[Swift-devel] ssh-cl how to tell coaster bootstrap to run with limited java heap space
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Sep 19 17:10:16 CDT 2013
Changing the line to 256M and rebuilding Swift somehow did not have any
effect on the run. I agree, an ability to run coaster service on compute
node will help. XSEDE Stampede also has the same and other constraints in
place.
On Thu, Sep 19, 2013 at 3:56 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> The coaster bootstrap starts the service with 512M on 64 bit machines.
> It can be changed in the code:
> org.globus.cog.abstraction.impl.execution.coaster.bootstrap.Bootstrap.java,
> line 191. The other solution is to run the service on a compute node, but I
> don't think we ever spent enough effort on nailing that issue down. Maybe
> it's time to do so.
> On Thu, 2013-09-19 at 15:53 -0500, Ketan Maheshwari wrote:
> > Yes, 64 bit running CentOS release 6.4
> > On Thu, Sep 19, 2013 at 3:48 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> > > Are the login nodes 64 bit by any chance?
> > > On Thu, 2013-09-19 at 15:43 -0500, Ketan Maheshwari wrote:
> > > > SDSC Gordon admins have limited java heap space to 256 on login
> nodes.
> > > > This is enabled via the following environment variable:
> > > > JAVA_TOOL_OPTIONS=-Xmx256m
> > > > It seems coaster bootstrap does not like this:
> > > > mdw$ swift -sites.file sites.gordon.xml -tc.file apps -config cf
> > > > workflow.swift
> > > > Swift trunk swift-r7089 cog-r3775
> > > > RunID: 20130919-2038-jef0ns83
> > > > Progress:  time: Thu, 19 Sep 2013 20:38:42 +0000
> > > > Progress:  time: Thu, 19 Sep 2013 20:38:43 +0000  Submitting:2
> > > > Execution failed:
> > > > Exception in matrixgen:
> > > >     Arguments: [2544, 3300, mA.dat]
> > > >     Host: gordon
> > > >     Directory:
> workflow-20130919-2038-jef0ns83/jobs/a/matrixgen-a1rnkhfl
> > > >     exception @ swift-int-staging.k, line: 162
> > > > Caused by: null
> > > > Caused by:
> > > > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > > Could
> > > > not submit job
> > > > Caused by:
> > > Could
> > > > not start coaster service
> > > > Caused by:
> Task
> > > > ended before registration was received.
> > > > Picked up JAVA_TOOL_OPTIONS: -Xmx256m
> > > > /bin/bash: line 54: 33675 Aborted
> > > /usr/java/latest/bin/java
> > > > -Djava=/usr/java/latest/bin/java -DGLOBUS_TCP_PORT_RANGE=50000,51000
> > > > -DX509_USER_PROXY=/home/ketan/.globus/sshproxy-316831905-1379663604
> -DX509_CERT_DIR=/home/ketan/.globus/sshCAcert-316831905-1379663604.pem
> > > > -DGLOBUS_HOSTNAME=gordon.sdsc.xsede.org -Duser.home=/home/ketan -jar
> > > > /tmp/bootstrap.RWIqFu http://swift.rcc.uchicago.edu:50001
> > > > https://128.135.112.73:50000 11836079986
> > > > Do I understand right that this is indeed the java heap space issue?
> or
> > > is
> > > > it something else that I could work around with? Thanks for any
> ideas.
> nodes.
> > > > workflow.swift
> > > > Execution failed:
> > > >     Host: gordon
> > > >     Directory:
> > > > Caused by: null
> > > > Caused by:
> > > > Could not submit job
> > > > Caused by:
> > > > Could not start coaster service
> > > > Caused by:
> > > > Task ended before registration was received.
> > > > Aborted                 /usr/java/latest/bin/java
> > > > -jar /tmp/bootstrap.RWIqFu http://swift.rcc.uchicago.edu:50001
> > > > or is it something else that I could work around with? Thanks for any
> > > > ideas.
> > > > Ketan
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >         login nodes.
> >         -config cf
> >         > workflow.swift
> >          Submitting:2
> >         > Execution failed:
> >         >     Host: gordon
> >         >     Directory:
> >         > Caused by: null
> >         > Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could
> >         > not submit job
> >         > Caused by:
> >         > Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Task
> >         space issue? or is
> >         any ideas.
> >         login nodes.
> >         -config cf
> >         > workflow.swift
> >          Submitting:2
> >         > Execution failed:
> >         >     Host: gordon
> >         >     Directory:
> >         > Caused by: null
> >         > Caused by:
> >         > Caused by:
> >         > Caused by:
> >         space issue?
> >         Thanks for any
> >         > ideas.
> >         > Ketan
> > Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130919/b19af549/attachment.html>
