[Swift-devel] How can I reduce log file size?
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Apr  3 21:02:48 CDT 2014
minimal.logging should be the one doing the trick, but if that fails...
everything is ultimately configured through log4j. So it's between
log4j.properties and Loader.java who overrides some logging options
based on command line arguments.
You could, for example, try to set a threshold of WARN for the file
appender in log4j.properties and make sure that Loader doesn't mess with
that.
Mihael
On Thu, 2014-04-03 at 16:59 -0500, David Kelly wrote:
> I'm running a script in 0.94.1 that generates a large log file. The script
> only runs 41 tasks and finishes in under 5 minutes, but the log file is 2.7
> gigabytes.
> I have:
> provenance.log=false
> tracing.enabled=false
> I've tried "-minimal.logging" and "-reduced.logging" but it doesn't make
> much of a difference.
> What else can I do to reduce the log file size? I'm running Swift from a
> module so I can't easily edit any swift-wide log4j settings.
> The log is at
> http://web.ci.uchicago.edu/~davidk/logs/combine-20140403-2122-csdnssc1.log.gz(17mb
> compressed, 2.7 gigabytes uncompressed)
> Thanks,
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
