[Swift-devel] Nested loops misbehaving [0.94 & Faster]
Mihael Hategan
hategan at mcs.anl.gov
Mon Mar 11 14:54:10 CDT 2013
Wait, do we really have "iterate {} until (cond)" loop around WHILE the
condition is true?
On Mon, 2013-03-11 at 20:23 +0530, Yadu Nand wrote:
> Oops. My mistake. Script work fine after correction.
> Thanks Tim :)
> -Yadu
> On Mon, Mar 11, 2013 at 8:09 PM, Tim Armstrong
> <tim.g.armstrong at gmail.com> wrote:
> > For 0.94, isn't it correct that it prints each combination 10 times because
> > of the 6th innermost foreach loop?
> > On Mon, Mar 11, 2013 at 9:16 AM, Yadu Nand <yadudoc1729 at gmail.com> wrote:
> >> Hi,
> >> I have 5 loops (foreach and iterate mixed) and I see indices repeating in
> >> the
> >> innermost loop body. This is causing the script to crash as the array
> >> content
> >> is already closed. This was run on 0.94 (rev 6364).
> >> On swift-faster this script fails to compile (I don't see any issue
> >> with the script,
> >> especially when it compiles and run on 0.94)
> >> I could have this checked for other nested loop combinations if that could
> >> help.
> >> The script and output are attached.
> >> Regards,
> >> Yadu Nand B
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
