[Swift-devel] New built-in system, request for comments
Ketan Maheshwari ketan at mcs.anl.gov
Fri Apr 4 22:58:27 CDT 2014
Is it possible to handle stdout and/or stderr of system("command")
separately? That way, it might be useful in other places as well.
On Fri, Apr 4, 2014 at 12:08 PM, Yadu Nand <yadudoc1729 at gmail.com> wrote:
> Hi,
> I have just added a new builtin "system" to trunk. It takes a string,
> which is executed in the shell
> by java and the results are returned as an array. This is done to make
> mappings easier, for example,
> you can map an entire folder "foo" using the following :
> file folder[ ] < array_mapper; files = system ("find foo -type f") >;
> If the execution of the string provided fails, the logger would report
> the the exitcode and stderr to
> the swift stdout.
> Thanks,
> Yadu Nand B
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140404/3edecf82/attachment.html>
