[Swift-devel] ssh-cl how to tell coaster bootstrap to run with limited java heap space
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Sep 19 15:53:00 CDT 2013
Yes, 64 bit running CentOS release 6.4
On Thu, Sep 19, 2013 at 3:48 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Are the login nodes 64 bit by any chance?
> On Thu, 2013-09-19 at 15:43 -0500, Ketan Maheshwari wrote:
> > SDSC Gordon admins have limited java heap space to 256 on login nodes.
> > This is enabled via the following environment variable:
> > JAVA_TOOL_OPTIONS=-Xmx256m
> > It seems coaster bootstrap does not like this:
> > mdw$ swift -sites.file sites.gordon.xml -tc.file apps -config cf
> > workflow.swift
> > Swift trunk swift-r7089 cog-r3775
> > RunID: 20130919-2038-jef0ns83
> > Progress:  time: Thu, 19 Sep 2013 20:38:42 +0000
> > Progress:  time: Thu, 19 Sep 2013 20:38:43 +0000  Submitting:2
> > Execution failed:
> > Exception in matrixgen:
> >     Arguments: [2544, 3300, mA.dat]
> >     Host: gordon
> >     Directory: workflow-20130919-2038-jef0ns83/jobs/a/matrixgen-a1rnkhfl
> >     exception @ swift-int-staging.k, line: 162
> > Caused by: null
> > Caused by:
> > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Could
> > not submit job
> > Caused by:
> Could
> > not start coaster service
> > Caused by:
> > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Task
> > ended before registration was received.
> > Picked up JAVA_TOOL_OPTIONS: -Xmx256m
> > /bin/bash: line 54: 33675 Aborted
> /usr/java/latest/bin/java
> > -Djava=/usr/java/latest/bin/java -DGLOBUS_TCP_PORT_RANGE=50000,51000
> > -DX509_USER_PROXY=/home/ketan/.globus/sshproxy-316831905-1379663604
> > -DX509_CERT_DIR=/home/ketan/.globus/sshCAcert-316831905-1379663604.pem
> > -DGLOBUS_HOSTNAME=gordon.sdsc.xsede.org -Duser.home=/home/ketan -jar
> > /tmp/bootstrap.RWIqFu http://swift.rcc.uchicago.edu:50001
> > https://128.135.112.73:50000 11836079986
> > Do I understand right that this is indeed the java heap space issue? or
> is
> > it something else that I could work around with? Thanks for any ideas.
> > workflow.swift
> > Execution failed:
> >     Host: gordon
> >     Directory:
> > Caused by: null
> > Caused by:
> > Could not submit job
> > Caused by:
> > Could not start coaster service
> > Caused by:
> > Task ended before registration was received.
> > Aborted                 /usr/java/latest/bin/java
> > -jar /tmp/bootstrap.RWIqFu http://swift.rcc.uchicago.edu:50001
> > or is it something else that I could work around with? Thanks for any
> > ideas.
> > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130919/dbcb98fc/attachment.html>
