[Swift-devel] dryrun for user
    Ioan Raicu
    iraicu at gmail.com
    Wed Jul 31 12:54:57 CDT 2013
I was thinking of using it to loosely couple Swift with some of the other work I am doing in my lab, specifically other run-times, as well as simulators. If its not there anymore, we'll think of some other way to get the DAG representation out of Swift.
Ioan
Ioan Raicu, Ph.D.
Assistant Professor, Illinois Institute of Technology (IIT)
Guest Research Faculty, Argonne National Laboratory (ANL)
Data-Intensive Distributed Systems Laboratory, CS/IIT
Distributed Systems Laboratory, MCS/ANL
Office: 1-312-567-5704
Email:  iraicu at cs.iit.edu
Web:    http://www.cs.iit.edu/~iraicu/
Web:    http://datasys.cs.iit.edu/
On Jul 25, 2013, at 10:59 AM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
> No, I don't really need it- we can drop it.
> On 07/25/2013 03:32 PM, Mihael Hategan wrote:
>> I think dryrun got removed in trunk (in the execution path, but I forgot
>> to remove it from the command line).
>> It was there along with "typecheck", which doesn't apply any more since
>> the swift compiler does the typechecking.
>> Is there a real need for dryrun any more?
>> Mihael
>> On Thu, 2013-07-25 at 13:59 -0500, Justin M Wozniak wrote:
>>> Yes.
>>> On 07/25/2013 12:46 PM, Mihael Hategan wrote:
>>>> Looks like a bug. Trunk?
>>>> On Thu, 2013-07-25 at 11:06 -0500, Justin M Wozniak wrote:
>>>>> Ok.  I currently get:
>>>>> swift -dryrun -pgraph o.dot ~/hello-k.swift
>>>>> <java stack dump>
>>>>> Could not start execution:
>>>>>       import @ hello-k.kml, line: 5:
>>>>> org.globus.cog.karajan.analyzer.CompilationException: Import of
>>>>> 'swift.k' failed:
>>>>>       generateProvenanceGraph @ swift.k, line: 132:
>>>>> org.globus.cog.karajan.analyzer.CompilationException: Unknown function:
>>>>> generateProvenanceGraph:
>>>>>       java.lang.RuntimeException: Unknown function: generateProvenanceGraph
>>>>> On 07/25/2013 10:48 AM, Mihael Hategan wrote:
>>>>>> Dryrun should produce no output. It fakes app execution, but runs
>>>>>> through the dependencies.
>>>>>> Mihael
>>>>>> On Thu, 2013-07-25 at 10:30 -0500, Justin M Wozniak wrote:
>>>>>>> I was trying to get dryrun working for a user yesterday but can't figure
>>>>>>> out where the output went- is anyone else currently using this?
>>>>>>>        Thanks
> Justin M Wozniak
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
