trunk on bluegene
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Aug 23 17:02:45 CDT 2014
That particular issue should now be fixed in trunk.  I'm able to build
swift with the ibm libraries (although within eclipse, so please give
this a shot in a real environment).
Mihael
On Fri, 2014-08-22 at 13:44 -0500, Ketan Maheshwari wrote:
> PS. The current java is from IBM:
> $ java -version
> java version "1.6.0"
> Java(TM) SE Runtime Environment (build pxp6460sr15-20131017_01(SR15))
> IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 Linux ppc64-64
> jvmxp6460sr15-20131016_170922 (JIT enabled, AOT enabled)
> J9VM - 20131016_170922
> JIT  - r9_20130920_46510ifx2
> GC   - GA24_Java6_SR15_20131016_1337_B170922)
> JCL  - 20131015_01
> On Fri, Aug 22, 2014 at 1:41 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> > Hi,
> > I am getting this error trying to build Swift trunk on BG Vesta:
> > compile:
> >      [echo] [util]: COMPILE
> >     [mkdir] Created dir:
> > /gpfs/vesta-home/ketan/swift-devel/cog/modules/util/build
> >     [javac] Compiling 56 source files to
> >     [javac]
> > /gpfs/vesta-home/ketan/swift-devel/cog/modules/util/src/org/globus/cog/util/concurrent/FileLock.java:91:
> > cannot find symbol
> >     [javac] symbol  : class VMManagement
> >     [javac] location: package sun.management
> >     [javac]         sun.management.VMManagement mgmt =
> > (sun.management.VMManagement) jvm.get(runtime);
> >     [javac]                       ^
> >     [javac]
> > cannot find symbol
> >     [javac]                                                           ^
> >     [javac] Note: Some input files use or override a deprecated API.
> >     [javac] Note: Recompile with -Xlint:deprecation for details.
> >     [javac] Note: Some input files use unchecked or unsafe operations.
> >     [javac] Note: Recompile with -Xlint:unchecked for details.
> >     [javac] 2 errors
> > Doe this means I need sun java on Vesta? Does anyone know if Sun java is
> > available for PPC64 architecture?
> > Thanks,
> > Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
