[Swift-devel] MODIS freezes on Midway
Yadu Nand yadudoc1729 at gmail.com
Tue Mar 26 11:18:20 CDT 2013
I think I've found the reason for the modis tests failing on beagle.
I had no default project set on beagle. The jobs go through once I've set
the
projects to :
CI-CCR000013 Michael Wilde           The Swift Parallel Scripting System
-Thanks,
Yadu
On Thu, Mar 21, 2013 at 11:16 PM, Ketan Maheshwari <
ketancmaheshwari at gmail.com> wrote:
> Yadu,
> netcat/nc has been helpful in the past resolving network/port connectivity
> issues. I tried to write to midway port 50000 from beagle which worked:
> on midway:
> $ nc -l 50000
> on beagle:
> $ netcat 128.135.112.71 50000
> hello from beagle
> Gives on midway:
> $ nc -l 50000
> hello from beagle
> Hope this helps with debugging.
>  On Thu, Mar 21, 2013 at 12:31 PM, Yadu Nand <yadudoc1729 at gmail.com>wrote:
>>  @Ketan, I believe I spoke too early yesterday about
>> /lustre/beagle/yadunand folder.
>> The error, No such file or directory went away after yadunand/swiftwork
>> directory was
>> created manually.
>> @Mihael, I think it would really help if the directory creation could be
>> handled by swift.
>> Yesterday, I tried some things David asked me to try setting the
>> following :
>> GLOBUS_HOSTNAME=128.135.112.73
>> GLOBUS_TCP_PORT_RANGE=50000,51000
>> The issue here as I understood it, is that, the workers on beagle try to
>> connect back
>> to midway to access the files, and the IP resolves to internal IP which
>> it can't access.
>> This is happening despite setting the GLOBUS_HOSTNAME explicitly. Even
>> the port
>> range that I've set does not seem to be used:
>> Failed to start channel GSSCChannel-https://192.5.86.107:60851(2)[
>> https://192.5.86.107:60851]
>> I'm also attaching a log from the beagle run.
>> The files used for the run are on
>> midway /home/yadunand/swiftdemo-trunk/test.beagle
>> -Yadu
>> On Thu, Mar 21, 2013 at 2:29 AM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
>>> On Wed, 2013-03-20 at 15:05 -0500, Michael Wilde wrote:
>>> > Yadu, I dont think the beagle test requires you to have any
>>> directories on beagle.
>>> We do the SWIFT_USERHOME thing on beagle, and that requires the modified
>>> user home to exist I think.
>>> Might be possible to attempt to create that directory automatically.
>>> Mihael
>> Yadu Nand B
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Ketan
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130326/c2cacfba/attachment.html>
