[Swift-devel] Swift standard library
Ketan Maheshwari ketancmaheshwari at gmail.com
Sat Jun 8 15:49:34 CDT 2013
Mike, my answers below:
On Sat, Jun 8, 2013 at 12:00 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> was: Re: Swift team meeting today - 2PM central - Agenda
> Ketan, what did people think about this? Did you discuss what Swift/T has?
Mihael opined that it makes sense for small and simple apps but worried it
could grow out of control over time as there are numerous ways in which
apps could be written currently. I know Swift/T uses import lot but we did
not discuss it in app library context.
> How would this be driven by real needs?
Start with demoing the idea by using import "applib" in Swift source so
users do not need to write app declarations in there code. They just need
to define data, loops and make app calls. 'type file;' should also be part
of applib as it is used in 99% of Swift scripts. Promote this style of
programming and gradually build app libraries for science use cases by
domain say "chemlib", "mdlib", and so on.
> What doc would be needed to make it useful and used?
We will need to identify app patterns and document them. Then try to fit as
many real app calls as possible in these patterns. We will need to document
and illustrate their usage. There will be outliers which won't fit in any
patterns and then there will be users who would want to declare there own
apps. Hopefully, users would be encouraged to put their apps in their own
libs and re-use them. We could absorb new apps into our applibs as they get
widely used.
> - Mike
> > From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> > To: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> > Cc: "Michael Wilde" <wilde at mcs.anl.gov>, "David Kelly" <
> davidk at ci.uchicago.edu>, "Mihael Hategan"
> > <hategan at mcs.anl.gov>, "Ketan Maheshwari" <ketan at mcs.anl.gov>, "Tim
> Armstrong" <tga at uchicago.edu>, "Yadu Nand"
> > <yadudoc1729 at gmail.com>, "Scott Krieder" <skrieder at iit.edu>, "Daniel S.
> Katz" <dsk at ci.uchicago.edu>, "Swift Devel"
> > <swift-devel at ci.uchicago.edu>
> > Sent: Saturday, June 8, 2013 10:28:52 AM
> > Subject: Re: Swift team meeting today - 2PM central - Agenda
> > Additionally, I proposed we create a small standard library of basic
> > apps and ship it with Swift. This library could contain app
> > declarations for simple apps such as cat, hostname, date, etc. This
> > library could then be imported into a Swift script making Swift
> > script look compact. Will add reusability value too.
> > We could steadily grow this to add more app declarations, say from
> > SwiftApps repo.
> > On Fri, Jun 7, 2013 at 2:39 PM, Justin M Wozniak <
> > wozniak at mcs.anl.gov > wrote:
> > On 06/07/2013 12:52 PM, Michael Wilde wrote:
> > Ketan is working on two power grid apps and had some minor questions
> > about Coasters for Mihael.
> > Yadu is working on the multi-site test suite which is itself
> > implemented as a Swift script.
> > Scott is looking at CUDA BLAS, OOPS, and mdproxy apps for GPU.
> > Justin added some minor new syntax in Swift/T. Made significant
> > additions to the Swift/T web materials. Provided Scott with an
> > eigenvalue code based on BLAS compatible with our model for Swift/T
> > and the GPU. Lots of conversation with the RDCEP and APS app cases.
> > For RDCEP, now have a better sense of how to validate and compare
> > the Swift/T implementation to the previous pure Fortran/MPI app. For
> > APS, have a better sense of overall workflow and some ideas on where
> > to find concurrency to target with Swift/T. Also working with Ketan
> > on Swift storage access on the cloud, focusing on the Chirp
> > experiments.
> > Tim is working on fixing up some remaining broken Swift/T tests.
> > Mihael is looking at some coasters data movement timeout errors
> > reported by Yadu.
> > o David outline strategy for swift command rework (esp. tc wildcards)
> > David is investigating pre-processing the Swift/K command line with
> > Perl. Mihael suggested some improvements to automatic app
> > configuration without tc.data .
> > o David: outline priority for corresponding User Guide revamp
> > David will have more time shortly to work on this.
> > o David: plans to phase in swift-lang.org and SWFT email list
> > David is in touch with David Forero about this.
> > o Mihael: help Yadu and David start documenting the protocol for
> > coasters in prep for coaster provider staging file caching feature
> > work
> > Done somewhere- Mihael will send Yadu and David the link.
> > o Yadu: review your observed Swift weaknesses and discuss & file (in
> > bugz) suggestions to address each
> > o Justin, Tim: next steps in Coaster integration
> > Yadu has the coasters C client running. Discussed a list of next
> > steps with Justin, including wrapping the client in SWIG and running
> > it from Swift/T. Justin provided code samples for reference.
> > o Ketan: perhaps discuss next steps for making AWS resources easy to
> > use by Swift end users
> > Ketan is doing this for the power grid app people.
> > o All: any other topics
> > Please report anything notable to swift-devel
> > Thanks, All, and have a great weekend.
> > - Mike
> > Justin M Wozniak
> > Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130608/8cc9bb66/attachment.html>
