[Swift-devel] Coasters does only one round of tasks in faster trunk
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Jul 10 14:22:20 CDT 2013
Further tests show that a simple catsn workflow fails on this SGE system in the same manner (when using the same sites file) and that the failing script form the prior log succeeds on Midway (under 0.94).
A log from the catsn failure is at: http://www.ci.uchicago.edu/~wilde/catsn-20130710-1415-t7cprvsd.log
- Mike
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Mihael Hategan" <hategan at mcs.anl.gov>
> Sent: Wednesday, July 10, 2013 1:47:05 PM
> Subject: Re: [Swift-devel] Coasters does only one round of tasks in faster trunk
> Mihael, the 0.94 branch (latest rev) seems to behave the same way on
> this workflow.
> What I see in the log is below, with the last set of message
> repeating, with no new app tasks starting or completing, until I
> kill the script (ie Allocating blocks for a total walltime of: 35s;
> BlockQueueProcessor Jobs in holding queue: 32)
> I'll test this again on a different scheduler.  The app tasks should
> run for about 5 secs, even though Ive used a default maxwalltime of
> 15 min.
> - Mike
> 2013-07-10 13:32:21,243-0500 DEBUG swift CDM:
> file://localhost/data.0001.tiny : DEFAULT
> file://localhost/processpoints.py : DEFAULT
> 2013-07-10 13:32:21,243-0500 INFO  LateBindingScheduler jobs queued:
> 437
> file://localhost/out/seq/seq00313 : DEFAULT
> 2013-07-10 13:32:21,244-0500 DEBUG swift FILE_STAGE_IN_START
> file=seq00313 srchost=localhost srcdir=out/seq srcname=seq00313
> desthost\
> =cluster destdir=paintgrid-20130710-1331-g435v1l3/shared/out/seq
> provider=file policy=DEFAULT
> 2013-07-10 13:32:21,248-0500 INFO  LateBindingScheduler jobs queued:
> 437
> 2013-07-10 13:32:21,248-0500 DEBUG swift FILE_STAGE_IN_END
> desthost=c\
> provider=file
> 2013-07-10 13:32:21,248-0500 INFO  swift END jobid=python-69som5cl -
> Staging in finished
> 2013-07-10 13:32:21,249-0500 DEBUG swift JOB_START
> jobid=python-69som5cl tr=python arguments=[processpoints.py,
> data.0001.tiny, out/s\
> eq/seq00313, 0.0]
> tmpdir=paintgrid-20130710-1331-g435v1l3/jobs/6/python-69som5cl
> host=cluster
> 2013-07-10 13:32:21,251-0500 INFO  GridExec TASK_DEFINITION:
> Task(type=JOB_SUBMISSION, identity=urn:0-5-296-1-1-1373481110671) is
> /bi\
> n/bash shared/_swiftwrap python-69som5cl -jobdir 6 -scratch  -e
> python -out out/out.00313 -err stderr.txt -i -d out/seq|out -if
> proce\
> sspoints.py|data.0001.tiny|out/seq/seq00313 -of out/out.00313 -k
>  -cdmfile  -status provider -a processpoints.py data.0001.tiny
> out/s\
> eq/seq00313 0.0
> 2013-07-10 13:32:21,252-0500 INFO  RequestHandler Handler(tag: 65,
> SUBMITJOB) unregistering (send)
> 2013-07-10 13:32:21,312-0500 INFO  BlockQueueProcessor Jobs in
> holding queue: 32
> 2013-07-10 13:32:21,312-0500 INFO  BlockQueueProcessor Time estimate
> for holding queue (seconds): 36
> 2013-07-10 13:32:21,312-0500 INFO  BlockQueueProcessor Allocating
> 2013-07-10 13:32:22,354-0500 INFO  BlockQueueProcessor Jobs in
> holding queue: 32
> 2013-07-10 13:32:22,354-0500 INFO  BlockQueueProcessor Time estimate
> 2013-07-10 13:32:22,354-0500 INFO  BlockQueueProcessor Allocating
> 2013-07-10 13:32:23,377-0500 INFO  BlockQueueProcessor Jobs in
> holding queue: 32
> > Sent: Wednesday, July 10, 2013 1:09:04 PM
> > Subject: [Swift-devel] Coasters does only one round of tasks in
> > faster trunk
> > Mihael,
> > Ive run into a more serious problem: Im running on a single SGE
> > node
> > with 32 cores.
> > The swift script has submitted about 400+ app() tasks
> > 32 completed, but then coasters doesn't seem to be sending new jobs
> > to the node.
> > The log is at:
> > http://www.ci.uchicago.edu/~wilde/paintgrid-20130710-1252-v9p47hm8.log
> > I'll try the same on a 0.94.1 rev.
> > - Mike
> > > Sent: Wednesday, July 10, 2013 12:53:44 PM
> > > Subject: Initial tests of new (faster) trunk
> > > Initial tests of the new trunk are working for me, but I'm seeing
> > > three odd things:
> > > 1. [Error] sites.beagle.coasters.xml:1:9: cvc-elt.1: Cannot find
> > > the
> > > declaration of element 'config'.
> > >    (as reported in the email below)
> > > 2. {env.HOME} is not interpreted in sites.xml as in prior
> > > versions.
> > > Swift created a workdir named "$PWD/{env.HOME}/swiftwork"
> > > 3. Progress ticker lines seem to be defaulting to one per second,
> > > even with no status changing.
> > > But so far so good - a first test script using the new code is
> > > running nicely on SGE.
> > > - Mike
> > > > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > > To: "David Kelly" <davidk at ci.uchicago.edu>
> > > > Cc: swift-support at ci.uchicago.edu, "Michael Wilde"
> > > > Sent: Tuesday, February 19, 2013 2:46:14 PM
> > > > Subject: Re: [Swift Support #22699] Fwd: [Swift-devel] First
> > > > tests
> > > > with swift faster
> > > > Yeah. The validation fails. You can ignore it for now. I'll fix
> > > > in
> > > > the
> > > > future. Basically there is code to validate the sites file
> > > > against
> > > > the
> > > > XML schema, but it fails. It's not a fatal issue though, and
> > > > parsing
> > > > still happens.
> > > > Mihael
> > > > On Tue, 2013-02-19 at 14:22 -0600, David Kelly wrote:
> > > > > I tried updating from svn and running with the added url
> > > > > tags:
> > > > > <config>
> > > > > <pool handle="beagle">
> > > > > <execution provider="coaster" jobmanager="local:pbs"
> > > > > url="localhost"/>
> > > > > <profile namespace="globus" key="jobsPerNode">1</profile>
> > > > > key="lowOverAllocation">100</profile>
> > > > > key="highOverAllocation">100</profile>
> > > > > key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
> > > > > <profile namespace="globus" key="maxTime">4000</profile>
> > > > > key="maxWallTime">00:05:00</profile>
> > > > > key="disableIdleBlockCleanup">true</profile>
> > > > > <profile namespace="globus" key="slots">1</profile>
> > > > > <profile namespace="globus" key="nodeGranularity">1</profile>
> > > > > <profile namespace="globus" key="maxNodes">1</profile>
> > > > > <profile namespace="globus" key="queue">batch</profile>
> > > > > <profile namespace="karajan" key="jobThrottle">8.00</profile>
> > > > > key="initialScore">10000</profile>
> > > > > <filesystem provider="local" url="localhost" />
> > > > > <workdirectory>/lustre/beagle/davidk</workdirectory>
> > > > > </pool>
> > > > > </config>
> > > > > I am seeing this error:
> > > > > the
> > > > > From: "Mike Wilde" <swift-support at ci.uchicago.edu>
> > > > > Sent: Tuesday, February 19, 2013 1:50:15 PM
> > > > > Subject: [Swift Support #22699] Fwd: [Swift-devel] First
> > > > > tests
> > > > > with
> > > > > swift faster
> > > > > Tue Feb 19 13:50:14 2013: Request 22699 was acted upon.
> > > > > Transaction: Ticket created by wilde at mcs.anl.gov
> > > > > Queue: swift-support
> > > > > Subject: Fwd: [Swift-devel] First tests with swift faster
> > > > > Owner: Nobody
> > > > > Requestors: wilde at ci.uchicago.edu
> > > > > Status: new
> > > > > Ticket <URL:
> > > > > https://rt.ci.uchicago.edu/Ticket/Display.html?id=22699 >
> > > > > David, Mihael, Yadu: could one of you try this on Beagle on
> > > > > the
> > > > > faster branch?
> > > > > Does the faster branch include the PBS support for Beagle?
> > > > > It shouldnt be too hard to see what part of the PBS pool def
> > > > > it
> > > > > doesnt like.
> > > > > - Mike
> > > > > ----- Forwarded Message -----
> > > > > From: "Lorenzo Pesce" <lpesce at uchicago.edu>
> > > > > Sent: Tuesday, February 19, 2013 1:26:20 PM
> > > > > Subject: [Swift-devel] First tests with swift faster
> > > > > This is the content of the file where we have the first
> > > > > complaint
> > > > > from swift (see attached):
> > > > > <config>
> > > > > <pool handle="pbs">
> > > > > <execution provider="coaster" jobmanager="local:pbs"/>
> > > > > <!-- replace with your project -->
> > > > > key="project">CI-DEB000002</profile>
> > > > > <profile namespace="globus" key="jobsPerNode">24</profile>
> > > > > <profile namespace="globus" key="maxTime">172800</profile>
> > > > > key="maxwalltime">0:10:00</profile>
> > > > > key="lowOverallocation">100</profile>
> > > > > key="highOverallocation">100</profile>
> > > > > <profile namespace="globus" key="slots">200</profile>
> > > > > key="jobThrottle">47.99</profile>
> > > > > <filesystem provider="local"/>
> > > > > <!-- replace this with your home on lustre -->
> > > > > <workdirectory>/lustre/beagle/samseaver/GS/swift.workdir</workdirectory>
> > > > > </pool>
> > > > > </config>
> > > > > Any ideas?
> > > > > Begin forwarded message:
> > > > > From: Sam Seaver < samseaver at gmail.com >
> > > > > Date: February 19, 2013 1:16:28 PM CST
> > > > > To: Lorenzo Pesce < lpesce at uchicago.edu >
> > > > > Subject: Re: How are things going?
> > > > > I got this error. I suspect using the new SWIFT_HOME
> > > > > directory
> > > > > means that there's possibly a missing parameter someplace:
> > > > > should we resume a previous calculation? [y/N] y
> > > > > rlog files displayed in reverse time order
> > > > > should I use GS-20130203-0717-jgeppt98.0.rlog ?[y/n]
> > > > > y
> > > > > Using GS-20130203-0717-jgeppt98.0.rlog
> > > > > [Error] GS_sites.xml:1:9: cvc-elt.1: Cannot find the
> > > > > declaration
> > > > > of
> > > > > element 'config'.
> > > > > Execution failed:
> > > > > Failed to parse site catalog
> > > > > swift:siteCatalog @ scheduler.k, line: 31
> > > > > Caused by: Invalid pool entry 'pbs':
> > > > > Caused by: java.lang.IllegalArgumentException: Missing URL
> > > > > at
> > > > > org.griphyn.vdl.karajan.lib.SiteCatalog.execution(SiteCatalog.java:173)
> > > > > at
> > > > > org.griphyn.vdl.karajan.lib.SiteCatalog.pool(SiteCatalog.java:100)
> > > > > at
> > > > > org.griphyn.vdl.karajan.lib.SiteCatalog.buildResources(SiteCatalog.java:60)
> > > > > at
> > > > > org.griphyn.vdl.karajan.lib.SiteCatalog.function(SiteCatalog.java:48)
> > > > > at
> > > > > org.globus.cog.karajan.compiled.nodes.functions.AbstractFunction.runBody(AbstractFunction.java:38)
> > > > > at
> > > > > org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:154)
> > > > > at
> > > > > org.globus.cog.karajan.compiled.nodes.CompoundNode.runChild(CompoundNode.java:87)
> > > > > at
> > > > > org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:147)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > org.globus.cog.karajan.compiled.nodes.FramedInternalFunction.run(FramedInternalFunction.java:63)
> > > > > at
> > > > > org.globus.cog.karajan.compiled.nodes.Import.runBody(Import.java:269)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > org.globus.cog.karajan.compiled.nodes.Main.run(Main.java:79)
> > > > > at k.thr.LWThread.run(LWThread.java:243)
> > > > > at
> > > > > java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
> > > > > at
> > > > > java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
> > > > > at java.lang.Thread.run(Thread.java:722)
> > > > > On Tue, Feb 19, 2013 at 1:13 PM, Sam Seaver <
> > > > > wrote:
> > > > > OK, it got to the point where it really did hang. I'm
> > > > > retrying,
> > > > > but
> > > > > with your suggestions. The other three finished fine!
> > > > > Progress: time: Tue, 19 Feb 2013 19:08:53 +0000 Selecting
> > > > > site:18147 Submitted:174 Active:96 Failed:2 Finished
> > > > > successfully:132323 Failed but can retry:183
> > > > > Progress: time: Tue, 19 Feb 2013 19:09:23 +0000 Selecting
> > > > > Progress: time: Tue, 19 Feb 2013 19:09:53 +0000 Selecting
> > > > > Progress: time: Tue, 19 Feb 2013 19:10:23 +0000 Selecting
> > > > > Progress: time: Tue, 19 Feb 2013 19:10:53 +0000 Selecting
> > > > > Progress: time: Tue, 19 Feb 2013 19:11:23 +0000 Selecting
> > > > > On Tue, Feb 19, 2013 at 8:51 AM, Lorenzo Pesce <
> > > > > lpesce at uchicago.edu > wrote:
> > > > > Hmm...
> > > > > foreach.max.threads=100
> > > > > maybe you should increase this number a bit and see what
> > > > > happens.
> > > > > Also, I would try to replace
> > > > > SWIFT_HOME=/home/wilde/swift/rev/swift-r6151-cog-r3552
> > > > > with
> > > > > SWIFT_HOME=/soft/swift/fast
> > > > > Keep me posted. Let's get this rolling.
> > > > > if it doesn't work, I can redo the packing.
> > > > > On Feb 19, 2013, at 1:07 AM, Sam Seaver wrote:
> > > > > Actually, the ten agents job does seem to be stuck in a
> > > > > strange
> > > > > loop. It is incrementing the number of jobs that has finished
> > > > > successfully, and at a fast pace, but the number of jobs its
> > > > > starting is decrementing much more slowly, its almost as its
> > > > > repeatedly attempting the same set of parameters multiple
> > > > > times...
> > > > > I'll see what it's doing in the morning
> > > > > S
> > > > > On Tue, Feb 19, 2013 at 1:00 AM, Sam Seaver <
> > > > > wrote:
> > > > > Seems to have worked overall this time!
> > > > > I resume four jobs, each were for a different number of
> > > > > agents
> > > > > (10,100,1000,10000) it made it easier for me to decide on the
> > > > > app
> > > > > time. Two of them have already finished i.e.:
> > > > > Progress: time: Mon, 18 Feb 2013 23:50:12 +0000 Active:4
> > > > > Checking
> > > > > status:1 Finished in previous run:148098 Finished
> > > > > successfully:37897
> > > > > Progress: time: Mon, 18 Feb 2013 23:50:15 +0000 Active:2
> > > > > Checking
> > > > > successfully:37899
> > > > > Final status: Mon, 18 Feb 2013 23:50:15 +0000 Finished in
> > > > > previous
> > > > > run:148098 Finished successfully:37902
> > > > > and the only one that is showing any failure (50/110000), is
> > > > > the
> > > > > ten agents version which is so short I can understand why,
> > > > > but
> > > > > its
> > > > > still actively trying to run jobs and is actively finishing
> > > > > jobs,
> > > > > so that's good.
> > > > > Yay!
> > > > > On Mon, Feb 18, 2013 at 1:09 PM, Lorenzo Pesce <
> > > > > Good. Keep me posted, I would really like to solve your
> > > > > problems
> > > > > in
> > > > > running on Beagle this week, I wish that Swift would have
> > > > > been
> > > > > friendlier.
> > > > > On Feb 18, 2013, at 1:01 PM, Sam Seaver wrote:
> > > > > I just resumed the jobs that I'd killed before the system
> > > > > went
> > > > > down, lets see how it does. I always did a mini-review of the
> > > > > data
> > > > > I've got and it seems to be working as expected.
> > > > > On Mon, Feb 18, 2013 at 12:28 PM, Lorenzo Pesce <
> > > > > I have lost track a bit of what's up. I am happy to try and
> > > > > go
> > > > > over
> > > > > it with you when you are ready.
> > > > > Some of the problems of swift might have improved with a new
> > > > > version and the new system.
> > > > > On Feb 18, 2013, at 12:22 PM, Sam Seaver wrote:
> > > > > They're not, I've not looked since Beagle came back up. Will
> > > > > do
> > > > > so
> > > > > later today.
> > > > > S
> > > > > On Mon, Feb 18, 2013 at 12:20 PM, Lorenzo Pesce <
> > > > > Postdoctoral Fellow
> > > > > Mathematics and Computer Science Division
> > > > > Argonne National Laboratory
> > > > > 9700 S. Cass Avenue
> > > > > Argonne, IL 60439
> > > > > http://www.linkedin.com/pub/sam-seaver/0/412/168
> > > > > (773) 796-7144
> > > > > "We shall not cease from exploration
> > > > > And the end of all our exploring
> > > > > Will be to arrive where we started
> > > > > And know the place for the first time."
> > > > > --T. S. Eliot
> > > > > Postdoctoral Fellow
> > > > > 9700 S. Cass Avenue
> > > > > Argonne, IL 60439
> > > > > (773) 796-7144
> > > > > --T. S. Eliot
> > > > > Postdoctoral Fellow
> > > > > 9700 S. Cass Avenue
> > > > > Argonne, IL 60439
> > > > > (773) 796-7144
> > > > > --T. S. Eliot
> > > > > Postdoctoral Fellow
> > > > > 9700 S. Cass Avenue
> > > > > Argonne, IL 60439
> > > > > (773) 796-7144
> > > > > --T. S. Eliot
> > > > > Postdoctoral Fellow
> > > > > 9700 S. Cass Avenue
> > > > > Argonne, IL 60439
> > > > > (773) 796-7144
> > > > > --T. S. Eliot
> > > > > tags:
> > > > > <config>
> > > > > url="localhost"/>
> > > > >   </pool>
> > > > > </config>
> > > > > the
> > > > > ______________________________________________________________________
> > > > >         First
> > > > >         tests
> > > > >         with swift faster
> > > > >         upon.
> > > > >              swift
> > > > >              faster
> > > > >                Owner: Nobody
> > > > >               Status: new
> > > > >          Ticket <URL:
> > > > >         Beagle
> > > > >         on
> > > > >         the faster branch?
> > > > >         Beagle?
> > > > >         pool
> > > > >         def
> > > > >         it doesnt like.
> > > > >         - Mike
> > > > >         first
> > > > >         complaint from swift (see attached):
> > > > >         <config>
> > > > >         <pool handle="pbs">
> > > > >         </pool>
> > > > >         </config>
> > > > >         Any ideas?
> > > > >         directory
> > > > >         someplace:
> > > > >         y
> > > > >         Execution failed:
> > > > >         Missing
> > > > >         URL
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at
> > > > >         at java.util.concurrent.ThreadPoolExecutor
> > > > >         retrying, but with your suggestions. The other three
> > > > >         finished
> > > > >         fine!
> > > > >         Selecting
> > > > >         Selecting
> > > > >         Selecting
> > > > >         Selecting
> > > > >         Selecting
> > > > >         Selecting
> > > > >         Hmm...
> > > > >         what
> > > > >         happens.
> > > > >         with
> > > > >         a
> > > > >         strange loop. It is incrementing the number of jobs
> > > > >         that
> > > > >         has
> > > > >         finished successfully, and at a fast pace, but the
> > > > >         number
> > > > >         of
> > > > >         jobs its starting is decrementing much more slowly,
> > > > >         its
> > > > >         almost
> > > > >         as its repeatedly attempting the same set of
> > > > >         parameters
> > > > >         multiple times...
> > > > >         S
> > > > >         of
> > > > >         agents
> > > > >         decide
> > > > >         on
> > > > >         the
> > > > >         app time. Two of them have already finished i.e.:
> > > > >         Active:4
> > > > >         Checking status:1 Finished in previous run:148098
> > > > >         Finished
> > > > >         successfully:37897
> > > > >         Active:2
> > > > >         Finished
> > > > >         successfully:37899
> > > > >         Finished
> > > > >         in
> > > > >         previous run:148098 Finished successfully:37902
> > > > >         (50/110000),
> > > > >         is
> > > > >         the ten agents version which is so short I can
> > > > >         understand
> > > > >         why,
> > > > >         but its still actively trying to run jobs and is
> > > > >         actively
> > > > >         finishing jobs, so that's good.
> > > > >         Yay!
> > > > >         your
> > > > >         problems in running on Beagle this week, I wish that
> > > > >         Swift
> > > > >         would have been friendlier.
> > > > >         system
> > > > >         went
> > > > >         mini-review
> > > > >         of
> > > > >         the
> > > > >         data I've got and it seems to be working as expected.
> > > > >         try
> > > > >         and
> > > > >         go
> > > > >         over it with you when you are ready.
> > > > >         with
> > > > >         a
> > > > >         new
> > > > >         up.
> > > > >         Will
> > > > >         do so later today.
> > > > >         S
> > > > >         Postdoctoral Fellow
> > > > >         9700 S. Cass Avenue
> > > > >         Argonne, IL 60439
> > > > >         (773) 796-7144
> > > > >         --T. S. Eliot
> > > > >         Postdoctoral Fellow
> > > > >         9700 S. Cass Avenue
> > > > >         Argonne, IL 60439
> > > > >         (773) 796-7144
> > > > >         --T. S. Eliot
> > > > >         Postdoctoral Fellow
> > > > >         9700 S. Cass Avenue
> > > > >         Argonne, IL 60439
> > > > >         (773) 796-7144
> > > > >         --T. S. Eliot
> > > > >         Postdoctoral Fellow
> > > > >         9700 S. Cass Avenue
> > > > >         Argonne, IL 60439
> > > > >         (773) 796-7144
> > > > >         --T. S. Eliot
> > > > >         Postdoctoral Fellow
> > > > >         9700 S. Cass Avenue
> > > > >         Argonne, IL 60439
> > > > >         (773) 796-7144
> > > > >         --T. S. Eliot
> > > > >         Postdoctoral Fellow
> > > > >         9700 S. Cass Avenue
> > > > >         Argonne, IL 60439
> > > > >         (773) 796-7144
> > > > >         --T. S. Eliot
> > > > >         Swift-devel mailing list
> > > > >         Swift-devel at ci.uchicago.edu
> > > > >         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
