[Swift-devel] MODIS freezes on Midway
Yadu Nand
yadudoc1729 at gmail.com
Tue Mar 19 17:35:41 CDT 2013
I've been running the modis tests on Midway, from the demo that mike had
shared:
/home/wilde/osgdemo/modis/svn/swiftdemo.v04.tgz
In the logs(please see attachment) I see a fail message : "sbatch: error:
Batch job
submission failed: Requested reservation is invalid"
The fact that no error messages are shown on stdout doesn't help, plus,
swift just
seems to hang forever. * Please help! *
I see test.midway show no progress, with just the same status for about
20mins:
Progress: time: Tue, 19 Mar 2013 20:21:18 +0000 Selecting site:35
Submitted:65
After this, I tried to kill by Ctrl+C and then I get a few error messages :
Failed to shut down block: Block 0319-5807480-000000 (16x3540.000s)
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Can
only cancel an active task
at
org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.cancel(AbstractExecutor.java:196)
at
org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.cancel(AbstractJobSubmissionTaskHandler.java:85)
at
org.globus.cog.abstraction.impl.common.AbstractTaskHandler.cancel(AbstractTaskHandler.java:69)
at
org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:106)
at
org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:95)
at
org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.cancel(BlockTaskSubmitter.java:46)
at
org.globus.cog.abstraction.coaster.service.job.manager.Block.forceShutdown(Block.java:332)
at
org.globus.cog.abstraction.coaster.service.job.manager.Block.shutdown(Block.java:312)
at
org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdownBlocks(BlockQueueProcessor.java:800)
at
org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdown(BlockQueueProcessor.java:789)
at
org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.shutdown(JobQueue.java:119)
at
org.globus.cog.abstraction.coaster.service.CoasterService.shutdown(CoasterService.java:271)
at
org.globus.cog.abstraction.coaster.service.ServiceShutdownHandler.requestComplete(ServiceShutdownHandler.java:28)
at
org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
at
org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:519)
at
org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:86)
at
org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:115)
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130320/cc3f30b2/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130320/cc3f30b2/attachment.obj>
