[Swift-devel] Java versions for testing - Re: Cant get auto-coasters to run from midway to beagle
Michael Wilde wilde at mcs.anl.gov
Sun Mar 10 11:23:04 CDT 2013
OK, thats good to know. But note that we've seen cases where Swift failed on a specific Oracle Java 1.6 build, due to the behavior of some esoteric class.  So testing on both OpenJDK and Oracle still makes sense, and even more importantly, telling the user what specific Java release a given Swift revision was tested under will help eliminate some variables affecting reliability.
- Mike
----- Original Message -----
> From: "Tim Armstrong" <tim.g.armstrong at gmail.com>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Sunday, March 10, 2013 11:10:45 AM
> Subject: Re: [Swift-devel] Java versions for testing - Re: Cant get auto-coasters to run from midway to beagle
> YMMV but for other projects I've not found any compatibility issues
> between OpenJDK and Oracle's java - their codebases are mostly the
> same anyway now. I don't think there are really any other open
> source jdks in wide use (GCJ is pretty much a dead project, about a
> decade behind the Java standard).
> - Tim
> On Sun, Mar 10, 2013 at 11:05 AM, Michael Wilde < wilde at mcs.anl.gov >
> wrote:
> Good point, Ketan. We should document this on the site guide for
> Beagle.
> We should also file a bug to fix this some day (ie find out why we
> dont work well with this java and if possible fix it. But thats very
> low prio; for now we want to make sure all Swift users run on Sun
> Java 1.7.
> I had sun java in my .modules file. Mihael has now added the -l flag
> to make sure that automatic coaster bootstrap runs the user's init
> to pick up such things.
> Yadu, this raises another issue for the test plan and suite: testing
> on multiple Javas and carefully deciding and controlling the Java we
> use. More important than this esoteric Cray IBM Java is validating
> Swift on popular open source Javas.
> - Mike
> > From: "Ketan Maheshwari" < ketancmaheshwari at gmail.com >
> > To: "Mihael Hategan" < hategan at mcs.anl.gov >
> > Cc: "Michael Wilde" < wilde at mcs.anl.gov >, "Swift Devel" <
> > swift-devel at ci.uchicago.edu >
> > Sent: Saturday, March 9, 2013 8:24:56 PM
> > Subject: Re: [Swift-devel] Cant get auto-coasters to run from
> > midway to beagle
> > IBM jdk on beagle is known to not function well with Swift
> > coasters.
> > We had to switch to Sun jdk for ssh:pbs runs from
> > bridled/communicado.
> > On Sat, Mar 9, 2013 at 7:43 PM, Mihael Hategan <
> > > wrote:
> > I noticed some random weirdness due to the fact that the coaster
> > service
> > runs with the ibm jdk.
> > I'll run some tests with both and see what happens.
> > Mihael
> > On Sat, 2013-03-09 at 17:49 -0600, Michael Wilde wrote:
> > > An update on this provider staging related issue: reducing
> > > filesize
> > > from 17MB to 600KB runs well.
> > > So seems like some kind of flow control or buffer management
> > > problem, possibly?
> > > May need to take that problem offline - would be a perfect test
> > > case for Yadu to develop a new stress test for.
> > > - Mike
> > > ----- Forwarded Message -----
> > > From: "Michael Wilde" < wilde at mcs.anl.gov >
> > > To: "David Kelly" < davidk at ci.uchicago.edu >
> > > Sent: Saturday, March 9, 2013 5:21:49 PM
> > > Subject: Re: runs for OSG talk
> > > OK, much better: with 600K files (5x5 reduction or 25X smaller)
> > > it
> > > works well, and fast (form midway to beagle!)
> > > Swift 0.94RC4 swift-r6284 cog-r3607 (cog modified locally)
> > > RunID: 20130309-2319-5zq0jrfg
> > > Progress: time: Sat, 09 Mar 2013 23:19:45 +0000
> > > Progress: time: Sat, 09 Mar 2013 23:19:56 +0000 Selecting
> > > site:269
> > > Submitting:47 Submitted:1
> > > Progress: time: Sat, 09 Mar 2013 23:20:05 +0000 Selecting
> > > site:269
> > > Stage in:1 Submitted:47
> > > Progress: time: Sat, 09 Mar 2013 23:20:09 +0000 Selecting
> > > site:269
> > > Stage in:47 Active:1
> > > Progress: time: Sat, 09 Mar 2013 23:20:10 +0000 Selecting
> > > site:269
> > > Stage in:46 Active:1 Stage out:1
> > > Progress: time: Sat, 09 Mar 2013 23:20:11 +0000 Selecting
> > > site:250
> > > Stage in:19 Active:28 Stage out:1 Finished successfully:19
> > > Progress: time: Sat, 09 Mar 2013 23:20:12 +0000 Selecting
> > > site:229
> > > Stage in:18 Submitting:21 Active:1 Stage out:7 Finished
> > > successfully:41
> > > Progress: time: Sat, 09 Mar 2013 23:20:13 +0000 Selecting
> > > site:220
> > > Stage in:41 Submitting:1 Active:5 Stage out:1 Finished
> > > successfully:49
> > > Progress: time: Sat, 09 Mar 2013 23:20:14 +0000 Selecting
> > > site:220
> > > Stage in:38 Active:1 Stage out:9 Finished successfully:49
> > > Progress: time: Sat, 09 Mar 2013 23:20:15 +0000 Selecting
> > > site:212
> > > Stage in:30 Submitting:8 Stage out:9 Finished successfully:58
> > > Progress: time: Sat, 09 Mar 2013 23:20:16 +0000 Selecting
> > > site:203
> > > Stage in:38 Submitting:8 Submitted:1 Finished successfully:67
> > > Progress: time: Sat, 09 Mar 2013 23:20:18 +0000 Selecting
> > > site:202
> > > Stage in:19 Stage out:28 Finished successfully:68
> > > Progress: time: Sat, 09 Mar 2013 23:20:19 +0000 Selecting
> > > site:172
> > > Stage in:33 Submitting:2 Submitted:6 Active:5 Stage out:2
> > > Finished
> > > successfully:97
> > > Progress: time: Sat, 09 Mar 2013 23:20:20 +0000 Selecting
> > > site:170
> > > Stage in:31 Submitting:2 Stage out:14 Finished successfully:100
> > > Progress: time: Sat, 09 Mar 2013 23:20:21 +0000 Selecting
> > > site:162
> > > Stage in:30 Submitting:10 Stage out:6 Finished successfully:109
> > > Progress: time: Sat, 09 Mar 2013 23:20:22 +0000 Selecting
> > > site:154
> > > Stage in:39 Submitting:5 Submitted:3 Active:1 Finished
> > > successfully:115
> > > Progress: time: Sat, 09 Mar 2013 23:20:23 +0000 Selecting
> > > site:154
> > > Stage in:21 Active:10 Stage out:16 Finished successfully:116
> > > Progress: time: Sat, 09 Mar 2013 23:20:24 +0000 Selecting
> > > site:126
> > > Stage in:20 Submitting:25 Submitted:1 Stage out:2 Finished
> > > successfully:143
> > > Progress: time: Sat, 09 Mar 2013 23:20:25 +0000 Selecting
> > > site:124
> > > Stage in:31 Active:2 Stage out:15 Finished successfully:145
> > > Progress: time: Sat, 09 Mar 2013 23:20:26 +0000 Selecting
> > > site:110
> > > Stage in:30 Submitting:14 Stage out:3 Finished successfully:160
> > > Progress: time: Sat, 09 Mar 2013 23:20:27 +0000 Selecting
> > > site:106
> > > Stage in:43 Submitting:1 Submitted:1 Active:1 Stage out:2
> > > Finished
> > > successfully:163
> > > Progress: time: Sat, 09 Mar 2013 23:20:28 +0000 Selecting
> > > site:104
> > > Stage in:20 Submitting:2 Active:7 Stage out:19 Finished
> > > successfully:165
> > > Progress: time: Sat, 09 Mar 2013 23:20:29 +0000 Selecting site:78
> > > Stage in:29 Submitting:16 Submitted:1 Stage out:2 Finished
> > > successfully:191
> > > Progress: time: Sat, 09 Mar 2013 23:20:31 +0000 Selecting site:76
> > > Stage in:30 Stage out:17 Finished successfully:194
> > > Progress: time: Sat, 09 Mar 2013 23:20:32 +0000 Selecting site:58
> > > Stage in:29 Submitting:18 Active:1 Finished successfully:211
> > > Progress: time: Sat, 09 Mar 2013 23:20:33 +0000 Selecting site:58
> > > Stage in:33 Active:3 Stage out:12 Finished successfully:211
> > > Progress: time: Sat, 09 Mar 2013 23:20:34 +0000 Selecting site:46
> > > Stage in:18 Submitting:11 Submitted:1 Active:2 Stage out:14
> > > Finished successfully:225
> > > Progress: time: Sat, 09 Mar 2013 23:20:35 +0000 Selecting site:30
> > > Stage in:29 Active:14 Stage out:3 Finished successfully:241
> > > Progress: time: Sat, 09 Mar 2013 23:20:36 +0000 Selecting site:28
> > > Stage in:28 Submitting:2 Stage out:17 Finished successfully:242
> > > Progress: time: Sat, 09 Mar 2013 23:20:37 +0000 Selecting site:10
> > > Stage in:30 Submitting:17 Submitted:1 Finished successfully:259
> > > Progress: time: Sat, 09 Mar 2013 23:20:38 +0000 Selecting site:10
> > > Stage in:35 Stage out:13 Finished successfully:259
> > > Progress: time: Sat, 09 Mar 2013 23:20:39 +0000 Stage in:21
> > > Submitting:6 Submitted:3 Stage out:15 Finished successfully:272
> > > Progress: time: Sat, 09 Mar 2013 23:20:40 +0000 Stage in:10
> > > Active:5 Stage out:14 Finished successfully:288
> > > Final status: Sat, 09 Mar 2013 23:20:41 +0000 Finished
> > > successfully:317
> > > real 0m58.953s
> > > user 0m32.573s
> > > sys 0m1.263s
> > > + mv /home/wilde/.swift/runs/current/run029.1362871183
> > > /home/wilde/.swift/runs/completed
> > > midway001$
> > > > From: "David Kelly" < davidk at ci.uchicago.edu >
> > > > To: "Michael Wilde" < wilde at mcs.anl.gov >
> > > > Sent: Saturday, March 9, 2013 5:12:59 PM
> > > > Yep - I had a version where the input files were in a very
> > > > similar
> > > > format (PGM, 1 byte per pixel). I'll add that back, but without
> > > > the
> > > > small PGM header in the files.
> > > > Sent: Saturday, March 9, 2013 5:04:43 PM
> > > > I think we need to cut down the size of these files for a demo
> > > > (although they are great for a stress test).
> > > > First, the RGB format by itself uses 3 bytes per pixel when it
> > > > only
> > > > needs one (for land use)
> > > > Second, we should cut down by a factor of 9 (3x3) or 16 (4x4).
> > > > I tried that using simple convert statements, but it always
> > > > seems
> > > > to
> > > > yield a file exactly double what it should be.
> > > > More on this later; was hoping to get things working "as is"
> > > > first.
> > > > I assume you could get the perl code to work on
> > > > one-byte-per-pixel
> > > > instead of the default 3 for the convert rgb format?
> > > > - Mike
> > > > > Sent: Saturday, March 9, 2013 4:36:30 PM
> > > > > That would probably be a good idea for a new script, to show
> > > > > how to
> > > > > stage apps like that. For now I updated the scripts on
> > > > > lustre..
> > > > > hopefully that helps.
> > > > > Sent: Saturday, March 9, 2013 4:29:14 PM
> > > > > OK, I see that its trying to run getlanduse.sh from your
> > > > > /lustre
> > > > > dir
> > > > > on beagle, which is different than the one Ive got checked
> > > > > out.
> > > > > It
> > > > > seems to get an error in a stderr redirect??? Let me se what
> > > > > I
> > > > > need
> > > > > to do to get the beagle side in sync.
> > > > > Seems like since these are perl scripts, we should make the
> > > > > app()
> > > > > /bin/sh and send the script as data, perhaps?
> > > > > - Mike
> > > > > > Sent: Saturday, March 9, 2013 4:19:31 PM
> > > > > > OK, making progress. Now I dialed down the throttle and
> > > > > > node
> > > > > > counts
> > > > > > to 48 jobs.
> > > > > > Now I get further, for ./demo and site=4 script=2:
> > > > > > RunID: 20130309-2214-1oi3rvea
> > > > > > Progress: time: Sat, 09 Mar 2013 22:14:06 +0000
> > > > > > Progress: time: Sat, 09 Mar 2013 22:14:17 +0000 Selecting
> > > > > > site:269
> > > > > > Progress: time: Sat, 09 Mar 2013 22:14:22 +0000 Selecting
> > > > > > site:269
> > > > > > Progress: time: Sat, 09 Mar 2013 22:14:28 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:25 Submitted:23
> > > > > > Progress: time: Sat, 09 Mar 2013 22:14:36 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:48
> > > > > > Progress: time: Sat, 09 Mar 2013 22:15:06 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:48
> > > > > > Progress: time: Sat, 09 Mar 2013 22:15:36 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:48
> > > > > > Progress: time: Sat, 09 Mar 2013 22:16:06 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:48
> > > > > > Progress: time: Sat, 09 Mar 2013 22:16:26 +0000 Selecting
> > > > > > site:269
> > > > > > Progress: time: Sat, 09 Mar 2013 22:16:27 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:36 Active:12
> > > > > > Progress: time: Sat, 09 Mar 2013 22:16:29 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:24 Active:24
> > > > > > Progress: time: Sat, 09 Mar 2013 22:16:34 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:24 Active:23 Stage out:1
> > > > > > Progress: time: Sat, 09 Mar 2013 22:16:35 +0000 Selecting
> > > > > > site:269
> > > > > > Stage in:14 Active:33 Stage out:1
> > > > > > Execution failed:
> > > > > > Exception in getlanduse:
> > > > > > Arguments:
> > > > > > [home/wilde/osgdemo/modis/svn/data/modis/2002/h08v04.rgb]
> > > > > > Host: beagle
> > > > > > Directory:
> > > > > > modis02-20130309-2214-1oi3rvea/jobs/k/getlanduse-ko5qjd6l
> > > > > > Caused by:
> > > > > > Application /lustre/beagle/davidk/modis/bin/getlanduse.sh
> > > > > > failed
> > > > > > with an exit code of 1
> > > > > > getLandUse, modis02.swift, line 20
> > > > > > real 2m31.463s
> > > > > > user 1m33.238s
> > > > > > sys 0m2.160s
> > > > > > + mv /home/wilde/.swift/runs/current/run024.1362867244
> > > > > > midway001$
> > > > > > > Sent: Saturday, March 9, 2013 3:55:30 PM
> > > > > > > ok, I'll take a look at that. The run dir I used was
> > > > > > > /scratch/midway/davidkelly999/modis/run011
> > > > > > > Sent: Saturday, March 9, 2013 3:52:28 PM
> > > > > > > I just tried this, but didnt work - same prob.
> > > > > > > But if its working for you now, we must be close.
> > > > > > > Not yet sure what the diff is...
> > > > > > > My run dir is /home/wilde/osgdemo/modis/svn/run021
> > > > > > > - Mike
> > > > > > > > Sent: Saturday, March 9, 2013 3:46:13 PM
> > > > > > > > Had to make sure I was using the IP address on eth4
> > > > > > > > (128.135.112.71
> > > > > > > > for midway-login1), not a local address or an
> > > > > > > > infiniband
> > > > > > > > address.
> > > > > > > > Sent: Saturday, March 9, 2013 3:43:51 PM
> > > > > > > > I just got it working. I had to adjust for the
> > > > > > > > differences in
> > > > > > > > my
> > > > > > > > username on Beagle/Midway, then I had to set
> > > > > > > > GLOBUS_HOSTNAME
> > > > > > > > on
> > > > > > > > Midway to the IP address, rather than the full hostname
> > > > > > > > Sent: Saturday, March 9, 2013 3:40:03 PM
> > > > > > > > > Sent: Saturday, March 9, 2013 3:34:58 PM
> > > > > > > > > Is your username the same on beagle and midway?
> > > > > > > > Yes. And I verified that I can ssh to login4 on beagle
> > > > > > > > from
> > > > > > > > my
> > > > > > > > midway
> > > > > > > > session (as indeed the scp's of the proxy files seem to
> > > > > > > > be
> > > > > > > > working)
> > > > > > > > - Mike
> > > > > > > > > Sent: Saturday, March 9, 2013 3:34:28 PM
> > > > > > > > > OK.
> > > > > > > > > Ignore what I said about "problem finding java" -
> > > > > > > > > thats
> > > > > > > > > code
> > > > > > > > > in
> > > > > > > > > the
> > > > > > > > > very long escaped shell command that gets sent to the
> > > > > > > > > remote
> > > > > > > > > side.
> > > > > > > > > I
> > > > > > > > > dont *think* thats the problem.
> > > > > > > > > I also verified that beagle can connect to ports
> > > > > > > > > 50001
> > > > > > > > > etc
> > > > > > > > > on
> > > > > > > > > swift.rcc, and that seems OK.
> > > > > > > > > I exported GLOBUS_HOSTNAME=
> > > > > > > > > midway001.rcc.uchicago.edu
> > > > > > > > > on
> > > > > > > > > the
> > > > > > > > > midway
> > > > > > > > > side. And the beagle side seems to be connecting
> > > > > > > > > there.
> > > > > > > > > Im a bit confused about the timestamps I see for the
> > > > > > > > > proxy
> > > > > > > > > expiration
> > > > > > > > > time, but am not yet suspicious of that (although it
> > > > > > > > > seems
> > > > > > > > > less
> > > > > > > > > than
> > > > > > > > > 5 hours past GMT... not sure.)
> > > > > > > > > - Mike
> > > > > > > > > > Sent: Saturday, March 9, 2013 3:26:32 PM
> > > > > > > > > > I'm seeing the same error now.. looking into it
> > > > > > > > > > Sent: Saturday, March 9, 2013 3:21:30 PM
> > > > > > > > > > Looking deeper I see that the logs show problems
> > > > > > > > > > with
> > > > > > > > > > finding
> > > > > > > > > > Java,
> > > > > > > > > > I
> > > > > > > > > > assume on beagle, ans also service ending
> > > > > > > > > > (presumably
> > > > > > > > > > coaster
> > > > > > > > > > service on midway host).
> > > > > > > > > > I'll dig into these two.
> > > > > > > > > > I see that it scp's the proxies to beagle which I
> > > > > > > > > > think
> > > > > > > > > > answers
> > > > > > > > > > my
> > > > > > > > > > question about security.
> > > > > > > > > > - Mike
> > > > > > > > > > > Sent: Saturday, March 9, 2013 3:15:01 PM
> > > > > > > > > > > OK. Any thoughts about beagle?
> > > > > > > > > > > Ive been experimenting but still cant get it to
> > > > > > > > > > > work,
> > > > > > > > > > > same
> > > > > > > > > > > error
> > > > > > > > > > > (cant connect to bootstrap port)
> > > > > > > > > > > WHen you tried ssh-cl to beagle with automatic
> > > > > > > > > > > coasters,
> > > > > > > > > > > what
> > > > > > > > > > > configuration (sites env etc) did you use?
> > > > > > > > > > > I verified that beagle can connect back to the
> > > > > > > > > > > midway
> > > > > > > > > > > hosts
> > > > > > > > > > > and
> > > > > > > > > > > ports.
> > > > > > > > > > > Do we need to specify security or create a proxy
> > > > > > > > > > > etc?
> > > > > > > > > > > Thanks,
> > > > > > > > > > > - Mike
> > > > > > > > > > > > Sent: Saturday, March 9, 2013 3:08:58 PM
> > > > > > > > > > > > One way you can override/customize the default
> > > > > > > > > > > > templates
> > > > > > > > > > > > is
> > > > > > > > > > > > to
> > > > > > > > > > > > create
> > > > > > > > > > > > them in $HOME/.swift/sites (I'm not sure if
> > > > > > > > > > > > that's
> > > > > > > > > > > > what
> > > > > > > > > > > > you
> > > > > > > > > > > > mean
> > > > > > > > > > > > by
> > > > > > > > > > > > a local sites dir or not). But you are right
> > > > > > > > > > > > about
> > > > > > > > > > > > Midway
> > > > > > > > > > > > I
> > > > > > > > > > > > have
> > > > > > > > > > > > noticed that when using modis it will sometimes
> > > > > > > > > > > > get
> > > > > > > > > > > > stuck
> > > > > > > > > > > > when
> > > > > > > > > > > > it
> > > > > > > > > > > > goes to a queue that is busy. Ideally swift
> > > > > > > > > > > > replication
> > > > > > > > > > > > would
> > > > > > > > > > > > be
> > > > > > > > > > > > able to help better handle that, but I haven't
> > > > > > > > > > > > had
> > > > > > > > > > > > much
> > > > > > > > > > > > luck
> > > > > > > > > > > > with
> > > > > > > > > > > > that yet. Another way around this may be to add
> > > > > > > > > > > > this
> > > > > > > > > > > > to
> > > > > > > > > > > > the
> > > > > > > > > > > > template:
> > > > > > > > > > > > <profile namespace="globus"
> > > > > > > > > > > > key="slurm.exclusive">false</profile>
> > > > > > > > > > > > The swift.log issue was never fixed. It went to
> > > > > > > > > > > > swift-devel
> > > > > > > > > > > > for
> > > > > > > > > > > > discussion but was never fixed. I think it is
> > > > > > > > > > > > relatively
> > > > > > > > > > > > simple
> > > > > > > > > > > > though.. probably worth fixing before release.
> > > > > > > > > > > > Sent: Saturday, March 9, 2013 1:38:47 PM
> > > > > > > > > > > > OK, sounds good re the trip plan. Feel free to
> > > > > > > > > > > > stay
> > > > > > > > > > > > Tue
> > > > > > > > > > > > night
> > > > > > > > > > > > to
> > > > > > > > > > > > avoid a 4hr drive after a long day.
> > > > > > > > > > > > Im trying the modis demo.
> > > > > > > > > > > > I tried to create a local sites/ dir so I can
> > > > > > > > > > > > modify
> > > > > > > > > > > > the
> > > > > > > > > > > > sites
> > > > > > > > > > > > templates; thats not working for me either yet.
> > > > > > > > > > > > For midway, need to force to westmere or sandyb
> > > > > > > > > > > > (but
> > > > > > > > > > > > not
> > > > > > > > > > > > both)
> > > > > > > > > > > > and
> > > > > > > > > > > > ensure 1-node jobs, because either queue can
> > > > > > > > > > > > get
> > > > > > > > > > > > filled
> > > > > > > > > > > > and
> > > > > > > > > > > > not
> > > > > > > > > > > > yield an idle node for a long time. maybe need
> > > > > > > > > > > > to
> > > > > > > > > > > > fiddle
> > > > > > > > > > > > jobsPerNode
> > > > > > > > > > > > to get at least 1 core when the system is busy
> > > > > > > > > > > > and
> > > > > > > > > > > > *pretend*
> > > > > > > > > > > > that
> > > > > > > > > > > > its a node.
> > > > > > > > > > > > So to get response I tried beagle-ssh; That
> > > > > > > > > > > > isnt
> > > > > > > > > > > > working
> > > > > > > > > > > > because
> > > > > > > > > > > > the
> > > > > > > > > > > > template sites file is wrong in swift 0.94 rc4.
> > > > > > > > > > > > I also see that swift.log is still getting
> > > > > > > > > > > > produced -
> > > > > > > > > > > > I
> > > > > > > > > > > > thought
> > > > > > > > > > > > we
> > > > > > > > > > > > eliminated that. Did it come back due to a
> > > > > > > > > > > > problem
> > > > > > > > > > > > with
> > > > > > > > > > > > that
> > > > > > > > > > > > fix?
> > > > > > > > > > > > I'll keep hacking; suggestions welcome.
> > > > > > > > > > > > - Mike
> > > > > > > > > > > > > Sent: Saturday, March 9, 2013 12:20:00 PM
> > > > > > > > > > > > > Hi Mike,
> > > > > > > > > > > > > Looking more closely at the agenda, I think
> > > > > > > > > > > > > the
> > > > > > > > > > > > > most
> > > > > > > > > > > > > interesting/useful talks will be on Tuesday.
> > > > > > > > > > > > > Monday
> > > > > > > > > > > > > I'll
> > > > > > > > > > > > > come
> > > > > > > > > > > > > to
> > > > > > > > > > > > > Argonne to work on any loose ends and put the
> > > > > > > > > > > > > finishing
> > > > > > > > > > > > > touches
> > > > > > > > > > > > > on
> > > > > > > > > > > > > any slides/runs/scripts, then drive to
> > > > > > > > > > > > > Indianapolis
> > > > > > > > > > > > > on
> > > > > > > > > > > > > Monday
> > > > > > > > > > > > > afternoon/evening. I have a hotel booked for
> > > > > > > > > > > > > Monday
> > > > > > > > > > > > > night.
> > > > > > > > > > > > > I'll do some runs using the routes we talked
> > > > > > > > > > > > > about.
> > > > > > > > > > > > > I'm
> > > > > > > > > > > > > pretty
> > > > > > > > > > > > > sure
> > > > > > > > > > > > > I
> > > > > > > > > > > > > have working configurations for everything we
> > > > > > > > > > > > > talked
> > > > > > > > > > > > > about,
> > > > > > > > > > > > > so
> > > > > > > > > > > > > I
> > > > > > > > > > > > > think it's really just a matter of plugging
> > > > > > > > > > > > > in
> > > > > > > > > > > > > the
> > > > > > > > > > > > > apps.
> > > > > > > > > > > > > David
> > > > > > > > > > > > > Sent: Saturday, March 9, 2013 11:03:15 AM
> > > > > > > > > > > > > Subject: runs for OSG talk
> > > > > > > > > > > > > Hi David,
> > > > > > > > > > > > > I just wanted to let you know that Im looking
> > > > > > > > > > > > > into
> > > > > > > > > > > > > the
> > > > > > > > > > > > > run
> > > > > > > > > > > > > options
> > > > > > > > > > > > > now. Im hoping to try a few... WIll see how
> > > > > > > > > > > > > much
> > > > > > > > > > > > > help
> > > > > > > > > > > > > I
> > > > > > > > > > > > > need.
> > > > > > > > > > > > > Have
> > > > > > > > > > > > > you decided on a driving time and made hotel
> > > > > > > > > > > > > arrangements?
> > > > > > > > > > > > > I would feel free to stay for whatever
> > > > > > > > > > > > > portion
> > > > > > > > > > > > > of
> > > > > > > > > > > > > the
> > > > > > > > > > > > > OSG
> > > > > > > > > > > > > meeting
> > > > > > > > > > > > > you
> > > > > > > > > > > > > feel is of value. The only thing I ask is
> > > > > > > > > > > > > that
> > > > > > > > > > > > > for
> > > > > > > > > > > > > Wed
> > > > > > > > > > > > > and
> > > > > > > > > > > > > Thu
> > > > > > > > > > > > > you
> > > > > > > > > > > > > stay available online for user-support or
> > > > > > > > > > > > > other
> > > > > > > > > > > > > assistance
> > > > > > > > > > > > > needs
> > > > > > > > > > > > > that come up here. And that you engage with
> > > > > > > > > > > > > people
> > > > > > > > > > > > > that
> > > > > > > > > > > > > can
> > > > > > > > > > > > > help
> > > > > > > > > > > > > us
> > > > > > > > > > > > > develop the Swift user community and reliable
> > > > > > > > > > > > > OSG
> > > > > > > > > > > > > usage.
> > > > > > > > > > > > > Rob,
> > > > > > > > > > > > > Marco,
> > > > > > > > > > > > > Lincoln, and Suchandra would be good to hang
> > > > > > > > > > > > > out
> > > > > > > > > > > > > with
> > > > > > > > > > > > > and
> > > > > > > > > > > > > they
> > > > > > > > > > > > > can
> > > > > > > > > > > > > introduce you to good contacts.
> > > > > > > > > > > > > Of course we will cover your expenses via a
> > > > > > > > > > > > > UChicago
> > > > > > > > > > > > > travel
> > > > > > > > > > > > > expense
> > > > > > > > > > > > > report.
> > > > > > > > > > > > > We'll be starting a project with a tiny bit
> > > > > > > > > > > > > of
> > > > > > > > > > > > > additional
> > > > > > > > > > > > > ExTENCI
> > > > > > > > > > > > > funds to make Swift do smarter data
> > > > > > > > > > > > > management
> > > > > > > > > > > > > on
> > > > > > > > > > > > > OSG
> > > > > > > > > > > > > sites
> > > > > > > > > > > > > (and
> > > > > > > > > > > > > in
> > > > > > > > > > > > > general) so anything you learn about OSG
> > > > > > > > > > > > > storage
> > > > > > > > > > > > > elements/services/tools will be valuable for
> > > > > > > > > > > > > that
> > > > > > > > > > > > > (srmcp,
> > > > > > > > > > > > > lcgcp,
> > > > > > > > > > > > > etc).
> > > > > > > > > > > > > Between now and your talk, lets just focus on
> > > > > > > > > > > > > the
> > > > > > > > > > > > > talk,
> > > > > > > > > > > > > OK?
> > > > > > > > > > > > > Im
> > > > > > > > > > > > > hoping
> > > > > > > > > > > > > we have slides frozen by Monday.
> > > > > > > > > > > > > While I fiddle, if you could do catsn or
> > > > > > > > > > > > > other
> > > > > > > > > > > > > hello-world-like
> > > > > > > > > > > > > tests
> > > > > > > > > > > > > to cover the "routes" we discussed, that
> > > > > > > > > > > > > would
> > > > > > > > > > > > > pave
> > > > > > > > > > > > > the
> > > > > > > > > > > > > way
> > > > > > > > > > > > > for
> > > > > > > > > > > > > plugging in the real app examples.
> > > > > > > > > > > > > Sound good? Let me know of any concerns
> > > > > > > > > > > > > (other
> > > > > > > > > > > > > than
> > > > > > > > > > > > > the
> > > > > > > > > > > > > fact
> > > > > > > > > > > > > that
> > > > > > > > > > > > > this is a tad rushed ;)
> > > > > > > > > > > > > Thanks and regards,
> > > > > > > > > > > > > - Mike
> > > > > > > > > > > > > Michael Wilde
> > > > > > > > > > > > > Computation Institute, University of Chicago
> > > > > > > > > > > > > Mathematics and Computer Science Division
> > > > > > > > > > > > > Argonne National Laboratory
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Ketan
