[Swift-devel] iterate fails
Mihael Hategan
hategan at mcs.anl.gov
Mon Sep 16 13:52:32 CDT 2013
I can confirm that this is an issue with write reference counting in
trunk. I'm working on it.
On Mon, 2013-09-16 at 11:29 -0500, Michael Wilde wrote:
> If this is indeed failing on trunk, hopefully the test suite will see the same thing.
> Yadu, can you look into this and file a ticket if its indeed a trunk bug?
> Thanks,
> - Mike
> > From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Monday, September 16, 2013 11:23:54 AM
> > Subject: Re: [Swift-devel] iterate fails
> > Mike,
> > I am using the latest trunk:
> > Swift trunk swift-r7065 (swift modified locally) cog-r3782
> > On Mon, Sep 16, 2013 at 11:20 AM, Michael Wilde < wilde at mcs.anl.gov >
> > wrote:
> > Ketan, this worked for me (see below). What version of swift did you
> > run where?
> > I ran on swift.rcc, on localhost.
> > - Mike
> > swift$ swift km2.swift -data=data.txt
> > Swift 0.94.1 RC2 swift-r6895 cog-r3765
> > RunID: 20130916-1617-i570fay7
> > Progress: time: Mon, 16 Sep 2013 16:17:32 +0000
> > Final status: Mon, 16 Sep 2013 16:17:33 +0000 Finished successfully:3
> > swift$ ls -lt outdir | head
> > total 16032
> > -rw-r--r-- 1 wilde wilde 9 Sep 16 11:17 f.0002.out
> > -rw-r--r-- 1 wilde wilde 9 Sep 16 11:17 f.0001.out
> > -rw-rw-r-- 1 wilde wilde 9 Sep 16 11:17 f.0000.out
> > -rw-rw-r-- 1 wilde wilde 9 Jul 27 17:05 f.0483.out
> > -rw-rw-r-- 1 wilde wilde 9 Jul 27 17:05 f.0490.out
> > -rw-rw-r-- 1 wilde wilde 9 Jul 27 17:05 f.0488.out
> > -rw-rw-r-- 1 wilde wilde 9 Jul 27 17:05 f.0500.out
> > -rw-rw-r-- 1 wilde wilde 9 Jul 27 17:05 f.0498.out
> > -rw-rw-r-- 1 wilde wilde 9 Jul 27 17:05 f.0491.out
> > swift$ swift -version
> > swift$
> > > From: "Ketan Maheshwari" < ketancmaheshwari at gmail.com >
> > > To: "Swift Devel" < swift-devel at ci.uchicago.edu >
> > > Sent: Monday, September 16, 2013 10:49:07 AM
> > > Subject: [Swift-devel] iterate fails
> > > Hi,
> > > I am trying a catsn example with foreach replaced by iterate as
> > > follows:
> > > type file;
> > > app (file o) cat (file i) {
> > > cat @i stdout=@o;
> > > file out[]<simple_mapper; location="outdir",
> > > prefix="f.",suffix=".out">;
> > > string d=@arg("data");
> > > #foreach j in [1:1000] {
> > > iterate j {
> > > file data<single_file_mapper; file=d>;
> > > out[j] = cat(data);
> > > } until (j==3);
> > > The run fails with error message as follows:
> > > $ swift -tc.file tc -config cf -sites.file sites.xml catsn.swift
> > > -data=data.txt
> > > RunID: 20130916-1045-tldyyexe
> > > Progress: time: Mon, 16 Sep 2013 10:45:41 -0500
> > > Execution failed:
> > > org.griphyn.vdl.mapping.InvalidPathException: Array index '[2]' not
> > > found for out of size 2
> > > swift:getFieldSubscript @ catsn, line: 93
> > > Caused by: org.griphyn.vdl.mapping.InvalidPathException: Array
> > > index
> > > '[2]' not found for out of size 2
> > > Any suggestions?
> > > Thanks,
> > > Ketan
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Ketan
