[Swift-devel] Connecting to nodes behind a login node
Yadu Nand
yadudoc1729 at gmail.com
Thu Jun 27 17:03:36 CDT 2013
Thanks to David for pointing out a very simple solution for this.
I wanted to ssh to the compute nodes behind the login node directly,
and this can be done by setting up the ssh-config file to use the
ProxyCommand feature. I set up my ~/.ssh/config file on swift.rcc with
the following :
Host churn.mcs.anl.gov
Hostname churn.mcs.anl.gov
User yadunand
ProxyCommand ssh -A yadunand at login.mcs.anl.gov nc %h %p 2> /dev/null
ForwardAgent yes
Now, I can directly ssh to churn using : "ssh churn.mcs.anl.gov" from swift.rcc.
-Yadu
On Thu, Jun 27, 2013 at 4:04 PM, Yadu Nand <yadudoc1729 at gmail.com> wrote:
> Hi,
> I am trying to use the MCS nodes (crush, stomp, thwomp...) to test a
> bag-of-workstations configuration. Earlier I used a persistent
> coaster-service running on one of these nodes to get tests run, but I
> would much rather connect to these from swift.rcc. Is there some way
> to tell swift to make the ssh-connection taking a hop over the login
> node ?
> I can't seem to find a method for this outlined either in the guides
> or mailing-list conversations. Any help would be appreciated.
> Thanks!
> Yadu
Yadu Nand B
