[Swift-devel] Wrapper staging
David Kelly
davidk at ci.uchicago.edu
Thu May 16 13:42:41 CDT 2013
I'd like to find a way to define different staging methods on a file-by-file basis. In some cases it would make sense to use dd to copy a file to the work directory. In other situations it may be better to create a symlink pointing to what you need.
I'm thinking of something along these lines (names will probably get changed):
file data <"file-direct:///home/davidkelly999/staging/dd-absolute/data.txt">; // Will stage the data to the work directory
file data2 <"file-indirect:///home/davidkelly999/staging/dd-absolute/data2.txt">; // Will create a symlink
Then based on the prefix you define, _swiftwrap.wrapperstaging can know exactly how to stage the file.
Is it possible to create data provider aliases, making file-direct:// and file-indirect:// work exactly like file:// until it gets passed to the wrapper?
David
----- Original Message -----
To: "David Kelly" <davidk at ci.uchicago.edu>
Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
Sent: Wednesday, May 8, 2013 12:46:45 PM
Subject: Re: Wrapper staging
I'm a bit busy today and this week, so I might not get to fixing these
until the weekend, but I'll try to answer some of your questions.
On Wed, 2013-05-08 at 10:53 -0500, David Kelly wrote:
> Hello,
> Just a few random questions about wrapper staging:
> How can I make gsiftp:// URIs get sent to _swiftwrap.wrapperstaging? I
> have wrapper staging enabled, but Swift is trying to connect to the
> server and retrieve the file, rather than just passing the URI to the
> wrapper script.
With wrapper staging enabled, swift should not try to *transfer* files,
but mappers might connect to the server to figure out what files are
there (i.e. to complete calls to Mapper.existing()).
> What does the property wrapper.staging.local.server do?
It specifies what url prefix to pass to the wrapper for local files
(i.e. accessible directly by swift).
> From within _swiftwrap.wrapperstaging, how can I know the current
> working directory of the user? I think I need this information to
> handle relative path names.
The wrapper should get a -urlprefix argument containing the CWD. The
value of that arg is constructed as: ${wrapper.staging.local.server} +
${CWD}.
> I believe in trunk, filenames passed as arguments to Swift apps being
> prepended with "__root__". What does this mean, and should swiftwrap
> strip this out?
No. There is a mapping from local file names to remote file names. It
used to be that absolute files are mapped simply by removing the leading
slash. So "/dir/file" on the swift side would become "dir/file" on the
remote side. But then if there was a local "dir/file", it would also be
"dir/file" on the remote side, causing a conflict.
At some point in trunk, I changed that (and also the handling of "/../")
in response to a bug that, I believe, Ketan submitted. The change
involved mapping a leading slash to "__root__" and parent dir references
to "__parent__". They have no special meaning as far as the wrapper or
the application is concerned. They get the proper path through @filename
and the likes, and swift stages the files in the places pointed by
@filename.
Mihael
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130516/8160e9c9/attachment.html>
